Old 08-21-2011, 05:16 PM   #26
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I am super glad you guys did this testing. In the middle of an engine build and it looks like the 2.5 N/A is a great option.
Thanks! and great work.
slowgenius is offline   Reply With Quote
Old 08-21-2011, 05:50 PM   #27
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
curious if you guys did any kind of bellmouth around the opening? I know don't see any in the pics. Just wondering if the necking in the opening might effect some of the cylinder to cylinder flow balancing.
Old 08-21-2011, 06:00 PM   #28
eg33GC
Member#: 206851
56 Belair
Pro Street
needs more ej20G testing
eg33GC is offline   Reply With Quote
Old 08-21-2011, 06:42 PM   #29
DSM_Outback
Member#: 56345
93 Swapped L
Green
It'd be interesting to see an ej20g as it appears to be the closest thing to the wrc manifold from the factory.
But it's still old n crusty
DSM_Outback is offline   Reply With Quote
Old 08-21-2011, 07:06 PM   #30
ASF Machine
Member#: 236349
1993 Impreza
OD Green
No velocity stack of any kind, clay or otherwise. Tried to keep variables down.
*ninja employee/personal login edit.
ASF Machine is offline   Reply With Quote
Old 08-23-2011, 12:03 AM   #31
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
what about testing the plastic legacy and 08+ wrx manifold?
bhhamblin is offline   Reply With Quote
Old 08-23-2011, 12:13 AM   #32
Homemade WRX
Member#: 33782
96 bastard child
I hadn't noticed claying differences (within reason) to cause much variance, especially that far up stream. It simply reduces the pressure necking that you'll have at that flat 90* bend. With the plenum being here, I don't it would have much effect either way...was just curious
Old 08-23-2011, 09:22 AM   #33
Storm
Member#: 5218
96L Most Over-
Developed Beater
Guess I should've worked a little harder on retrofitting the 05+ big plenum/long runner to my motor instead of jumping on the stupid low price of the OBX ITB's....
I have a big plenum/short runner manifold sitting on a shelf if anyone is interested. I'll be keeping the long runner for myself though!
Thanks for the info!!!
Jay
Old 08-23-2011, 12:50 PM   #34
Homemade WRX
Member#: 33782
96 bastard child
OBX made a Tomei knock-off? did you ever slap it on?
Old 08-23-2011, 01:01 PM   #35
DSM_Outback
Member#: 56345
93 Swapped L
Green
$600 on the ebays.
Old 08-23-2011, 01:02 PM   #36
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Nice data! Thanks for this...I'd like to see a retest with some big name manifolds on it...it'd be interesting to see stock vs cossie vs a consistent pnp job like GRIMMSPEED
todeswalzer is offline   Reply With Quote
Old 08-31-2011, 11:35 AM   #37
jiml
Member#: 26479
Any updates? Curious about Cosworth's intake.
jiml is offline   Reply With Quote
Old 08-31-2011, 11:45 AM   #38
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Still making arrangements for round two; being as we're not buying all of the manifolds we're testing, it may take a little bit.
Old 08-31-2011, 03:09 PM   #39
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Any possibility of seeing flow numbers on stock usdm sti ported?
I have a grimmspeed pnp that i may have around for a little while.
How long do you think the turn around would be and would you want to use your TGV deletes. It will be atleast a month before i have a set.
Its suppose to be of 05 USDM STI
bswilmington is offline   Reply With Quote
Old 09-01-2011, 02:30 AM   #40
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
id like to see grimmspeed ported one tested.
Bariga is offline   Reply With Quote
Old 09-01-2011, 11:41 AM   #41
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Regardless of porting the STI and wrx manifold have 0 plenum.
project_skyline is offline   Reply With Quote
Old 09-02-2011, 08:00 AM   #42
ionised
Member#: 136775
2004 Impreza RS
I'd love to see what someone with access to CFD & wet flow could come up with.
That said, we're not super interested in testing someone's home ported stock WRX manifold and I wouldn't be super excited about even a JDM long runner (I'd probably still do one) as I think we'd find that it's awfully close to a USDM STI.
I have a plastic Leggy XT manifold somewhere that I wanna do and I'd like to maybe test a Cossie, Forsa, Corsa-Veloce, Tomei and maybe a Tomei knockoff.
Awesome thread! Will be very interested to see how the plastic manifold goes, fitting one at the moment to my 04 with cable throttle. Lots of screwing around so hopefully it'll perform well...
ionised is offline   Reply With Quote
Old 09-02-2011, 08:31 AM   #43
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Same here, interested
Bad Noodle is offline   Reply With Quote
Old 09-04-2011, 05:44 AM   #44
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
This.
Compare G to K manifolds.
i_c_the_light is offline   Reply With Quote
Old 09-04-2011, 04:39 PM   #45
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
This is an awesome thread. The more hardcore guys can use some of this info to shift their powerbands slightly to the left or right, or add more midrange or topend with choosing long runner short runner right?
achavez is offline   Reply With Quote
Old 09-11-2011, 05:30 PM   #46
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Just picked up a EJ25 SOHC Big Plenum Long Runner. Won't be until next spring, but I will be doing some before and after dyno testing compared to stock sti. Great thread btw. This data pushed me over the edge to change mine.
cnstman is offline   Reply With Quote
Old 09-11-2011, 05:45 PM   #47
Storm
Member#: 5218
96L Most Over-
Developed Beater
I need an address to end the Tomei knockoff setup to....
Jay
Old 09-11-2011, 11:01 PM   #48
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Jay
590 N Westgate DR #A, Grand Junction, CO 81505
Old 09-11-2011, 11:08 PM   #49
B.R.E.D
Member#: 289606
06 WRX
white
Really great info guys, Thanks for a positive contribution to the community.
Looking forward to seeing the Plastic Legacy Manifold and the Cosworth Manifold tested.
Its been my experience that the Legacy Manifold makes more power with virtually no loss down low. It would be nice to see some actual flow numbers.
B.R.E.D is offline   Reply With Quote
Old 09-12-2011, 01:43 AM   #50
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Makes more power then what?
IIRC it has 0 plenum as well so its not going to make any good top end.
Subaru Cylinder Head Flow Database ASF Machine Built Motor Discussion 48 08-23-2015 05:05 PM
best flowing OEM intake manifold Gamble_WRX Built Motor Discussion 20 05-25-2010 09:52 AM
WTB high flow intake manifold and internals modusvivendi Private 'Wanted' Classifieds 2 08-06-2009 11:25 PM
'04 Plastic Intake Manifold Flow Numbers SOLUTION Normally Aspirated Powertrain 1 03-14-2006 08:03 PM
AVO high flow intake manifold aspera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-10-2002 09:58 AM
