Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 02-25-2013, 01:31 AM   #101
SubieEngineer
Member Sales Rating: (47)
Member#: 208152
2007 STI LTD #576
UGM, 09 NB 528i
^ Do you not have the AOS plumbed back into the inlet? Or is this temporary to monitor blow-by...?
I, too have the ETS TMIC and the Crawford, but with a custom bracket made by the shop that built my motor. No clearance issues, but no FSTB, either.
SubieEngineer is offline   Reply With Quote
Old 02-25-2013, 08:31 AM   #102
Acejam2k
Member Sales Rating: (25)
Member#: 42645
2014 Audi S4
Brilliant Black
Good catch. This pic was of my old motor, and I was simply monitoring blow-by that got past the AOS temporarily. Driving this kind of configuration on the street would be impossible for me as it absolutely smells awful. (Very strong oil vapor fumes)
I'm also ruining an AMR Inlet now too.
Acejam2k is offline   Reply With Quote
Old 02-25-2013, 12:37 PM   #103
monkiboy
Member Sales Rating: (34)
Member#: 202958
2008 wrx
i have an 08 wrx with the crawford v2 FMIC version installed at the dog-bone, with the cusco front bar and the vent line to the right fender with air filter. no fitment issues or rubbing. there's definitely ways to get it done with just a bit of effort.
i also never have the "very strong oil vapor fumes". this is on a high-hp setup but perhaps adding that filter at the end would help you if you have a desire for that design setup/eliminating the opportunity for blow-by to enter the intact tract.
monkiboy is offline   Reply With Quote
Old 02-25-2013, 12:45 PM   #104
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Stick that hose in your engine bay like I did with no filter and I guarantee you'll smell it at idle. The fender liners will vent the air reasonably well to the sides of the car, hence the lack of smell. I only ran this temporarily because I wanted to see if anything was getting past the AOS. Nothing did - my bottle was clear with just a tiny bit of water vapor. (It was cold out)
Old 02-25-2013, 12:54 PM   #105
Crawford Performance
Vendor Sales Rating: (2)
Member#: 42075
Yea, the smell of the crankcase when at a stop is nasty! Glad to hear the results from your test were good
Team Crawford
__________________
Home to Ken Blocks Gymkhana 1 and Gymkhana 2
Home to the worlds fastest new age Subaru WRX STI
Follow us on
Crawford Performance is offline   Reply With Quote
Old 02-25-2013, 02:36 PM   #106
amp0412
Member Sales Rating: (19)
Member#: 179330
05 LGT Wgn
400whp PriceRocket
Mine finally showed up in the mail today and will be getting installed in a few weeks when I am ripping into my engine bay again. I bought the tmic aplication for 02-07 sti's and am looking forward to installing it along side of my rotated 3076 and spearco top mount. I will update with photo's.
-Gary
amp0412 is offline   Reply With Quote
Old 02-25-2013, 02:41 PM   #107
monkiboy
Member#: 202958
2008 wrx
i think you misunderstood because i did not specify clear enough. it does not sit IN the fender rather ON the fender in the engine bay. really mounted to the strut tower. i guess from your comments, the small filter at the end of my setup, really does allow me to avoid those noxious fumes. here's a photo of its location to further describe what i'm talking about.
Old 02-25-2013, 04:40 PM   #108
P-Train
Member#: 279233
2008 WRX
Maybe I'm not understanding the working of this completely, but wouldn't you need to have that top hose connected to the intake duct still and not just a filter? Is there enough crankcase pressure to move the air through this thing fast enough to separate the oil without the extra suction from the intake? Since it's suppose to use centrifugal force and all to separate the oil from the air. Also I was wondering if you keep the PCV valve or if the AOS causes any codes to be thrown?
P-Train is offline   Reply With Quote
Old 02-26-2013, 06:45 PM   #109
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, 09 NB 528i
Gotcha. I haven't logged into IWSTI much in the last month, been making some changes, non-car-related.
I get the oil vapor smell even with the clean air return plumbed back into the inlet. I can smell it if I'm standing behind the car at idle. After having the AOS installed for a few thousand miles, I took my ETS TMIC off to wire some gauges, and while it was 95% dry (save the slightest of shinyness at the bottom of the TB coupler area), it absolutely reeked of oil when I put my head within 1' of the outlet.
Old 02-26-2013, 06:57 PM   #110
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
That makes sense - oil "vapor/air that smells like oil still makes its way through the motor and back into the inlet. If there's a strong smell though when the car is running, then you might have a leak.
Old 02-26-2013, 07:06 PM   #111
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, 09 NB 528i
Oil level is consistent when not pushing the car hard (like at a track day), so not sure where I'd have a leak. Can't smell anything under the hood while running, it's out the exhaust. I think I've read of others experiencing the oil vapor smell, I just need to read up on it a bit.
Old 02-26-2013, 07:20 PM   #112
Member#: 42075
If you are smelling it in the exhaust then you are burning oil in the combustion chamber which is exiting out the back of your car. This is common for a high mileage motor or one that is very loose for what ever reason. If the oil is going into your turbo faster than its draining out the bottom then that could cause the smell as well, this usually happens with rotated turbos that do not have a proper restrictor in the oil feed line.
