Old 08-17-2011, 04:06 PM   #1
rbriggs2
Member#: 242678
2005 Legacy
Pearl White
Default HELP!!! Low Idle 05 Legacy 2.5i
So I have had my Legacy for about 3 years now and it has run fine up until about 6 months ago when the CEL came on. I took it to Autozone and they ran the computer and said the airflow sensor was out. I bought a new airflow sensor took it to a local car place and they replaced it. When I got it back from them, the idle was running way low and every time I come to a stop the idle chugs down almost to zero (doesn't stall but gets close) and then goes back up and continues the process until I start accelerating again. I have noticed that other year Subarus get the IACV gunked up and it can be helped by cleaning could this be my problem?
rbriggs2 is offline   Reply With Quote
Old 08-17-2011, 05:43 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
airflow sensor.
You mean front 02 sensor?
If so - did you get an OEM sensor or some aftermarket junker?
Do you have a CEL now?
IF SO - what is your CEL Code ?
Old 08-17-2011, 05:58 PM   #3
rbriggs2
Member#: 242678
2005 Legacy
Pearl White
the front O2 sensor is referred to as the air flow sensor/meter so yes it is an O2 sensor.
The CEL is not currently on as soon as the sensor was replaced it turned off. As far as what type of sensor I got it was one of the higher end OEM's not sure the part number but I shopped around.
Old 08-17-2011, 07:27 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
your symptoms are spot on for a bad 02 Sensor
if you did not get the correct OEM part, it may just be failing again.
You should probably check your paperwork and make sure you have a genuine subaru part, not some aftermarket "equivalent".....
Old 12-23-2012, 11:21 PM   #5
Tom400CFI
Member#: 240903
92 Corvette
Red
Are we talking the O2 sensor here? or the MAF Sensor?
I have a car ('05 Outback) that has the same symptom (super low idle), but doesn't surge...it just idles wicked low. So low I worry about the oil pressure! Anyway, clarification on the above would be cool. Thanks.
Tom400CFI is offline   Reply With Quote
05 Legacy 2.5i Subaaaru Member's Car Gallery 2 03-03-2007 06:43 PM
05 Legacy 2.5i Notyab Private 'Wanted' Classifieds 0 08-11-2006 10:03 PM
Rotor help 05 Legacy 2.5i Fabius Brakes, Steering & Suspension 1 10-12-2005 01:41 PM
Just got an 05 legacy 2.5i (bl) XanTium Legacy Forum 1 04-03-2005 04:10 AM
05 Legacy 2.5i Review Diabolical1 CC News & Rumors 6 10-27-2004 01:42 PM
