Notices
Old 08-16-2011, 04:42 PM   #1
RJ2120
Member#: 285018
2006 vf34 wrx
sgm
Default HELPP problems with cobb ap
I just got an accessport for my 06 wrx from another nasioc member and i was reflashing to stage 1 and the screen turned black in the middle of reflash. so i turned the car off and then the screen turned back on and stated it went into recovery mode do to failed attempt. So i go to uninstall but it cant communicate with the car and every time i turn it to the on position the accessport turns off so can somebody please help me out! i was thinking my battery is low on power if i have some body give me a jump would that work?
RJ2120 is offline   Reply With Quote
Old 08-17-2011, 08:45 AM   #2
Cobb Tuning
Member#: 4803
Sorry for the troubles you've been having.
It could be there is a problem with the AccessPORT or OBD cable. If you have another car, I would try plugging the AccessPORT in (don't actually do anything) just to see if the screen remains on. If it does, then it is either your OBD port that has a problem or it is a low battery (or other electrical issue). If that is the case, then you can put it on a trickle charger. If all else fails, give our tech support guys a call: 866-922-3059
Bill
Problems With My AP V1 rally'n AccessPort 2 04-20-2009 01:03 PM
Problem with COBB AP V2 jd20jd AccessPort 0 09-07-2007 01:22 AM
problems with new ap kmv AccessPort 11 12-16-2006 07:07 PM
Problems with Cobb AP AWD>FWD Engine Management & Tuning 9 05-14-2006 12:14 PM
anybody with COBB ap with fmic? awdguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-28-2005 02:49 PM