__________________
Follow us on
Old 02-27-2013, 12:08 AM   #113
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, 09 NB 528i
Gotcha. Yeah, I figure I'm burning some off slightly. It's a TopSpeed RR.5 motor with looser tolerances than stock, and they told me to expect some light consumption. I have yet to do a full interval without some type of autocross/track driving, so I haven't been able to get a good idea as to use. Turbo is a Blouch 1.5 XTR with a TMIC.
Old 02-27-2013, 12:16 AM   #114
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I didn't realize the leak you mentioned was from behind the car. By "leak" I meant one of the AOS lines in the engine bay being loose, causing a funky smell to seep into the cabin. (such as venting the top hose to atmosphere in my picture)
I also recently pulled my TMIC - it definitely smelled, but it was bone dry.
Old 02-27-2013, 12:23 PM   #115
Member#: 42075
There's your answer then... Rock on!
Team Crawford
__________________
Follow us on
Old 02-27-2013, 12:25 PM   #116
Member#: 42075
It's good to hear that our AOS is doing it's job! Thanks for the positive feedback.
Team Crawford
__________________
Follow us on
Old 02-27-2013, 09:27 PM   #117
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, 09 NB 528i
Yeah, coming out the exhaust. No leaks under the hood (that I'm aware of...).
Team Crawford
That's why I never worried about it. I expect some consumption with the looser tolerances, but just no idea how much since I haven't been able to really measure it. Just wasn't expecting the oil vapor odor out the back end. Thanks for the feedback!
Old 02-27-2013, 11:04 PM   #118
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I hate to say it, but in my opinion if you can smell oil coming out of the tailpipe, something isn't right.
Old 02-28-2013, 01:07 AM   #119
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, 09 NB 528i
Normally I'd agree with you, but I'm not burning any really noticeable amount of oil, and I've done 7 track days with this motor, using roughly 1/2-1 qt per day. Unless it starts creeping up to something excessive, I think I'm good. *crosses fingers and does a little dance*
Old 03-21-2013, 08:13 AM   #120
RallySoob
Member#: 74872
2006 STi
White/Black
I am so glad I did not buy the grimspeed AOS for my new 18Gxt sti build. I think I will do catch can(s) instead.
Which is the very best catch can system people? or is there an AOS that actually works. Should I just get the crawford and call it good?
RallySoob is offline   Reply With Quote
Old 03-21-2013, 09:44 AM   #121
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
It may be pricey, but the Crawford V2 AOS does work. I chose the Crawford on my setup so I don't have to worry about emptying catch cans.
Old 03-21-2013, 10:07 AM   #122
Member#: 42075
Thanks for the support Acejam2k... it's customers like you that have made us who we are today!
Team Crawford
__________________
Follow us on
Old 11-10-2013, 01:01 PM   #123
d3rock
Member#: 313194
2011 WRX GV
Great write up! Thanks for your pics and reviews. I've been debating between exactly these two (along with the new Perrin AOS) as I too DD the car, but am leaning towards tracking a lot more.
This thread was super helpful.
d3rock is offline   Reply With Quote
Old 05-09-2015, 11:19 PM   #124
gsprophecy
Member#: 285677
sorry to revive an old thread. We're looking to get a AOS for our 2015 STI.
Two questions if people don't mind:
1. We've also been looking at the Perrin set up compared to the crawford set up. Do they function the same way or not so much?
2. Is there a concern when recycling the oil back into the crank case as opposed to catching the oil in a can to be emptied?
I drive a Direct Injection GTI and our notion is that catch cans work better than putting the crap back into the crank case, obviously requiring more driver maintenance to empty the can regularly. I'm not too knowledgeable about Subaru motors. Seems like Crawford is the way to go.
Thanks!
gsprophecy is offline   Reply With Quote
Old 05-09-2015, 11:38 PM   #125
Junior2JZ
Member Sales Rating: (13)
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Thanks!
IAG makes the best AOS you cab purchase. I had the Crawford on my 15 at one point and was completely put off by its constant spitting oil from the breather and milky crap it drained back into my motor. Switch to the IAG and haven't looked back. 0 problems with milky substance and not a drop of oil shot out of the vent.
Junior2JZ is offline   Reply With Quote
FS: Crawford AOS for TMIC - Brand New jordanretro1223 Engine/Power/Exhaust 19 09-25-2011 07:36 PM
Crawford AOS, ARP studs, Grimmspeed, JDM STi Spec C 12L WATER TANKS in STOCK!! IA Performance Engine/Power/Exhaust 8 04-24-2011 04:04 PM
FS (SC): Crawford AOS - New rubberman Engine/Power/Exhaust 4 02-18-2010 08:55 AM
FS: Used Crawford AOS - FMIC version kuldud VIC Private Classifieds 8 01-18-2010 11:32 AM
Cobb vs Hawk pads - reviews/ opinions? Jeenyus Brakes, Steering & Suspension 7 06-22-2008 12:45 AM
