Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 08-26-2014, 11:52 PM   #1
Apex22b
Member#: 306286
08 WRX
Default 08 WRX Stage 1+ SF 91 MTv300 LWG Logs
Just wanted to leave this here and get some help. I hit fuel cut (sorry wasn't logging at the time) and I have not wanted to recreate it. only Mods on the car are COBB SF intake, and AccessPort with Stage 1+ SF91 MTv300 LWG on it. I know the car is hitting 17.5-19.0 PSI a few times in second gear but cant recreate it with just a 3rd gear pull. Any help will be greatly appreciated
https://docs.google.com/spreadsheets...it?usp=sharing 3rd Gear Controlled Pull
https://docs.google.com/spreadsheets...it?usp=sharing 17.47 PSI spike (unsure of gear)
I will try soon to replicate the fuel cut and log that run
Apex22b is offline   Reply With Quote
Old 08-27-2014, 12:06 PM   #2
snoopy_sti
Member#: 164942
2013 WRX STI Limited
2007 WRX STI Limited
need permissions
snoopy_sti is offline   Reply With Quote
Old 08-28-2014, 12:24 AM   #3
Apex22b
Member#: 306286
08 WRX
My bad it has been fixed should be able to see it now.
Old 08-28-2014, 08:20 AM   #4
snoopy_sti
Member#: 164942
Your first log looks fine, you had a perceived knock event at lower rpms that it pulled timing for and then added it back in. I see the boost spike in the second log. I don't know what is up with that because I was looking at the throttle position and you were only at 90% when it happened. Also in the start of that log your DAM dropped to 0.625. There could be many causes for that to happen so I would go back to the stock intake for the boost spike, and maybe try running 93 gas with the 91 map to see if that keeps your DAM in check.
Old 09-01-2014, 04:48 PM   #5
Apex22b
Member#: 306286
08 WRX
Thanks alot for the info. I will go back to the stock intake to see what happens. I wish I could go to 93 out here but only 91 available in my part of Kansas. Is the knock event you were talking about normal? I am still pretty new to all of this thank you
Old 09-10-2014, 11:13 PM   #6
Apex22b
Member#: 306286
08 WRX
removed the Cobb SF Intake re flashed with the Stage 1 LWG here is a datalog
thanks for looking
Old 09-10-2014, 11:29 PM   #7
snoopy_sti
Member#: 164942
Yeah something weird is going on because your DAM is 0.8, your getting some knock still. Did the DAM start at 1 and work its way down?
If it started at .8 you can reset the ECU and drive it in 2nd gear under moderate boost at 2500 rpm while holding one foot on the break and the other on the gas and it should raise the DAM to 1 right away. Or you could just drive it around normally doing some moderate boost until the DAM gets to 1. Most maps now start at 1 and if something is wrong it decreases. Older maps started at a lower value and increased to 1.0.
Old 09-13-2014, 01:43 AM   #8
Apex22b
Member#: 306286
08 WRX
I reset the ECU and checked the DAM it was at .812 stayed there till running it at minor boost for a while, then it went to 1.0 staying there. I am going to drive around it around for a little while longer and then take another log and post it
