Old 02-27-2012, 02:00 PM   #26
lokey
Member Sales Rating: (1)
Member#: 261622
2011 E85 WRX Ltd 5dr
I have the GS AOS on my car, and now I'm wondering how well it's really working. What type of clear hose/tubing would be safe to use? Could you post a link? I called Grimmspeed, and they said that they used Gates (pic on their site: http://www.grimmspeed.com/catalog/pr...roducts_id=191 ), but I can't find it on the internet anywhere! I found plenty of 1/2" and 3/4" silicone hose, but from what I understand, using silicone is a big no-no for oil and fuel. Thanks!
lokey is offline   Reply With Quote
Old 02-27-2012, 02:26 PM   #27
monkiboy
Member Sales Rating: (34)
Member#: 202958
2008 wrx
I've always used Watts clear nylon braided hose from home depot or Lowes without ill consequence. if you want, you can get nicer stuff from Pegasus.
monkiboy is offline   Reply With Quote
Old 02-27-2012, 02:48 PM   #28
lokey
Member#: 261622
Old 02-27-2012, 11:01 PM   #29
Si1ver&B1acK
Member Sales Rating: (5)
Member#: 250668
2008 STI - (Silver)
06 Forester (Black)
I ran a similar AOS that mounted to the oil cap. I had a Cyl4 ring land failure after 2 sessions at VIR. Rebuilt engine, same AOS but added a single catch can. Cracked ring land after 1 track event (15-20% leak down in 2 cylinders). I also had to drain 1/2 quart of oil from the catch can after every session. Drove 2 more track events then Cyl1 ring land failure. Rebuild 3rd motor with forged internals with same AOS and 2 catch cans. This worked, but still had to drain 1/2 quart of oil out of the catch cans after every session. 4 events later I switched to a single Moroso AOS. 1 oz of waste oil (very liquid) after each session.
My opinion:
4) AOS which sits on top of the oil cap. The AOS on the oil cap works for WOT straight pulls (blow by) but not for high G turns (oil slosh)
3) stock PCV- better than #4
2) Moroso, Element, or Crawford system works for high G track conditions.
1) Dry sump plus #2 (Element) is what I'm soon to test!
Si1ver&B1acK is offline   Reply With Quote
Old 02-29-2012, 04:03 AM   #30
vinz0r
Member#: 154112
08 STi
Element Tuning's Dry sump? That thing looks monstrous. Thanks for the review. Will be getting a Crawford AOS most likely.
vinz0r is offline   Reply With Quote
Old 02-29-2012, 04:44 PM   #31
Si1ver&B1acK
Member#: 250668
2008 STI - (Silver)
06 Forester (Black)
Yep, I will be putting Element's dry sump, AOS, and Hydra to the test very soon.
Old 02-29-2012, 05:54 PM   #32
04.SPT.WRX
Member Sales Rating: (4)
Member#: 69568
2004 WRX Sedan
Same here. Keeps the I/C clean, but is everything else OK?
04.SPT.WRX is offline   Reply With Quote
Old 02-29-2012, 06:23 PM   #33
Supraru
Member#: 23313
99' 2.5Rs
black
Last time I had my intercooler off there was a decent amount of oil in there. Not something to be crazy worried about but enough to peak my interest. I'll be going with a crawford unit soon.
Supraru is offline   Reply With Quote
Old 03-01-2012, 08:27 AM   #34
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
Hey lokey and bill
Sinister7 is offline   Reply With Quote
Old 03-01-2012, 07:16 PM   #35
lokey
Member#: 261622
Hey! (just visiting) :-)
Old 03-12-2012, 08:27 PM   #36
shadowpr
Member Sales Rating: (25)
Member#: 273800
2009 WRX
grimmspeed have any updates on their second version? I already have their aos, but am now thinking about switching over.
time to do more research.
shadowpr is offline   Reply With Quote
Old 03-18-2012, 01:07 PM   #37
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
interesting stuff. Would really like to see grimmspeed solve this issue because they make great stuff but the crawford AOS is on my list for now
Cr4ckfi3nd is offline   Reply With Quote
Old 03-19-2012, 06:47 PM   #38
04.SPT.WRX
Member#: 69568
2004 WRX Sedan
I received the PM excerpts below, here on 3/2 & 3/5. For those of us who have purchased the AOS this is not exactly want we'd want to read.
I suggested "I think it best if you were to mention the high G cornering issue in the description of the AOS on your web site".
As of 3/19 they have not.
On 3/2:
"There are some issue with the aos but over all it's benefits out weigh the cons, at least in our eyes. We find that the aos is perfectly suited for a DD that's looking to get the most out of the motor. This may not, however, be the case for a car that sees a lot of high g cornering or track days. Oil is able to go back up the oil fill tube and over run the aos with oil. We are working on a revision that will be better suited for the track but don't have any updates or release dates as of yet. People who have run this strictly on a daily driver have had amazing results!"
The I/C on my WRX is indeed oil free since the addition of the AOS, so for a DD it works as stated.
On 3/5:
"I auto crossed my old wrx with our aos and didn't run into any issues. The big problem seems to be on long sweeping corners where the oil has an extended period of time to ride of the walls. If you're at all concerned you could run a back up catch can on the return line or remove it for the event".
