Old 08-19-2011, 12:44 PM   #1
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Default PSA: Stop resetting your ECU
This is a public service announcement for all of you out there who think that resetting the ECU is a logical debugging step when you encounter a problem with your car.
It's Not
Resetting the ECU is NEVER a valid response to a problem. It will never fix the problem, it will never give you insight into the problem, it will do NOTHING but hide the problem for a few miles before it comes right back, or it could even make the problem much worse than it was before.
There are VERY FEW situations in which resetting the ECU could be considered a logical move. These include:
1) AFTER tracking down, and FIXING a problem with your car (IE: bad O2 sensor, vacuum leak, etc), it's a good idea to reset the ECU to clear all of the learned parameters (which it learned while there was a problem) so that it can start from scratch.
2) After changing the octane of the fuel your car is running, either higher or lower. If you're raising the octane, resetting the ECU will clear out the timing changes the ECU had to make to compensate for the low octane, and allow you to take advantage of the higher octane sooner. If you're lowering the octane, resetting the ECU will put it into an active knock learning mode, which will let it adjust for knock quicker than if you just left the ECU alone. Note that if you're lowering the octane, do NOT, under ANY circumstances, perform the "vishnu" trick after resetting the ECU.
3) After making a major part change on your car and flashing a new tune to suit. Now most tuning methods will reset all of the learned parameters when you flash the new map on the ECU anyway, so in this case, the reset is already taken care of for you.
There might be a couple others, but not many.
Here are a few situations in which you should NOT reset the ECU:
1) Your gas mileage has dropped and the car is not running as well as before - resetting the ECU will do absolutely nothing but erase all evidence of what could have been causing the problem, and the problem WILL come back
2) The ECU has thrown a check engine light - If it's an important CEL it WILL come back, and if it's not an important CEL it will disappear ON ITS OWN after just a few key cycles.
3) The engine is running rough and/or misfiring - Like #1, resetting the ECU will do nothing but erase all evidence of what was causing the problem, and the problem WILL come back
4) The car is stalling - See #1 and #3 above
5) The boost is not hitting target (either high or low) - There are no learned boost control values like there are for fueling and timing that could be zero'd out with an ECU reset. There is only the on/off switch from DAM/IAM. If your ECU has completely disabled boost control due to excessive knock, resetting the ECU will set the DAM/IAM back to its default value, which will temporarily restore boost control. This is a BAD thing though, because there's a reason the ECU deemed it necessary to cut off boost...it detected excessive knock and determined that the engine was in danger. You don't want to bypass this safety feature, you need to find and fix whatever is causing the excessive knock.
And many, many others.
The basic rule of thumb is that unless you've recently made a major change to your car that will affect its operating conditions (either fueling or knock-related), AND it's your intention to clear out the old learned parameters to give the ECU a "fresh slate" so-to-speak, you should never reset the ECU.
Sorry about the rant, I've just seen way too many threads recently where the owner encountered a problem with their car, and their first reaction was to reset the ECU. This will ALWAYS either make the problem worse, or do nothing at all. It will NEVER fix the problem, and it will erase all evidence of what was causing the problem, making troubleshooting next to impossible.
Old 08-19-2011, 12:46 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Thank you for this. I wish more people would understand this. Simply turning of the CEL does not fix the problem!
Old 08-19-2011, 12:54 PM   #3
taosracer
Member#: 131108
2002 TS/WRX wagon
Blue ridge pearl
Good advice. Nothing more irritating than trying to fix a car and having to put many drive cycles on it to get it to throw the DTC again !
Having just moved from Colorado to New England, and seeing how that has affected my car's boost levels and performance, I think that making a major altitude change would also be a valid reason to do a reset.
Thanks
taosracer is offline   Reply With Quote
Old 08-19-2011, 01:35 PM   #4
Meiki
Member#: 289311
2011 Subaru WRX STi
How do you even reset ECU? Sorry for stupid question.
Meiki is offline   Reply With Quote
Old 08-19-2011, 01:40 PM   #5
teesutt
Member#: 127940
Evil shenanigans
pull negative battery terminal, press brake pedal, reconnect neg terminal, start car. Or a reflash.
teesutt is offline   Reply With Quote
Old 08-19-2011, 01:42 PM   #6
dpbacon
Member#: 241511
2010 WRX Premium
Dark Grey
Remove the battery terminal and press the brake peddle a few times to bleed the system of any remaining electrical charge.
dpbacon is offline   Reply With Quote
Old 08-19-2011, 01:42 PM   #7
Member#: 51961
2005 STi
2012 WRX
An altitude change shouldn't have an effect on anything that would be changed with an ECU reset. There are no learned boost parameters, so resetting the ECU will not affect boost, and any knock or fueling corrections that were learned at altitude should still be valid at sea level, so a reset shouldn't be necessary.
Disconnect the battery for a few minutes, or you can use a tactrix cable or an accessport to reset it through software.
edit: hah, little late to the party on that one
Old 08-19-2011, 02:07 PM   #8
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Curious, does an ECM reset also dump the OBD monitor ratios back to zero? I guess it might be similar to performing a clear CEL message.
Originally Posted by the suicidal eggroll View Post
It resets everything. All learned parameters, including fueling adjustments, timing adjustments (knock correction), idle throttle plate position, as well as CELs/DTCs are cleared. It will reset the IAM back to 0.5, cutting your timing advance in half and robbing the car of 10+ whp, and it will also throw the ECU into a "not ready" state, which means you can't pass emissions until you drive for ~100 miles. Is this what you're asking?
