Welcome to the North American Subaru Impreza Owners Club Wednesday November 26, 2014
Old 08-19-2011, 08:42 PM   #1
cheapfreerider
Member#: 152985
2006 wrx wagon
wrb
Have a Nice Day? tiny hesitation at 4500 rpm & lil' shaky idle
hey ap gurus i've been trying to hunt down a problem with a slight rough idle and newly discovered tiny hiccup sometimes at 4500 rpm. wondered if someone could take a look at my ap log to see if anything weird is noticeable?
https://spreadsheets.google.com/spre...ZnSEE&hl=en_US
map is cobb ots stg 1.
no mods except perrin inlet tube.
recently changed spark plugs and fuel filter with no effect.
no change between stock map and cobb ots stg 1
shop said they are pretty certain it's the tune but it does it even w/ stock map so i think it's something else (coil pack, injector?)
cheapfreerider is offline   Reply With Quote
Old 08-24-2011, 10:09 PM   #2
cheapfreerider
Member#: 152985
2006 wrx wagon
wrb
just did a compression test - 125,130,123,131 - cold motor. car has 33k miles
what next, injectors? or do i let a shop tune it. if they tune it and it doesn't fix the shaky idle or hesitation at 4500 do i still have to pay them? lol
Old 08-24-2011, 11:58 PM   #3
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
How about you take that inlet tube off since none of the OTS maps support it and neither does the stock tune... Otherwise yes, you will HAVE to have it tuned in order to get rid of your issue.
2Fast4U1DAY is offline   Reply With Quote
Old 08-25-2011, 01:38 AM   #4
cheapfreerider
Member#: 152985
2006 wrx wagon
wrb
the idle issue existed before the perrin inlet tube as well... 100% stock it still idled funky and no change after any mods. that's why i don't think it's a tuning issue...
Old 08-25-2011, 06:55 AM   #5
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Check Plugs, Coils, Fuel pressure, Compression, and Compression leakdown. If it was idling funky when stock theres a mechanical issue somewhere...
Old 09-08-2011, 12:07 AM   #6
cheapfreerider
Member#: 152985
2006 wrx wagon
wrb
that's what I'm thinking too 2fast. just swapped coil packs and no change. do you think I should bother with sending the injectors in for test & cleaning? that was going to be my next step.
runs the same with either maf or o2 sensor (or both) unplugged... ruling those two items out.
Old 09-08-2011, 05:52 PM   #7
Cobb Tuning
Member#: 4803
A more likely scenario is a post-MAF intake leak. I would do a good bit of driving on one map (without changing maps or resetting the ECU) and then check your A/F Learning 1 A, B, C, D values. These are your long-term fuel trims and if you have a post-MAF leak, bad MAF, or bad front o2, you will generally see more extreme long-term fuel trims (well outside of +/- 5%). However, it takes some cruise-type driving for these to be learned since they are cleared when you reflash a map or reset the ECU.
Bill
Old 09-11-2011, 09:55 PM   #8
cheapfreerider
Member#: 152985
2006 wrx wagon
wrb
thanks a million for the info Bill, I will for sure monitor this and post the findings. I wonder if it could be a small intake manifold gasket leak.
boost cut at 4500 rpm??? warui111 AccessPort 0 01-23-2007 07:05 AM
CEL!! no idea why. fuel cut at 4500 rpm :( supermoose Subaru Conversions 16 09-13-2005 04:41 PM
Bouncing at 4500 rpms after 2.5 sti block swap DJIMPREZA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-01-2004 11:56 PM
Hesitation at 4500 rpm HKS_Impreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-18-2003 03:01 PM
Wrx Missing At 4500 Rpm WRX'R X Newbies & FAQs 2 11-14-2001 03:57 PM
