Old 08-19-2011, 10:04 PM   #1
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Here's what we tested:
Stock 07 STI
Sheet Metal V1 (I was told this was a Magnus V1 but Magnus never replied to my photo and email)
EJ25 SOHC Big Plenum Short Runner
EJ25 SOHC Big Plenum Long Runner
EJ25 SOHC Big Plenum Long Runner Modified For Reversed Setup
Forsa "Rear Entry" Manifold
Cosworth Cast Intake Manifold
EJ25 SOHC Big Plenum Short Runner ASF Porting Stage 0.5
Plastic not quite so fantastic Manifold
EJ25 SOHC Bigger Plenum Monstrosity with ASF Porting & 75mm TB
Procedure & Equipment: Superflow SF-110, tested @ 7" and corrected to 28", 4" Plexiglas bore fixture with small Plexi sheet adapter sealed to the fixture with an OE Subaru steel & rubber o ring intake gasket. Holes, non tested runners and nipples plugged with rubber plugs, tape and modeling clay. Tested with no velocity stack or throttle body; ie: open throttle flange. Stock STI , Magnus Sheet Metal & Cosworth used a topfeed TGV delete, short runner NA used it's own injector riser and the Forsa is a one piece design.
All tests that were denoted as done with a throttle body were done with a 60mm DBW partially gutted and wired WOT.
Intake manifold, cylinder head intake runner & throttle body as a system test, here:
http://forums.nasioc.com/forums/show...&postcount=140
Code:
Stock 07 STI
Runner 1 284 CFM
Runner 2 280 CFM
Runner 3 280 CFM
Runner 4 274 CFM
Average 279.5 CFM
Runner to runner max variation 10 CFM or 3.6%
Code:
Stock 07 STI w/ TB
Runner 1 303 CFM
Runner 2 304 CFM
Runner 3 306 CFM
Runner 4 299 CFM
Average 303 CFM
Runner to runner max variation 10 CFM or 2.3%
Code:
Sheet Metal
Runner 1 314 CFM
Runner 2 301 CFM
Runner 3 264 CFM
Runner 4 273 CFM
Average 288 CFM
Runner to runner max variation 50 CFM or 16%
Code:
Runner 1 306 CFM
Runner 2 303 CFM
Runner 3 303 CFM
Runner 4 306 CFM
Average 304.5 CFM
Runner to runner max variation 3 CFM or 1%
Code:
Runner 1 304 CFM
Runner 2 304 CFM
Runner 3 304 CFM
Runner 4 300 CFM
Average 303 CFM
Runner to runner max variation 4 CFM or 1.4%
Code:
 Modified EJ25 SOHC Big Plenum Long Runner
 Runner 1 314 CFM
 Runner 2 303 CFM
 Runner 3 308 CFM
 Runner 4 314 CFM
 Average 309.75 CFM
 Runner to runner max variation 11 CFM or 3.5%
Code:
Forsa Industries Rear Entry Sheet Metal Manifold
 Runner 1 329 CFM
 Runner 2 326 CFM
 Runner 3 314 CFM
 Runner 4 295 CFM
 Average 316 CFM
 Runner to runner max variation 34 CFM or 10.3%
Notes: One piece runner (ie: no TGV). If there was a radius or pipe
 on the throttle body flange, the number 4 runner wouldn't
 lag behind the others in terms of flow; I tested this by
 simply holding my index finger next to & slightly below
 the throttle flange opening which raised this runner's
 flow to 317 CFM. The close proximity of this runner to
 the open throttle flange makes it a sharp bend.
Code:
Forsa Industries Rear Entry Sheet Metal Manifold with TB
Runner 1 352 CFM
Runner 2 343 CFM
Runner 3 324 CFM
Runner 4 324 CFM
Average 335.75 CFM
Runner to runner max variation 28 CFM or 8.3%
Notes: Having a throttle body did help flow variation here.
Runner 4 was EXTREMELY turbulent, as in turbulent enough
 to make the flow depression bounce 1".
