Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 08-17-2011, 12:22 PM   #1
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Default Ej20g chip but what about 20k??
Know there are options besides stand alone for a 20g such as chip from rob... But what about a 20k ecu?? Is there anything out there for this besides stand alone??
peanutswagon is offline   Reply With Quote
Old 08-17-2011, 12:36 PM   #2
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
rob mentioned getting into tuning the v3/4 ECUs but i dont know if all of them are possible. I think the benefit of the EJ20G ECUs is they have an empty or swappable chip socket, so it can be easily taken out and modified. idk if all/any of the 20K ECUs support this
elislider is offline   Reply With Quote
Old 08-17-2011, 01:10 PM   #3
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Yea I had talked to him a couple times he ordered a v3/4 ecu and will let me know what's up soon. Or I can re pin everything for the 20g and get a chip. A lot of work I am stil doing my harness
Old 08-19-2011, 06:39 AM   #4
pmugabi
Member#: 280926
Re-pinning is not that much work surprisingly. It took me only about 4 hours to do the conversion from EJ20K ECU to EJ20G ECU, this was with one hour or so wasted before I learned how to remove the pins quickly. After that, all that's left is wiring the ignitor and then swapping two pins on the throttle body sensor. Plus I also rewired the main relay ON signal to the ignition switch because of a tiny wiring difference on the two versions. So at most 6 hours all told.
pmugabi is offline   Reply With Quote
Old 08-19-2011, 06:53 AM   #5
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
That's not bad. If I do decide to do it I have the diagrams and I'll ask you whats up I I get stuck
We all know about celeb look-a-likes, but what about sound-a-likes? Hamsterstyle Off-Topic 21 03-17-2010 07:21 PM
HID's look great but what about my corners??? Qbushido Interior & Exterior Modification 8 11-14-2002 03:03 PM
I know WRX heads will bolt to a 2.5, but what about a older 2.2? vwluv10338 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-07-2002 02:23 PM
No Southeast Club, but what about club stickers? JasonRan South East Region Forum 1 03-03-2002 11:00 AM
Debadgeing is common. But what about Re-Badgeing? Snoopy General Forum Archive 10 02-20-2001 12:23 AM
