Old 08-18-2011, 10:15 PM   #1
wrx904
Member#: 97365
2015 Mustang PP SC
Default Log with Fine Knock Learn?
https://spreadsheets.google.com/spre...I2ZVE&hl=en_US
Here is my log. This was a 3rd gear pull. I have offer logs and have been seeing about the same fine knock learn around the same rpm range. Is this okay or is there a problem? The map that I am running is a eTune. Thanks
Power Mods:
Perrin TBE with high flow cat
Perrin CAI
Perrin inlet hose
Perrin TMIC
Grimmspeed P&P headers and uppipe
wrx904 is offline   Reply With Quote
Old 08-20-2011, 09:07 AM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Power Mods:
Perrin CAI
Perrin inlet hose
Perrin TMIC
I dont think you should be seeing knock in back to back cells like that during a WOT run. I was told by Cobb that seeing some feedback knock or fine knock learn when mashing the pedal or shifting is normal, and seeing knock correction at WOT could indicate a problem.
Edit: Looking at it again I would say something is up because FKLC goes from -.7 to -5.6 which would indicate several knock events occurring in a row. I would see if you can have a revision done.
2Fast4U1DAY is offline   Reply With Quote
Old 08-22-2011, 10:42 PM   #3
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
I'd be interested to hear Cobb's response to this...free bump
Phil_Dunphy is offline   Reply With Quote
Old 08-23-2011, 09:57 AM   #4
Cobb Tuning
Member#: 4803
You don't want to see that large of a correction (-5.6), especially at high load. I would make sure you don't have anything in the engine bay that is loose/rattling that may be picked up by the knock sensor. Since this is an etune, you should get with your tuner.
Bill
Old 08-23-2011, 12:10 PM   #5
Tripintaz
Member#: 245218
2013 STI Limited
Personally I think you are running a little too much timing for a heat soak prone TMIC and are probably a little lean in that area.
For what its worth, I would target a 11.3-11.1 AFR and a 2 degrees less timing than you currently have.
Tripintaz is offline   Reply With Quote
Old 08-24-2011, 11:10 PM   #6
wrx904
Member#: 97365
2015 Mustang PP SC
Thank everyone for the replies. I decided to go with a new tuner and now everything is good. Thanks to a eTune from Torqued Performance. The other eTune was a waste of money but a learning experience. However, I do wish that Cobb Tuning was in Tampa, FL.
feedback knock and fine knock learning??? please explain. dudenhoeffer02wrx AccessPort 6 06-21-2016 12:10 PM
i am getting the same fine knock learn at the same rpm everytime? dudenhoeffer02wrx Newbies & FAQs 2 08-08-2011 01:39 AM
constant fine knock learn? olazy AccessPort 5 05-24-2011 11:53 AM
Fine Knock Learning in ATR Tripintaz AccessPort 5 10-01-2010 09:31 AM
Data logging newb: Knock learning vs. Correction Liquidr1 AccessPort 13 03-10-2010 01:42 AM
