Old 08-19-2011, 09:14 AM   #1
PurpleHeartSti
Member#: 283940
2008 Sti
Default 2008 Sti w/ AMR t60r
Event: Initial Tune
Ambient Temp: 85-90
Elevation: Sea level?
Weather: Partly Cloudy & Humid
Car: 2008 Sti
Tuner: Randy w/ National Speed
Dyno Info: Dynojet
Transmission: ACT Prolite FW, ACT Clutch
Gear: 3rd
Peak HP at RPM: 360awhp @ ~6,400
Peak Torque at RPM: 322awtq @ ~ 5,300
Baseline hp/tq for a stock on same dyno: ~270/~260
Target Boost: 19.4psi
Target AFR: 12.0
Fuel: 93 octane
Engine/Power Modifications: AMR T60r, 1000cc DW's, Perrin FMIC, Turbo xs 3'' DP w/ 3'' cut-out, Perrin Cat-back, AP Fuel Rails, CAI.
Still to go on: AP Headers, Build Shortblock, cams.
Other Modifications: Sways, Top Strut, Oil Baffle, Bushings, other little shenanigans.
Headers were put on back order and i was tired of the break in tune. These numbers come on STOCK headers and we also ran out of time. Looking for ~400whp until the block gets in there.
REMEMBER: We ran out of time for the day, so this is just the first graph of many to come (as you can see still have some to work out)
Thanks for looking!
EDIT: New graph, forgot about this thread and forgot to update. Still stock block and stock cams. 19lbs, not 21.5.
PurpleHeartSti is offline   Reply With Quote
Old 08-19-2011, 10:32 AM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
12.0 AFR on pump even with a FMIC is aggressive. Whats with everyone buying AMR T60s?
Nice setup Op
juanmedina is online now   Reply With Quote
Old 08-19-2011, 10:49 AM   #3
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
Nice setup Op
seems like alot of people have been posting up about them latley..i got mine bc mikey and i did a straight trade for the vf39
BONFIRE074 is offline   Reply With Quote
Old 08-19-2011, 11:10 AM   #4
PurpleHeartSti
Member#: 283940
2008 Sti
I did mine because i've never had a problem with amr and had a considerable amount of parts on an 04 wrx..
also, the AFR will get straightened out. it's mostly between 10 and 12 on the graph though.
cant wait for headers and what not
Old 08-19-2011, 11:28 AM   #5
Arthrogrian19
Member#: 155466
2008 Stg III+ FSXT
Aside from the AFRs, your dyno graph looks exactly like mine, except I'm running a 4eat. What are your IDCs at WOT? It looks like there's plenty of headroom in your build if you choose to turn up the boost.
Arthrogrian19 is offline   Reply With Quote
Old 08-19-2011, 11:34 AM   #6
PurpleHeartSti
Member#: 283940
2008 Sti
definitely room.. I mean, stock headers, block, and cams right now.. Once i can get a shortblock in and some cams i can take it into the 400's. just have to get there first
Old 08-20-2011, 01:35 AM   #7
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
Nice numbers man! Yeah thats good for just a short while on the dyno. I like this turbo, i have one on the way right now! For the price with a 3in inlet,8cm hot side, coated and fully ported with oil line and coolant line too all for 1380.00 isnt bad at all, beter deal than the HTA Green id say, and spool the same with more top end. Im running E85 full time too, that should wake the t60r up!
20wrx05 is offline   Reply With Quote
Old 08-20-2011, 05:38 AM   #8
Rodimusprime49
Member#: 160454
06' WRX 20g Twin
Scroll e85 fed!
Definately agree with this. A lot of people buying this turbo and posting great numbers. Anybody reach 450 hp/tq with e85 on a Dynojet with this turbo?? With supporting mods of course
Rodimusprime49 is offline   Reply With Quote
Old 08-20-2011, 11:50 AM   #9
killichnakropf
Member#: 244879
2006 STI stage 2
Needs a 20g
Am I the only one wondering why your not make power till 5000 rpm? Those numbers don't seem much higher than what can be accomplished on the stock turbo with your modifications. And power would be made much sooner and with a decent power band. No offense just my two cents.
killichnakropf is offline   Reply With Quote
Old 08-20-2011, 12:26 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Nice setup Op
12 measured at the tail pipe /=/ 12 measured in the downpipe
its not as lean as it appears.
jorge at P&L used to post up 12:1 plots all the time.
