Old 02-23-2013, 11:51 AM   #26
Airboy
Member#: 72829
2006 WRX
2015 WRX
Originally Posted by lancelucas View Post
According to theory, yes, the damper serves a well-intended purpose (absorbing fuel line pulsation). This isn't from the pump being run at partial speed, but rather, from injectors opening and closing and such.
http://www.injector.com/cart/pc/Puls...Dampers-c4.htm
http://injector-rehab.com/shop/fpd.html
Here in the real world, our 4 cylinders do perfectly fine with no ill effects without a damper. The OEM dampers don't do a whole lot and are prone to getting noisy anyways, unfortunately.
I would think the pump being pulsed on/off at 33/66% duty cycle will create pulses in the fuel line as well, at whatever frequency that it is toggling at.
Airboy is online now   Reply With Quote
Old 02-23-2013, 12:05 PM   #27
cummins990
Member#: 245156
2005 STI
yes i could see that being an issue also which is why i might try to bypass that. But if the stumbling is due to pulsation or noise and in my case see more noise with dampers. There are others that have seen success with no dampers so I cant see it being an issue.
cummins990 is offline   Reply With Quote
Old 02-23-2013, 01:04 PM   #28
Airboy
Member#: 72829
2006 WRX
2015 WRX
I am sure it works, as far as the issue at 25-3000RPM goes. I am just not sure what potential side effects it would have.
Old 02-23-2013, 01:17 PM   #29
cummins990
Member#: 245156
2005 STI
Yes but wouldn't you see any side affects in the learning view
Old 02-23-2013, 01:43 PM   #30
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Oops.
lancelucas is offline   Reply With Quote
Old 02-23-2013, 01:45 PM   #31
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
The PWM output from the fuel pump controller is ~18000 hz. Not a concern.
Old 02-23-2013, 01:47 PM   #32
cummins990
Member#: 245156
2005 STI
So you don't think the duty cycle fluctuation will make any difference with or without dampers? So no need to bypass?
Old 02-23-2013, 01:49 PM   #33
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
So you don't think the duty cycle fluctuation will make any difference with or without dampers? Do no need to bypass?
Correct.
Old 02-23-2013, 02:16 PM   #34
Airboy
Member#: 72829
2006 WRX
2015 WRX
That fast eh? Good to know.
Old 02-23-2013, 09:41 PM   #35
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Fast lil bugger. My rudimentary understanding of the situation thinks that any lower would cause issues with the "audible" range (at least from an OEM designer's perspective).
Old 03-08-2013, 06:09 PM   #36
cummins990
Member#: 245156
2005 STI
I ended up totally fixing the problem. My comps are all zeroed out and no stumble.
No dampers with an after market FPR. Runs better than ever.
Old 03-08-2013, 07:12 PM   #37
kapp_badbloodz
Member#: 203327
The rails with larger injectors + tuning gave me ZERO stumble. Its phenomenal to drive a car that feels normal again
kapp_badbloodz is offline   Reply With Quote
Old 03-08-2013, 07:14 PM   #38
cummins990
Member#: 245156
2005 STI
Did your tuner zero out your comp tables? If not then it is likely to come back.
Old 03-08-2013, 07:24 PM   #39
kapp_badbloodz
Member#: 203327
Hmmm... I didn't. But that's a question I'll ask when I go back. I believe it was but not 100% sure
Old 03-16-2013, 03:30 PM   #40
badkulo
Member#: 53565
2008 OBP STi SQC 278
Guys, when you zero the comp tables? Does your ecu still able to make fuel correction? I'm on Cobb race tuner and both my correction and learning wont budge from zero after zeroing out the load comp tables. Any ideas?
badkulo is offline   Reply With Quote
Old 03-16-2013, 03:41 PM   #41
eminehart
Member#: 11205
2015 WRX
Zeroing out that table does not effect fuel correction. Sometimes randomly after a reflash the o2 sensor takes a while to warm up. Restart the car and it should come back.
eminehart is offline   Reply With Quote
Old 03-16-2013, 03:56 PM   #42
badkulo
Member#: 53565
Thanks for the quick response. I might have zeroed out the wrong tables since I'm using race tuner. Its under the close loop target load compensation a&b tables. Is it the right one?
Old 03-16-2013, 04:02 PM   #43
eminehart
Member#: 11205
2015 WRX
Wrong table.
No its in the sensor calibrations tab.
Load Compensation (Manifold Pressure)(Accel)
Load Compensation (Manifold Pressure)(Cruise)
Old 03-16-2013, 04:12 PM   #44
badkulo
Member#: 53565
Thank you!
Old 08-02-2013, 02:54 AM   #45
eagland
Member#: 246792
2010 SE STI
Default 2800 RPM stumble FIXED
Cobb 3.30 map has fix for this issue. I just reflashed ECU with 3.30, it's gone.
eagland is offline   Reply With Quote
Old 08-02-2013, 09:27 PM   #46
hutch959
Member#: 267463
wait for it........
hutch959 is offline   Reply With Quote
Old 08-14-2013, 09:58 AM   #47
pumba
Member#: 308636
2008 STi
wow thats funny. I spent ~ 4 hours last night datalogging/tuning and fixed the issue (for the most part, i get some stumble below 2k rpms).. I'm going to put on the v3.3 stage 2 map tonight and see if its gone with those maps. I've been reading about this issue for a while and was surprised cobb hadn't came up with a fix yet. I'll post back in a few days and confirm if the studder is gone on my car for the v3.3.
pumba is offline   Reply With Quote
Old 08-16-2013, 11:20 AM   #48
pumba
Member#: 308636
2008 STi
yup its fixed. zero stumble and the car seems to run 10x better with v3.3. Read the release notes to try and see what they did but they didn't go into too much detail. Either way my car feels brand new! I did notice they dropped off the peak HP/TQ a decent amount (~10%) according to the release notes, i have yet to do a virtual dyno and see if its true.
Old 08-16-2013, 02:13 PM   #49
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
Cobb 3.31v fixed the stumble and better yet the random "cruise" knock that I have been fighting over a year. I enjoyed driving my car for the first time in a year today. Thanks Cobb for fixing it!
Mplvan is offline   Reply With Quote
Old 08-16-2013, 02:41 PM   #50
MADMIKE874
Member#: 280732
2011 STI hatch
Is the stumble going away with custom maps as well as off the shelf maps? I'm curious because I've been pro tuned and my tuner can't get the stumble resolved, So im going the AP route and going to see if the local cobb tuning shop can get my problem fixes. I've got built motor with upgraded Turbo, fuel, Evey thing. I ordered my V3 at the start of the month and am still waiting for them to get more built and shipped out. From what I have read I am hoping that there is something in the software that will help out even with custom tunes.
MADMIKE874 is offline   Reply With Quote
Did you pass OBD-II test with Accessport stage 2 and upipe resistor fix? MO REX Engine Management & Tuning 4 11-24-2004 07:12 PM
Are fixes required with AccessPORT REX Tuner Engine Management & Tuning 5 04-06-2004 09:14 AM
Stumbling with ECUtek Part 2 wRxbeater11 Engine Management & Tuning 1 03-27-2003 05:25 PM
Stumbling with ECUtek wRxbeater11 Engine Management & Tuning 16 03-23-2003 03:17 AM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 12:53 AM
