Old 08-17-2011, 02:17 PM   #1
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Default Dumb question...
Can you take an n/a computer and flash it to run a turbo motor somehow??
peanutswagon is offline   Reply With Quote
Old 08-17-2011, 03:30 PM   #2
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Can who? Can you personally? If you have to ask most likely not.
Odds are if your are refering to a pre-96 n/a ssm1 ecu you want to "flash" and put into a pre-96 ssm1 factory turbo then signs point to no. I doubt your local subaru dealer could help you with this either.
I dont even think Rob "flashes" ecu's. I believe that he uses a ROM burner and rechips ECU's (opens them up and puts in new chips).
For 96 or newer with OBD2/SSM2; It seems like it might be possible but I personally dont know.
Hope that helps
TommyAtomic is offline   Reply With Quote
Old 08-17-2011, 03:32 PM   #3
RallyColtTurbo
Member#: 16819
Most likely not, because the extra inputs for MAP (and such), as well as extra outputs for boost control (and such) are not present.
If your just talking about fuel and timing, then it is likley - if the knowledge exists. Most of the Subaru know-how is about the turbo ECUs.
RallyColtTurbo is offline   Reply With Quote
Old 08-17-2011, 03:41 PM   #4
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Ok thanks for the info guys. I have had a 1996 jdm turbo motor run of a 98 usdm n/a ecu. Just very rough and rich. Timing was completely off. Ran rough until boost. But it was just a thought... Interesting
Old 08-17-2011, 04:01 PM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
was the NA ecu from sohc or dohc?
Old 08-17-2011, 04:29 PM   #6
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Dohc motor
Looking for dumb answer to a dumb question (HD DVD related) L Bo Off-Topic 15 05-09-2007 11:42 PM
A few Dumb Questions, but still Questions... ScubyMedic Normally Aspirated Powertrain 7 06-08-2006 10:39 AM
Dumb question about strut compatibility... Velocity Legacy Forum 10 09-15-2000 08:26 AM
Dumb question - Why not an "i club"? DoctorMoo North West Impreza Club Forum -- NWIC 2 04-12-2000 10:33 AM
PARDON THIS DUMB QUESTION ... BUT .... Penni Canada Region Forum 1 02-26-2000 08:06 PM