Code:
 Runner 1 303 CFM
 Runner 2 299 CFM
 Runner 3 299 CFM
 Runner 4 314 CFM
 Average 303.75 CFM
 Runner to runner max variation 15 CFM or 4.8%
Code:
Cosworth Cast Intake Manifold with TB
 Runner 1 333 CFM
 Runner 2 318 CFM
 Runner 3 318 CFM
 Runner 4 314 CFM
 Average 320.75 CFM
 Runner to runner max variation 19 CFM or 5.9%
Notes: That is not a typo, runner 4 had no change between
 having a TB and not having one. Oddly, with a throttle body,
 flow variation actually went up
Code:
Runner 1 318 CFM
Runner 2 310 CFM
Runner 3 322 CFM
Runner 4 310 CFM
Average 315 CFM
Runner to runner max variation 12 CFM or 3.7%
Notes: Stage 0.5 consisted of upper runner to lower runner matching,
 partial runner flash removal and EGR pillar removal from the center-bottom
 of the plenum.
Code:
EJ25 SOHC Big Plenum Short Runner ASF Porting Stage 0.5 with TB
Runner 1 354 CFM
Runner 2 354 CFM
Runner 3 337 CFM
Runner 4 331 CFM
Average 344 CFM
Runner to runner max variation 23 CFM or 6.6%
Notes: Flow variation more than doubled with throttle body here.
Code:
Plastic Thing with TB
Runner 1 293 CFM
Runner 2 283 CFM
Runner 3 283 CFM
Runner 4 291 CFM
Average 287.5 CFM
Runner to runner max variation 10 CFM or 3.5%
Code:
EJ25 SOHC Big Modded Plenum Long Runner ASF Monstrosity with 75mm TB
Runner 1 376 CFM
Runner 2 362 CFM
Runner 3 396 CFM
Runner 4 389 CFM
Average 380.75 CFM
Runner to runner max variation 34 CFM or 8.9%
Notes: OMFG. Pic was during setup, so rest easy the
 brake booster nipple was plugged during testing.
Code:
Process West Holy Moly Thing of Beauty
Runner 1 349 CFM
Runner 2 356 CFM
Runner 3 360 CFM
Runner 4 374 CFM
Average 359.75 CFM
Runner to runner max variation 25 CFM or 6.9%
Notes: Large plenum and short runner characteristics
cannot be seen in this test but my hypothesis is that
this could be a candidate for best choice in a big
turbo/big rpm setup.
Thanks to Tyler Williams the rainbow dude & Will @ Elevated Tuning and for their help and to Brian L (RexFTW) for the Process West, Zach (Fate066), Fin @ Forsa and Jordan (MartinSTi05) for the manifolds to test.
ASF Machine is offline   Reply With Quote
Old 08-19-2011, 10:13 PM   #2
fateo66
Member#: 130997
I like what I see!
fateo66 is offline   Reply With Quote
Old 08-19-2011, 10:16 PM   #3
subiewhore
Member#: 138786
05 obp wrs ^.-
rally time
huh, I was wondering what happened to the intake manifold off my car!
subiewhore is offline   Reply With Quote
Old 08-19-2011, 10:25 PM   #4
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Plastic with TB
Short Runner NA with ASF Stage .5
Cossie with TB
Stock STI with TB
Forsa with TB
Old 08-20-2011, 02:22 AM   #5
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I really appreciate you posting these test results. I have always been up in the air about switching to a oem sti manifold or 2.5rs mani. Now I'm just curious on what my ported 03 wrx manifold will flow to see if it would be worth it.
I have had my hands on plenty wrx and sti intake manifold and never really saw any differance besides tb bolt pattern and color.
wrxsubiemod is offline   Reply With Quote
Old 08-20-2011, 02:29 AM   #6
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Runner 1 304 CFM
Runner 2 304 CFM
Runner 3 304 CFM
Runner 4 300 CFM
Average 303 CFM
^This is what I'll be running.
