Old 08-16-2011, 03:56 AM   #1
bradg1166
Member#: 280700
2005 WRX C70
PMS
Default catless dp on stage 2
what problems, if any can i run into with having a catless dp with a stage 2 flash from AP?
bradg1166 is offline   Reply With Quote
Old 08-16-2011, 08:44 AM   #2
humperdinc
Member#: 205625
2009 Impreza WRX
obp
The only problems I went through with getting a catless dp with Perrin stage2 map was not being able to contain my excitement Second problem was wanting more power after getting used to the stage2 power
Honestly, as long as everything is installed correctly (make sure the stage2 map is loaded correctly) and the bolts tightened, you have nothing to worry about.
humperdinc is offline   Reply With Quote
Old 08-16-2011, 09:46 AM   #3
fenix-silver
Member#: 231700
2004 WRX Wagon
You shouldn't have any problems. I believe the issue of boost creep is more prevalent on the 2.5 liter engines.
fenix-silver is offline   Reply With Quote
Old 08-16-2011, 12:05 PM   #4
bradg1166
Member#: 280700
2005 WRX C70
PMS
ok thanks
Installed my catless DP on Sunday, reflashed to cobb stage 2 and.... beedee AccessPort 9 05-15-2009 05:57 PM
is a 4" DP hurting HP on stage 2? lowranger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-02-2008 05:08 PM
catless dp on an 06 wrx cel or not??? (stock tune) hector Newbies & FAQs 16 12-30-2007 02:15 PM
Do I need programming to get a catless DP on my 2.5? kc jazz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-21-2007 08:10 AM
06 WRX TR Invidia V2 catless DP and stage 2!! chirp the 1-2 Car Part Reviews 8 08-03-2006 11:15 AM
