Old 08-16-2011, 11:39 PM   #1
Kitty93
Member#: 260210
Default Speedo and Turbo Talk.
My speedo recently crapped the bed. Which put my ECU in to limp mode. At the same time the heater core blew. So I took this as an opportunity to get a robs tune, does anybody know if a more modern speedo fits a 93 WRX?
And my car has a TD04 on it. And I want to revert back to a TD05. The only TD05 I can find locally forsale is off of an Eagle Talon. Are they the same? Will it fit my car. Feel nooby asking. But you know. Lol.
Thanks!
Kitty93 is offline   Reply With Quote
Old 08-17-2011, 02:13 AM   #2
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Won't fit.
You can use any speedo cable (ie. early Legacy etc) will fit transmission side and cluster side as long as you use the complete cable (I believe early WRX have a split cable).
Marnix is offline   Reply With Quote
Old 08-17-2011, 08:45 AM   #3
luka
Member#: 194742
1993 Impreza WRX JDM
Kitty,
the bolt pattern is different on the exhaust housing/collector between subaru/mitsu even thought they're essentially the same turbos (14b, 16g, b16g, 18g, 20g, etc). Subaru is 5 bolt exhaust housing & 3 bolt collector (up pipe). mitsu is 4 bolt exhaust housing and 4 bolt collector.
also in some cases the mitsu TD04/5's have a 2 bolt flange welded on the end of the compressor housing for a "J-pipe". so just be careful what you're buying
luka is offline   Reply With Quote
Old 08-17-2011, 12:37 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
Where are you located? I have a TD05H from a v2 STi that is for sale...
Also you should be able to use any mechanical speedo cable for an impreza or early legacy
elislider is offline   Reply With Quote
Old 08-17-2011, 06:43 PM   #5
Kitty93
Member#: 260210
Awesome thanks for all the help guys! I guess I'll have the speedo fixed sooner than I expected.
I'm located in Calgary. How much are you selling the turbo for?
Speedo and Tach losing power Hagwag02 Factory 2.0L Turbo Powertrain 3 08-17-2004 07:37 PM
Anyway to Switch Speedo and Tach gauge? Devilchrist Interior & Exterior Modification 9 09-15-2002 10:38 PM
broken speedo after turbo install KillerTHC Normally Aspirated with bolt-on Forced Induction Powertrain 9 06-04-2002 05:05 PM
How do you Recalibrate the Speedo and Odo? MY99 2.5GT Brakes, Steering & Suspension 3 07-15-2001 05:50 PM
Message Board Statistics All times are GMT -4. The time now is 09:33 AM.
