Old 08-18-2011, 01:26 PM   #1
bradg1166
Member#: 280700
2005 WRX C70
PMS
Default boost/ boost target
on the AP under the monitor menu you can select boost or boost target. what is the difference? why does one read higher than the other?
bradg1166 is offline   Reply With Quote
Old 08-18-2011, 02:29 PM   #2
Cobb Tuning
Member#: 4803
"Boost" is the actual "boost" based on the car's manifold pressure sensor. "Boost Target" is the target (at sea level) that the engine control unit (ECU) is attempting to hit.
You will not hit your target at all times - it is dependent on many factors.
Bill
Old 08-18-2011, 04:15 PM   #3
bradg1166
Member#: 280700
2005 WRX C70
PMS
i guess i am still not fully understandng. i am running stage 2 right now, it says in the notes on the cobb website that i should hit target boost of 16.5 +\- .7 and currently hitting 16.2. but when i go to monitor "boost" its much lower (cant remember exactly but it think it was around 11 or 12) so that is the acutal amount of boost my turbo/ car is putting out and 16.2 is what it is trying to hit or it is hitting 16.2?
Old 08-18-2011, 04:24 PM   #4
fenix-silver
Member#: 231700
2004 WRX Wagon
Keep in mind that your boost tapers off towards redline, probably towards 11-12 psi.
fenix-silver is offline   Reply With Quote
Old 08-19-2011, 08:59 AM   #5
Cobb Tuning
Member#: 4803
"Boost" is your actual boost. The boost target will vary based primarily on RPM and throttle position and is determined by the map. The "boost target" is like the bullseye, while the "boost" is where the dart actually hits.
You will not always hit your boost target, but to make sure you are hitting within the range dictated by your map at peak boost, do a data log of a 3rd gear wide open throttle run from around 2500 RPM to near redline (if you can do so safely and assuming you have the version 2 AccessPORT). Make sure you reset the data log list to the default.
Here's a general video on how to data log with the v2 AccessPORT:
Bill
Old 08-19-2011, 03:09 PM   #6
bradg1166
Member#: 280700
2005 WRX C70
PMS
ok thank you Bill for clearing that up for me. that is what i assumed but wanted to be sure
Not hitting target boost, boost drops off FlaT FouR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-25-2010 03:56 AM
Boost? Boost? Boost? 02Subiwrx-mac Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-17-2010 06:58 AM
Wanted: TD05-16g (small) boost/fuel target tables Geek Guy Open Source Reflashes 10 12-29-2009 07:40 PM
Boost overshooting target. MasterKwan Commercial ECU Reflashes 8 10-24-2007 11:22 PM
boost, Boost, BOOST!! MBX Motorsports Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-15-2001 11:12 AM
