Old 09-24-2012, 09:00 AM   #76
themaus
Member Sales Rating: (5)
Member#: 321211
Originally Posted by Crawford Performance View Post
We have been tossing around the idea of doing a V3 with a PCV in the system. Is there enough interest in this upgrade for us to build it?
What would be the advantage of that?
themaus is offline   Reply With Quote
Old 09-24-2012, 09:21 AM   #77
mert34
Member#: 183598
2013 Evo
PB
Im curious as well as i was about to order the v2 sometime soon
mert34 is offline   Reply With Quote
Old 09-24-2012, 10:37 AM   #78
Vendor Sales Rating: (2)
Member#: 42075
The only advantage would be for smog reasons, the system would still function the same but the OEM PCV valve would still be in place. Our V2 gets vacuum from the intake which creates Positive Crankcase Ventilation.
Team Crawford
__________________
Home to Ken Blocks Gymkhana 1 and Gymkhana 2
Home to the worlds fastest new age Subaru WRX STI
Follow us on
Crawford Performance is offline   Reply With Quote
Old 09-25-2012, 03:32 AM   #79
'08WRXRider
Member#: 276361
I would be interested in the V3 you mentioned. Especially, if it had CARB EO. Even if it doesn't, though, still interested.
'08WRXRider is offline   Reply With Quote
Old 09-25-2012, 10:33 AM   #80
Member#: 42075
Good idea.
__________________
Follow us on
Old 09-25-2012, 03:52 PM   #81
Meeners
Member#: 314898
I'm sorry, but you guys all kill me with this nonsense. You are spending hundreds of dollars trying to do what nissan and volvo have been doing stock for years. If you have a street car you can just buy a stock oil seperator from any AWD/RWD turbo sr20 powered vehicle aside from the VE version (it is steel with an internal baffle), or find a separator from a n/a or turbo volvo s70 or 850 etc (ABS). These are cars that both are turbocharged and both have separators that drain to the crankcase stock and have been since before a lot of the people on this site were born.
If you are paranoid about condensation back into the block then just bolt the catch can to the block like they do in BOTH case scenarios. I've done that for years on regular catch cans. And you can find them for $15, or buy them OEM from any dealer for $40-50.
Stock Oil Separator Examples
If you are worried about draining back contaminated oil, don't... because you aren't running a vented system. it's closed. If you vent it to the atmosphere then yes, drain it to a can.
Even if you are a racer, understand that they have been doing this for higher performance engines that your life depends on for a number of years... i.e. PLANES. Do a search on oil separators from Aircraft Spruce... its the same concept.
I'm not crapping on these aftermarket products because they are providing a service and a material that there obviously is a need for, especially if you are into racing your vehicles but some of you people need to think outside the box or better yet, think for yourselves instead of just going by what others say.
However, I highly appreciate the hands on approach to show others how the products work... that is what forums need more of. kudos OP.
Meeners is offline   Reply With Quote
Old 09-25-2012, 09:51 PM   #82
Member#: 42075
This is our BRZ specific AOS
__________________
Follow us on
Old 09-26-2012, 04:46 AM   #83
luvless2620
Member Sales Rating: (43)
Member#: 190566
Looks nice. Can't wait to see it on the online store shelves.
luvless2620 is offline   Reply With Quote
Old 09-26-2012, 09:58 AM   #84
Member#: 42075
RallySport Direct is having a group by on our BRZ
AOS at the moment
__________________
Follow us on
Old 09-27-2012, 04:03 PM   #85
04.SPT.WRX
Member Sales Rating: (4)
Member#: 69568
2004 WRX Sedan
Crawford Team - no comment on my lack of hardware commentary?
Seeing as I just installed the V2, no thanks.
Smog reasons? Please elaborate ...
04.SPT.WRX is offline   Reply With Quote
Old 09-27-2012, 05:25 PM   #86
Acejam2k
Member Sales Rating: (23)
Member#: 42645
2007 STI BrenTuned
Crystal Gray Metallic
The PCV valve is considered an emissions device. Therefore, it's illegal to remove it on cars registered in the US. This does not depend on local/state laws. It's a federally mandated EPA law.
Acejam2k is offline   Reply With Quote
Old 09-29-2012, 08:57 PM   #87
04.SPT.WRX
Member#: 69568
2004 WRX Sedan
Ah, thank you. Same goes for my aftermarket catalytic converter.
Old 10-26-2012, 08:07 PM   #88
neg_matnik
Member Sales Rating: (9)
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S --> my DD
The problem is, even if the crankcase valve is left alone, the hose coming out of the valve will be tampered with and routed to some non-OEM device. That's possibly a visual inspection failure in California (and probably other states as well).
