Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 08-16-2011, 12:37 AM   #1
gcMatt
Member#: 278426
1995 wrx
black
Default North American Header/Uppipe on rhd car?
local guy is selling his aps equal length headers/uppipe for an 2007 sti for a good price, it would be perfect for my track car build. however i have a 1995 wrx, ej20g, right hand drive car. Im wondering if this header/uppipe combo will work on my car? i want to use an 02-07 downpipe, no custom made stuff. I remember reading that the sti stuff wont clear my oil pan. I was also curious if the new up pipe would clear my steering rack? just wondering if anyone on here has tried it. heres a pic of the headers.
gcMatt is offline   Reply With Quote
Old 08-16-2011, 03:15 AM   #2
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I dont know about the aps header specifically but i have researched this issue myself. The general consensus is that equal length headers require an sti oilpan to fit. On the other hand most Unequal length headers will fit no problem.
TommyAtomic is offline   Reply With Quote
Old 08-16-2011, 07:26 AM   #3
luka
Member#: 194742
1993 Impreza WRX JDM
I have a 4" USDM DP and I had to bang it a little / grind the steering column knuckle a bit to make it fit.
luka is offline   Reply With Quote
Old 08-16-2011, 10:13 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
a 2.5 oil pan and pick up will be required..
and...
the GD nose is slightly longer, more distance between the engine and the front frame/radiator some equal length headers won't clear.. no idea if this one will work .. steering rack/crossmember clearance should be fine
dp: the jdm dp is shorter so if you want to do a usdm (cdm) 02-07 dp you will also need a 02-07 catback ..
Old 08-16-2011, 01:44 PM   #5
gcMatt
Member#: 278426
1995 wrx
black
and...
hmmm. I havent looked into the oil pan issue yet, is the sti oilpan/oil pump pickup a direct swap onto a 2.0L? I doubt theres any way around the subframe issue tho. About the downpipe, i already have an invidia n1 race turboback, i just wanted to make sure this uppipe wouldnt relocate the turbo at all.
Old 08-17-2011, 10:35 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
that should be fine and the oli pan is a direct swap .. just need to put it in the air and take some measurements
FS : 02 WRX injectors, TGV's, Ebay header/uppipe!!!! Autopilot747 TXIC Private Classifieds 4 08-14-2011 11:45 PM
FS : 02 WRX injectors, TGV's, Ebay header/uppipe!!!! Autopilot747 Engine/Power/Exhaust 4 08-08-2011 11:53 AM
Laws on RHD cars in BC? Rat^3 Vancouver Impreza Club Forum -- VIC 6 05-16-2011 09:57 AM
FS: 3 times North American PGT winning car 2002 WRX ! gizmo666 Private Vehicle 'For Sale' Classifieds 2 12-09-2003 11:08 PM
Looking for 2003 Head and taillights from a non North American car Alexn Legacy Forum 0 08-09-2002 11:39 AM