Finally some numbers on a flow bench. The only other manifolds I'd like to see is the Cosworth and the vers 9 jdm long runner which would probably have the same results as any stock sti manifold.
methaddict is offline   Reply With Quote
Old 08-20-2011, 02:30 AM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
....and I have the red one and the short SOHC one in my possession.
FuJi K is online now   Reply With Quote
Old 08-20-2011, 07:17 AM   #8
25rsti
Member#: 166324
Thanks for you contribution. I'm running the long runner sohc manifold and always heard about these characteristics, but never saw the data. Seeing the actual #s makes me feel much better.
Though I do wonder why the other sohc one flows more, the one with the custom change.
Old 08-20-2011, 09:17 AM   #9
MartinSTi05
Member#: 145145
2006 wrx STi
I have a cosworth laying around. If I send it out do you want to test it?
MartinSTi05 is offline   Reply With Quote
Old 08-20-2011, 09:39 AM   #10
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
what model year are theses from?
EJ25 SOHC Big Plenum Short Runner...96-2001?
maxpowr is offline   Reply With Quote
Old 08-20-2011, 10:05 AM   #11
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Martin, send it over and we'll test it.
Max, all of the big plenum SOHC are from newer EJ253s (think 06+), exact years and models I don't know, possibly someone (hey Zach) could chime in with more exact info.
We did this because all we ever heard was speculation without any real data, we didn't expect the big plenum NA manifolds to be so exceptional. We did hypothesize that they would have great runner to runner balance but we had figured they would only marginally outflow the STi and get destroyed by the SMIM. Testing revealed that the SMIM has poor balance, front runners (1&3) vs. back runners (2&4).
I am excited to test a Cossie as this will be great reference point when considering Cosworth's own flow numbers on the stocker when corrected from 50" (421 avg cfm) to 28"(315 avg cfm which is still 12% higher than our findings), the cast Cossie should make 350+ avg cfm on our bench corrected to 28" yet I am guessing somewhere closer to 315 avg cfm.
Old 08-20-2011, 10:35 AM   #12
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Zach modified the plenum on this one, he removed the pillar out of it and put a sloping roof on it in order to move the TB flange down for front entry.
The beauty part is that we think all the big plenum intakes have room for improvement.
Old 08-20-2011, 11:10 AM   #13
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Awesome test, glad to finally see some numbers. I only wish you had a 1 piece V8 Spec C to test. I'm really curious as to what numbers you would get out of one of those.
axelthrasher is offline   Reply With Quote
Old 08-20-2011, 12:53 PM   #14
Back Road Runner
Member#: 60082
2004 Forester STI
Excellent work. This is one thing this site and the Subaru community has been lacking for a LONG time.
It's interesting to see the gross variation of the e-Bay cheapy.
I'm curious, there are quite a few other manifolds out there. Are you guys willing to test more manifolds if people sent them in to you? I'm just thinking of things like old cast versus new plastic NA manifolds, the very large diameter runner Legacy (GT?) manifold, the Cosworth high flow manifold, even some stock manifolds with some porting work (to see if this is worth it, although may be more beneficial attacked to a head and pulled though versus the manifold itself).
I would just love to see more comprehensive data for a lot of the major products out there.
Old 08-20-2011, 01:32 PM   #15
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i agree...the tech section here on nasioc is a little thin...
Old 08-20-2011, 01:32 PM   #16
MartinSTi05
Member#: 145145
2006 wrx STi
I support a hard numbers style of testing. Many loud mouths are quick to condemn any product they don't have any real world experience with. Many think the cissies manifold kills low end etc etc. I sure had a healthy power curve with it, oh wait that's because the rest of my setup was thought out.
This type of testing eliminates many variables that cloud other conclusions people have made. That being said it would be nice to see dynamic testing that could quantify the effects of the runner length, ID, firing order and plenum volume. Maybe a "standard" test Subaru setup...