So, unless Crawford is willing to spend time and money to obtain a smog exemption (and its associated EO number) for their AOS, they shouldn't even bother.
neg_matnik is offline   Reply With Quote
Old 10-26-2012, 09:13 PM   #89
BlackedOut04
Member Sales Rating: (11)
Member#: 149468
2004 STi
Well would ya look at that.
BlackedOut04 is offline   Reply With Quote
Old 10-29-2012, 08:56 PM   #90
iSTI
Member#: 241769
thanks for the writeup ive had the gsaos for about 2 years now, but imma install clear lines now to check how its holding up.
iSTI is offline   Reply With Quote
Old 11-02-2012, 06:18 AM   #91
lokey
Member#: 261622
2011 E85 WRX Ltd 5dr
I did a clear line on my gs aos (just the vent hose) to verify. It's working.
lokey is offline   Reply With Quote
Old 02-20-2013, 01:44 PM   #92
SATSTI
Member#: 341814
2013 STI
Snap. There IS a downside to this! I was thinking of getting one of these but if it's going to be a hassle when I get the car inspected nevermind.
SATSTI is offline   Reply With Quote
Old 02-20-2013, 05:08 PM   #93
0BlueSTi4
Member#: 98955
2011 WRX Hatch
It is a downside but that is where shady/hole-in-the-wall smog shops come in - somehow I doubt those guys know which hose goes where - just don't take it to Subaru specialists
0BlueSTi4 is offline   Reply With Quote
Old 02-21-2013, 02:39 AM   #94
dsca1993
Member Sales Rating: (1)
Member#: 228367
05 impreza 2.5 rs
regal blue pearl
I have used the Grimmspeed one in my 2005 wrx for a few months now daily driving and some cases of "spirited" driving and it worked perfectly. I went to button willow raceway and it failed.. didn't do a thing. So I'm going to replace it.. unfortunately I can't use the Crawford one since I have a fmic and a tower bar. Has anyone heard anything about the Moroso one? Or any others?
Thanks
-Daniel
dsca1993 is offline   Reply With Quote
Old 02-24-2013, 12:44 PM   #95
SubieEngineer
Member Sales Rating: (39)
Member#: 208152
2007 STI LTD #576
Urban Gray Metallic
Thanks
-Daniel
I know a guy that tracks his 08 STI and his Forester and he uses a Crawford in his 08 (IIRC) and the Moroso dual catch can setup in the Fozy. He likes both of them. I personally used the Grimmspeed clone for about 2 months and noticed all the oil that still would up in the return line (especially at an autocross) and ditched it in favor of a Crawford V2 AOS.
SubieEngineer is offline   Reply With Quote
Old 02-24-2013, 02:07 PM   #96
Acejam2k
Member#: 42645
2007 STI BrenTuned
Thanks
-Daniel
I have a big ETS TMIC and a strut brace, and I can fit my Crawford TMIC AOS.
They make a FMIC version too, which I believe sits even lower.
Old 02-24-2013, 03:16 PM   #97
dsca1993
Member#: 228367
05 impreza 2.5 rs
regal blue pearl
Can you post or pm me a picture?
Old 02-24-2013, 03:45 PM   #98
Acejam2k
Member#: 42645
2007 STI BrenTuned
Of my setup? Or their FMIC version?
Old 02-24-2013, 10:41 PM   #99
dsca1993
Member#: 228367
05 impreza 2.5 rs
regal blue pearl
Of your set up
Old 02-24-2013, 11:55 PM   #100
Acejam2k
Member#: 42645
2007 STI BrenTuned
Of your set up
Here's the best close-up shot that I could find:
For reference, I have a Whiteline "Big TMIC" strut brace and an ETS TMIC. The AOS has about 2-3mm clearance below the strut brace. It doesn't rub at static, but under chasis flex it might touch, so I've wrapped part of the top AOS nipple with some black electrical tape to prevent any scrapes on the fancy black paint.
FS: Crawford AOS for TMIC - Brand New jordanretro1223 Engine/Power/Exhaust 19 09-25-2011 07:36 PM
Crawford AOS, ARP studs, Grimmspeed, JDM STi Spec C 12L WATER TANKS in STOCK!! IA Performance Engine/Power/Exhaust 8 04-24-2011 04:04 PM
FS (SC): Crawford AOS - New rubberman Engine/Power/Exhaust 4 02-18-2010 08:55 AM
FS: Used Crawford AOS - FMIC version kuldud VIC Private Classifieds 8 01-18-2010 11:32 AM
Cobb vs Hawk pads - reviews/ opinions? Jeenyus Brakes, Steering & Suspension 7 06-22-2008 12:45 AM
Message Board Statistics All times are GMT -4. The time now is 09:48 PM.