Yes, thanks that is what I was looking for. I was sure on the other items you listed. But I have never compared the monitor ratios or as you called them the ECM's "not ready" state. I just did not want to assume anything.
JarHarms is offline   Reply With Quote
Old 08-19-2011, 02:21 PM   #9
Member#: 51961
2005 STi
2012 WRX
Old 08-19-2011, 02:38 PM   #10
Raptor89
Member#: 285405
2013 WRX Hatch
What about a reset after having to unplug the MAF to change the passenger blinker bulb, which causes the CEL and TCS lights to illuminate, and the Cruise Control to blink and not work? Obviously there's nothing wrong (other than the common faulty blinker bulb), as the car had less than 3,000 miles on it. Is a reset in that situation okay?
Raptor89 is offline   Reply With Quote
Old 08-19-2011, 03:28 PM   #11
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Ecu reset is never a bad thing when you mod your car, ie finish installing a turbo inlet and resetting ecu as unabomber mentions in all his faq's. Not only a major part change.
drewvdw is offline   Reply With Quote
Old 08-19-2011, 04:18 PM   #12
Member#: 51961
2005 STi
2012 WRX
I've unplugged my MAF many times for one reason or another, and it's never set off a CEL (it will if the engine is running at the time, but it shouldn't make any difference if the key is off). Is this a quirk in the newer ECUs?
Completely unnecessary to reset the ECU after a turbo inlet install, you won't gain a single thing by it. If you really want to, knock yourself out. This post is more about people resetting the ECU to fix a problem they're having.
Old 08-19-2011, 04:36 PM   #13
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Thank
XanRules is offline   Reply With Quote
Old 08-19-2011, 04:59 PM   #14
fredtga
Member#: 156274
2002 WRX Wagon
so, let's say i have a subaru that i'm using only for about 2-3 times a month... track day, rally event you name it, but it is not daily driver...
is it bad to disconnect the battery every time i have it parked ? the battery is a small one and if i leave it connected on the car for about a week, it would barely rotate the engine for start...
fredtga is offline   Reply With Quote
Old 08-19-2011, 05:11 PM   #15
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
battery tender or something similar, you lose some performance by doing so (vishnu reset can correct this)
Old 08-19-2011, 06:08 PM   #16
Member#: 51961
2005 STi
2012 WRX
You could disconnect it, just remember that your car will never be operating properly, since you'll be eternally driving in "learning" mode with reduced timing.
The better option would probably be to just hook it up to a trickle charger every couple of days to keep it full.
Old 08-19-2011, 09:49 PM   #17
Matt08WRX
Member#: 169656
2008 WRX 4DR
SSM 331hp/362tq MPS tune
brb going to reset ecu
Great post
Matt08WRX is offline   Reply With Quote
Old 08-20-2011, 02:29 AM   #18
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^i actually did just reset my ecu...stupid tiny wastegate i can't wait until i can get my ewg on and tuned, so far off though need intercooler, fuel pump, and injectors...
Old 08-20-2011, 12:18 PM   #19
cmiovino
Member#: 134005
2004 WRX Premium
I agree with this. I haven't reset my ECU in 2 years since I got the car.
Old 08-20-2011, 01:16 PM   #20
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Did you try to start the car with the MAF unplugged? If so, reset.
Otherwise..umm..unplugging the MAF while the car is off shouldnt throw a CEL.
Old 08-20-2011, 01:50 PM   #21
SilvrBullit
Member#: 288937
2007 WRX TR
I don't understand why a person would assume that this would help solve anything. Seems to do more bad than good
SilvrBullit is offline   Reply With Quote
Old 08-20-2011, 01:52 PM   #22
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
This applies for at least half of the "advice" spewed around here..
Old 08-20-2011, 09:59 PM   #23
Raptor89
Member#: 285405
2013 WRX Hatch
Now that I think back, I did turn the key on while everything was still detached to test the turn signal and make sure it was fixed and stopped blinking fast...that must've been it. Next time I do anything I'll make sure to leave everything off until I am 100% done. Thanks for the replies!
Old 06-13-2013, 12:46 PM   #24
DieselOx
Member#: 334906
NEVER is a strong word.
4) If you drove like a grandma for the first 100 miles in a new OB, and the ECM then can't handle how you drive after that.
I reset mine (actually a recall reflashed it), and my stumbling idle and throttle dead zone was GONE immediately. I drove like I stole it for the next 100 miles, it's been great for the last 10k miles.
Anyway, what I'm really looking for is confirmation that the ECM in Gen4 OB's, both CVT and manual transmissions, have some learning of driver's habits, fuel trim, timing, anything. There's a lot of talk all over the place, but I can't find any documentation. Maybe if you Impreza folks have documentation for this, it could lead to OB documentation.
Just grasping at straws here, been all over the OB forums looking for stuff about it.
Thanks.
DieselOx is offline   Reply With Quote
Old 06-13-2013, 01:02 PM   #25
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
I reset my ECU because a police car was following me. It worked because when I got done with the reset, the police car was no longer following me.
You know how your lights blink on and off when you reset your ecu? eurojax Off-Topic 7 01-17-2006 08:15 AM
Installing Intake, did you reset your ECU? BLCK DVL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-08-2002 12:06 PM
Why reset your ECU when not doing mods? I am b Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-26-2002 05:10 PM
How do you reset your ECU IcedOutRS Newbies & FAQs 10 03-27-2001 04:41 PM
How often do you reset your ECU? Gambit Normally Aspirated Powertrain 17 10-26-2000 02:57 PM
