Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 08-16-2011, 11:22 PM   #1
LiveAloha
Member#: 289286
2007 Wrx Sti
Default Any tips of removing scratches?
As the title says. Will wet sanding be the best way? and how about those dull scratches in between the door handle where it dips?
LiveAloha is offline   Reply With Quote
Old 08-17-2011, 12:35 AM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....sorry, but your title is just as vague as your post.
Kean is offline   Reply With Quote
Old 08-17-2011, 01:25 AM   #3
Drifter2be
Member#: 265122
2004 WRX
Java Black Pearl
I assume you are talking about from the scratches at the bottom of the exterior door cup underneath the handle, from people dragging fingernails along the bottom? Those piss me off so much. Get yourself a foam applicator pad, cut it in half to make it fit easier, then use ScratchX 2.0, it made them pretty much invisible on my car. Hope that helps.
Drifter2be is offline   Reply With Quote
Old 08-18-2011, 12:56 PM   #4
smokey07
Member#: 151683
60 grit sand paper, and rub the hell out of teh scratches.
Report back with results and pics.
smokey07 is offline   Reply With Quote
Old 08-18-2011, 01:41 PM   #5
GARGOYLE
Member#: 178918
Damn its getting harsh in here
GARGOYLE is offline   Reply With Quote
Old 08-18-2011, 08:58 PM   #6
LiveAloha
Member#: 289286
2007 Wrx Sti
i meant on the exterior where the handles
Old 08-18-2011, 09:50 PM   #7
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
grap my tired
(get some 205 and a microfiber waxing pad)
JimmyOOOOO is offline   Reply With Quote
Old 08-18-2011, 10:36 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
.....where the handles......what????
Seriously, at least make an effort to communicate the details of your problem so we can help you. ....this is a pet peeve of mine if you can't tell.
Old 08-19-2011, 01:14 AM   #9
DBus81
Member#: 291904
DO NOT WET SAND. UNLESS you're planning on repainting that area..... use compound rubber.... works the best.... I have been detailing cars for awhile and it has never failed on me.
DBus81 is offline   Reply With Quote
Old 08-19-2011, 02:23 AM   #10
wrxwon
Member#: 269596
2011 WRX
Are you able to post some pics? What you used to repair scratches depends on where and how deep it is.
wrxwon is offline   Reply With Quote
Old 08-19-2011, 06:23 AM   #11
JimmyOOOOO
Member#: 12647
2011 STi
Talking
OP, I just saw you were from Fort Drum... do you ever come to the Syracuse meet-ups? There's one this saturday at 5 Guys. Send me a PM if you're coming down and I will bring my porter cable and some 205. That'll do the trick fo sho!
p.s.- Thank you for your service to our country!
Old 08-19-2011, 09:03 PM   #12
LiveAloha
Member#: 289286
2007 Wrx Sti
i wish i could but i just got my wisdom teeth pulled ill be there next saturday
Old 08-20-2011, 07:01 PM   #13
mvkl5
Member#: 292038
Scratch-X works
mvkl5 is offline   Reply With Quote
Old 08-24-2011, 07:22 PM   #14
Gazeebo
Member#: 232698
2002 WRX Wagon
don't sand it. try some rubbing compound followed by a wax.
Gazeebo is offline   Reply With Quote
Old 08-24-2011, 08:50 PM   #15
jxkim
Member#: 239150
2003 WRX Sedan
you always start with less abrasive and move up. sanding would be last resort and probably counter productive in your case
jxkim is offline   Reply With Quote
Old 08-24-2011, 08:53 PM   #16
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Do not wet sand within the door handles. You will not be able to get a buffer in there and trying to compound, polish out the wet sanding marks will be near impossible. Get some rubbing compound and an applicator and work it that way. I detail cars and this is what I do. I wish there was a better way to do this but there isn't.
