Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 08-15-2011, 07:13 PM   #1
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW > 25mm Rear Sway Bar For 2008+ WRX & STI
Introducing The NEW 25mm Rear Sway Bar For 2008-2011 WRX and STI
PERRIN sway bars are made from solid steel using precision bending equipment. The entire bar is heavily powder coated to fight corrosion and give it that great red finish. We laser cut and MIG weld our bar ends for precise placement. This type of bar end will never fail and gives us greater precision over competitors. (Competitors who smash the ends of their bars flat)
PERRIN Performance sway bars incorporate multiple endlink mounting holes which allow the installer to custom tailor your driving experience. Perrin sway bars increase stiffness by a minimum of 100% overstock. Adjusting the endlink mounting position can increase that stiffness to as much at 400% over stock. *varies by model
Centering Rings
Perrin Performance sway bars feature centering rings that prevent sway bar movement in hard cornering. This keeps your sway bar centered and ready for the next corner.
All sway bars include polyurethane bushings for a crisp response and better turn in. Special pockets carved into the bushing surface extends the interval between re-greasing.
19mm, 22mm or 25mm
Perrin Performance sway bars come in three different sizes. 19mm, 22mm and the new 25mm. Driving enthusiast will enjoy the feel of a 19mm bar while true racers will like the rigidity of the 25mm.
MSRP $219.99
Most of our coupons will work on this items to save you some money.
Click HERE to check it out.
Wholesale clients please contact your PERRIN sales rep for more info.
PERRIN is offline   Reply With Quote
NEW > Radiator Shroud For 2008+ WRX & STI PERRIN Perrin Performance 10 02-26-2014 01:49 PM
FS (AL): SOLD!!! Cobb 25mm Rear Sway Bar for 04-07 STI - excellent condition stidoc Suspension/Brakes/Handling 4 04-22-2010 10:51 AM
FS(CA): Cobb Rear Sway Bar for 2008+ WRX/STi(cheap!!) vinceGC8 Suspension/Brakes/Handling 23 12-20-2009 02:40 AM
Perrin adjustable 25mm rear sway bar for wrx with stoutmounts $200 shipped wagoneee Suspension/Brakes/Handling 0 09-30-2008 08:25 AM
WTB: Perrin 25mm rear sway bar for '06 STi roadracerex Private 'Wanted' Classifieds 0 02-11-2008 09:15 PM