Old 08-20-2011, 04:14 PM   #11
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
This post caught my interest. What would a 10.6afr at the tailpipe mean? Slighlty richer?
achavez is offline   Reply With Quote
Old 08-20-2011, 05:09 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
Yesss
Old 08-20-2011, 05:26 PM   #13
JRSRED10
Member#: 57292
2008 STi
WhiteNGold
I have 440/440 on mustang or something like that power wise at 20-21 psi with 2 cats on e85. Still changing some things and going back to finish tune. I really can't wait to see the guys who were talking about pushing this turbo to try and get 500 and run em in 1/4.
And you can find vendors selling this turbo for 1200 new.
JRSRED10 is offline   Reply With Quote
Old 08-20-2011, 07:11 PM   #14
SubieFiesta
Member#: 149426
2002 Subaru WRX
2005 Subaru STi & 2000 RS
440/440 is crazy on a mustang dyno! Especially with 2 cats. Takes those cats out and you can easily hit 460+whp with the T60R
SubieFiesta is offline   Reply With Quote
Old 08-21-2011, 06:40 AM   #15
JRSRED10
Member#: 57292
2008 STi
WhiteNGold
Whoops.. I was wrong. Torque on my sheet is only 415. I have no doubt 450 is prob a few pounds of boost away on e85 for most people's setups though.
Old 08-21-2011, 01:05 PM   #16
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
+1
Even with stock headers and an unfinished tune the curve looks like that of a 35r but with the power of a 20g. and 19psi isn't exactly low enough for the turbo to be nowhere near its efficiency range unless this turbo likes insane boost levels.
Unless of course the timing/avcs/boost tables are completely untouched down low so far and its running on spring pressure or something to that effect.
VladiWrX is offline   Reply With Quote
Old 08-22-2011, 04:46 PM   #17
PurpleHeartSti
Member#: 283940
2008 Sti
as i said it was a very rough "powertune" under a short amount of time. Basically the headers were on back order and the initial plan was to tune when i got those, but i got too impatient...
once i get the headers on we will go in and clean some stuff up and hopefully start seeing better/sooner results. Im also sort of taking it easy on the stock block. i figure have 2 blocks that are good just in case one breaks is better than having one break and needing a new one
Old 01-15-2012, 12:06 AM   #18
janderson13
Member#: 306735
2004 WRX STi
Im running a T60 here soon, built block and stock heads. AMR un-equal lengths, there pro series 2.5'' upipe. and of course all the other supporting mods, injectors, catless downpipe blah blah blah. From what Im reading 400whp is possible with this turbo around 20psi?
janderson13 is offline   Reply With Quote
Old 01-15-2012, 12:08 AM   #19
janderson13
Member#: 306735
2004 WRX STi
This seems like a high reading dyno as well, Im going to be tuned on tpg tunings dyno, and if Im correct its a heartbreaker.
Old 01-15-2012, 12:36 AM   #20
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
This is my graph built 2.5 motor less cams 91 octane,, and a dyno jet on 22 PSI.
*6STARS* is offline   Reply With Quote
Old 01-15-2012, 02:10 PM   #21
tfcinc1
Member#: 204084
08 sti
black
I made 350/350 at 23psi on EFI mustang dyno. Built block, el header all the supporting mods stock heads/cams.
tfcinc1 is offline   Reply With Quote
Old 01-15-2012, 02:20 PM   #22
shutupnshift04
Member#: 101710
BOSS
that thing didn't hit boost till almost 5 grand and made basically 16g power..almost picked up one of these turbos a week ago very happy i didn't. if they made this turbo in a dbb version i guarantee they would be a lot more popular
shutupnshift04 is offline   Reply With Quote
Old 01-15-2012, 05:15 PM   #23
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
thats a worst dyno i ever seen
Bariga is offline   Reply With Quote
Old 01-15-2012, 09:06 PM   #24
PurpleHeartSti
Member#: 283940
2008 Sti
^ that's the worst sentence i've ever seen, thanks for the bump though
forgot to update, but here:
Old 01-15-2012, 09:07 PM   #25
PurpleHeartSti
Member#: 283940
2008 Sti
^also, not 21.49psi.. we had to use a 100lb sensor because the 50 wasn't working. I am at 19lbs. This all came with just headers and cleaning it up.
David's 2008 STi - AMR S1 (Stage 1) TRACK RESULTS! AMR Proven Power Bragging 38 08-18-2009 10:13 PM
2007 Subaru STi - AMR T60R / AMR TMIC / 93 Octane / More.... AMR Proven Power Bragging 17 01-29-2009 12:19 PM
2008 Subaru STi - AMR Race FMIC / AMR T60R / AMR Direct Port Meth / 25psi @ 3800rpm AMR Proven Power Bragging 16 11-11-2008 10:35 PM
2006 Subaru STi - AMR T60R Bolt-On Laying down the POWER!!!! (double the factory HP!) AMR Proven Power Bragging 18 08-26-2008 09:53 AM