Subydude81 is offline   Reply With Quote
Old 08-25-2011, 03:29 AM   #17
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Using compound rubber....... yea sounds like you've been detailing for a long time.
pho_shizzle is offline   Reply With Quote
Old 08-25-2011, 07:07 AM   #18
kateviliams
Member#: 285333
use scracthX it is very effective for the scracth's .
kateviliams is offline   Reply With Quote
Old 08-25-2011, 10:23 AM   #19
Subydude81
Member#: 118266
6MT
Those scratches in the handle area are 99% to deep for scratch x and some sort of rubbing compound will need to be used. You can then follow it up with a polish or scratch x.
Old 08-25-2011, 10:55 AM   #20
Kean
Member#: 25187
'08 Foz Prem TGM
.....this makes the most sense considering none of us knows exactly what the extent of the damage is since the OP won't provide the information needed.
IME, in some cases those types of scratches (in the recessed area of the door handle) will correct quite easily if they are light enough (especially when the marks are more like transfer rather than any sort of real "scratch" from peoples nails). In those cases, using a product like Scratch-X can work rather well.
Personally, I would just grab some Meguiars Ultimate Compound and their Swirl-X. It's a decent combination (IMO) to have on hand for any future issues that may arise. .....and if you can swing it, you might even want to get some Scratch-X (the abrasiveness of this product would be about in the middle of the other two). Each of those products are basically Bubba-proof and work rather well by hand or DA. I would say UC is milder than other "compounds" but still effective. However, it still requires a follow-up with a lighter finishing polish IME (especially when used by hand).
As jxkim mentioned.... when in doubt, start with the least abrasive method and move up from there.
Old 08-25-2011, 11:24 AM   #21
jxkim
Member#: 239150
2003 WRX Sedan
i pretty much only have had to use meguiars UC and swirl X. i believe compound is more abrasive than the UC.
Old 08-25-2011, 07:08 PM   #22
Kean
Member#: 25187
'08 Foz Prem TGM
….yeah. As with most things on this subject it’s all relative considering terms like “compound” and “polish” cover a myriad of products all with different characteristics of their own. Compare UC to some of the “can of rocks” you might find on some store shelves and there is a huge difference. Personally, I have used it on several occasions and find it fits well in between my M205 and M105. …..in fact, I find myself grabbing for the UC more often than the 105. I was actually really surprised how well it finished via DA the first time I used it. ….although I would still use a finishing polish.
Old 08-31-2011, 11:25 AM   #23
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Scratch-X or Meguires u.c. Just used the Meguires this weekend. You'll be fine. Just wax afterwards. I used a terry cloth towel, but a micro fiber would probably work better. Good luck! By the way, thanks for your service. RP
drivin blind is offline   Reply With Quote
Old 08-31-2011, 10:39 PM   #24
Subbie Dude
Member#: 292940
I have some small scratches also, I used the rubbing compond. Do I know use the touch up paint sticks you get at dealer to go over scratches, and then use rubbing compound again and wax?
Subbie Dude is offline   Reply With Quote
Old 09-07-2011, 11:05 AM   #25
lordgrinz
Member#: 293423
2011 WRX Limited 5dr
WRB SPT/Stock
The best stuff you will ever use, 3M Perfect-It II....Fine cut.....make sure to use a microfiber when using this, you'll be happy with the results.
Amazon.com: 3M Perfect-It II Liquid Rubbing Compound, 16 oz Bottle: AutomotiveAmazon.com: 3M Perfect-It II Liquid Rubbing Compound, 16 oz Bottle: Automotive
lordgrinz is offline   Reply With Quote
Any tips on removing hours worth of rain out of you car 03twrx Interior & Exterior Modification 32 08-22-2011 12:11 AM
Any tips on removing oil stains from driveways? Snowphun New England Impreza Club Forum -- NESIC 8 10-24-2003 08:15 PM
Any tips to remove headlights on the XT? BrysImpreza Forester Forum 4 10-16-2003 01:41 PM
any tips on removing mileage sticker on window? garie Interior & Exterior Modification 9 08-04-2003 05:54 PM
Any tips for removing Door Panels ? ludecrous Car Audio, Video & Security 9 02-12-2003 06:16 PM