Back up catch can? Lots of long sweepers where I have autox'd in the past.
Old 03-19-2012, 06:59 PM   #39
Supraru
Member#: 23313
99' 2.5Rs
black
I was tired of being embarrassed puffing smokes at start up leaving car meets. People laugh. I'm all for grimmspeed stuff and they have the best customer service but unfortunately this product wasn't acceptable to me. Purchased a crawford unit and have had zero issues. No more pointing and laughing.
If anyone is interested in buying my grimmspeed let me know. The basic hoses are gone since I didn't wanna run my lines over everything.
Old 03-19-2012, 07:06 PM   #40
Jubert39
Member Sales Rating: (55)
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
random question- for those running the crawford, do you NEED to remove the cruise control thingy on the passenger side strut tower to use the crawford unit?
Jubert39 is offline   Reply With Quote
Old 03-20-2012, 06:45 PM   #41
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
I'll more than likely be going for the crawford when I build the engine. I have the GS right now
Old 03-21-2012, 12:49 AM   #42
azn2nr
Member Sales Rating: (23)
Member#: 35276
just wanna put my 2 cents into this thread
first off i dont have any first hand experience with the grimmspeed. one of my friends has a prova aos similar to the grimspeed on his sti and a crawford on his race car.
my car was smoking on startup pretty bad. after the car misbehaving (low on boost) one night i drove the car pretty hard for about 30 minutes to data log it and to try to find consistency.
the next morning it smoked for 10 minutes before it stopped and i was freaking out. the engine builder told me nothing was wrong with the motor and to get an aos (i didnt even have a catch can) but to stay away from the oil cap style as it probably would be insufficent for my power level (430 on 91)
i purchased the crawford timc aos even though i have a front mount because the gimick/ebay/txs piping comes very close to the firewall in the middle.
the install went perfect. it was self explanatory without detailed instructions and came with nearly everything. the only thing that could have been better was if the inlet nipple cap was smaller but we made it work. some people may prefer instructions and those can be found online.
since ive had it on the car has not smoked once. ive beaten the hell out of it daily since i got it just to make sure to put as much potential stress on it as possible. i took alot of oil out of my piping and intercooler so its possible that it could take time to build up to the point that it smokes everywhere but i seriously doubt it.
im going to a track day on saturday and im more excited to start my car the day after than i am to go to the track day. just to see if it will smoke after being beaten for 2+ hours.
ill also be checking if oil consumption goes down.
azn2nr is offline   Reply With Quote
Old 03-23-2012, 06:21 PM   #43
shadowpr
Member#: 273800
2009 WRX
how was it switching over? was it complicated? (I can't remmber what i did when i installed the gs one)
please keep us updated
Old 03-23-2012, 06:29 PM   #44
Supraru
Member#: 23313
99' 2.5Rs
black
There was just a tiny bit of a challenge since I had my gs lines run behind and under my top mount so it didn't look like a bunch of hoses over my intake manifold. Had to get them out first. Then since I didn't have any pcv stuff anyway I had to come up with a couple different hoses to make it work and run the way I wanted. At some point I'll probably get some more hose and run it more cleanly but I was just trying to bang out the job quickly and correctly after work one day.
Old 03-24-2012, 09:33 AM   #45
shadowpr
Member#: 273800
2009 WRX
do you have any pics? It might be helpful for guys like me that will be changing setups.
Old 03-25-2012, 08:43 AM   #46
Supraru
Member#: 23313
99' 2.5Rs
black
The downloaded instructions were extremely easy to follow and if you still get confused there's an install vid on youtube that's nice to watch before as well.
Old 03-28-2012, 01:53 AM   #47
azn2nr
Member#: 35276
update: track day done. almost no consumption at the track at all. no smoking the next day either. car is running smooth as silk.
Old 04-01-2012, 06:45 PM   #48
WRBWRX04
Member#: 274804
2004 WRX
Unhappy just bought the grimmspeed AOS
Just bought the grimmspeed aos for my dd. I dont ever autox im thinking ill go with the clear hose. test it out . maybe return it.
WRBWRX04 is offline   Reply With Quote
Old 04-13-2012, 05:09 PM   #49
04.SPT.WRX
Member#: 69568
2004 WRX Sedan
I just ordered the Crawford. I want to get a track day in this season and a few autox events as well. I've lost confidence in the GS for that.
Old 04-13-2012, 06:17 PM   #50
Supraru
Member#: 23313
99' 2.5Rs
black
I wouldn't go that far. They still make good stuff, this just wasn't what I needed for my car. Plus their customer service is second to none.
FS: Crawford AOS for TMIC - Brand New jordanretro1223 Engine/Power/Exhaust 19 09-25-2011 07:36 PM
Crawford AOS, ARP studs, Grimmspeed, JDM STi Spec C 12L WATER TANKS in STOCK!! IA Performance Engine/Power/Exhaust 8 04-24-2011 04:04 PM
FS (SC): Crawford AOS - New rubberman Engine/Power/Exhaust 4 02-18-2010 08:55 AM
FS: Used Crawford AOS - FMIC version kuldud VIC Private Classifieds 8 01-18-2010 11:32 AM
Cobb vs Hawk pads - reviews/ opinions? Jeenyus Brakes, Steering & Suspension 7 06-22-2008 12:45 AM