Old 08-20-2011, 01:38 PM   #17
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
nasioc sponsored? ^^^
Old 08-20-2011, 01:47 PM   #18
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Here's some additional CFM numbers for you guys. I had the OEM JDM V7 EJ207 STi Intake Manifold & TGV's sent out to Extrude Hone and they threw it up on the flow bench before and after the Extrude Hone process. Impressive CFM gains in my opinion considering the expensive aftermarket options that are available.
SuperFlow 1020 Flow Bench @ 28"
Test Pressure @ 29.6 PSI
Temperature during Flow Bench Testing - +78*F
OEM JDM V7 STi EJ207 / After Extrude Hone process ( Difference in CFM from Stock to after Extrude Hone process - )
Runner #1 Before - 263.7 CFM / Runner #1 After - 311.8 CFM ( +48.1 CFM, 18.2% increase )
Runner #2 Before - 274.3 CFM / Runner #2 After - 316.4 CFM ( +42.1 CFM, 15.3% increase )
Runner #3 Before - 272.5 CFM / Runner #3 After - 316.0 CFM ( +43.5 CFM, 15.9% increase )
Runner #4 Before - 269.8 CFM / Runner #4 After - 314.9 CFM ( +45.1 CFM, 16.7% increase )
Ken Sekiguchi
KenSekiguchi is offline   Reply With Quote
Old 08-20-2011, 02:02 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I just wish I had been able to get a flowbench that I was gonna get last fall. It was swiped from under my feet 1 day before I could pick it up
Old 08-20-2011, 02:32 PM   #20
ASF Machine
Member#: 236349
1993 Impreza
OD Green
I'd love to see what someone with access to CFD & wet flow could come up with.
That said, we're not super interested in testing someone's home ported stock WRX manifold and I wouldn't be super excited about even a JDM long runner (I'd probably still do one) as I think we'd find that it's awfully close to a USDM STI.
I have a plastic Leggy XT manifold somewhere that I wanna do and I'd like to maybe test a Cossie, Forsa, Corsa-Veloce, Tomei and maybe a Tomei knockoff.
Old 08-20-2011, 02:36 PM   #21
ASF Machine
Member#: 236349
1993 Impreza
OD Green
I had ideas about building a throttle body flange adapter and flipping the switch on the machine to blow through it but there were two major issues with that plan: 1, no one else's numbers have been done that way and 2, we'd surely run out of capacity on our little machine. I thought it may be a better indicator on a forced induction setup but alas we stuck with the standard procedure.
Old 08-20-2011, 02:48 PM   #22
Mister Tanker
Member#: 237759
2003 WRX Wagon
Built ej205 478whp 417wtq
Id like to see a test of a wrx manifold thats been port matched to the tgv's. I have ported a few of these manifolds and lots of material is removed in the process.
Mister Tanker is offline   Reply With Quote
Old 08-20-2011, 03:12 PM   #23
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
^ I agree, but I really haven't seen a differance between sti and wrx manifolds. The test was performed with tgv deletes and sti mani so id assume a wrx manifold will be very close. I'm sure grimmspeed has some back up flow data from ported to non ported we can look at.
Old 08-20-2011, 03:32 PM   #24
MartinSTi05
Member#: 145145
2006 wrx STi
Unforunately we don't gave access to all the toys we can dream of as a community. However this is one hell of a good start.
Old 08-21-2011, 03:45 PM   #25
subyswamper
Member#: 91049
2008 wrx wgn
charcoal grey
I like this very much!!!! Special thanks to Zach and Margarite for giving up their intakes for testing.
subyswamper is offline   Reply With Quote
Subaru Cylinder Head Flow Database ASF Machine Built Motor Discussion 48 08-23-2015 05:05 PM
best flowing OEM intake manifold Gamble_WRX Built Motor Discussion 20 05-25-2010 09:52 AM
WTB high flow intake manifold and internals modusvivendi Private 'Wanted' Classifieds 2 08-06-2009 11:25 PM
'04 Plastic Intake Manifold Flow Numbers SOLUTION Normally Aspirated Powertrain 1 03-14-2006 08:03 PM
AVO high flow intake manifold aspera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-10-2002 09:58 AM
