Old 10-12-2011, 10:54 AM   #51
jiml
Member#: 26479
Any info, updates, or forthcoming data?
jiml is offline   Reply With Quote
Old 10-12-2011, 07:02 PM   #52
ASF Machine
Member#: 236349
1993 Impreza
OD Green
No one has sent in any manifolds...
ASF Machine is offline   Reply With Quote
Old 10-12-2011, 09:16 PM   #53
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I got a plastic 08+ manifold I can send you guys. What's the easiest way... ups?
Bad Noodle is offline   Reply With Quote
Old 10-12-2011, 09:53 PM   #54
albersondh
Member#: 196882
08 WRX
Oh man I have been watching this post and waiting for this. I have high hopes for the plastic fantastic. I wonder what the insulation is worth in terms of CFM on top of what should be pretty solid flow without casting turbulance?
albersondh is offline   Reply With Quote
Old 10-12-2011, 11:27 PM   #55
AREA1320
Member#: 112508
I have a cossi i can send. But its got a rediculous paint job and cannot be damaged.
AREA1320 is offline   Reply With Quote
Old 10-13-2011, 12:56 AM   #56
Christian.
Member#: 87604
I can be plan B if Bad Noodle is not able to come through, I have several plastic manifolds. I can go without one for a few months. PM'ed ya, just let me know if you would like me to ship it to you.
Christian. is offline   Reply With Quote
Old 10-17-2011, 04:24 PM   #57
ASF Machine
Member#: 236349
1993 Impreza
OD Green
I have a plastic one, just need a Cossie for round two.
Old 10-17-2011, 05:04 PM   #58
AREA1320
Member#: 112508
I have a cossi. Just need a time frame for how long it will be gone and need to be certain it wont be damaged
Old 11-09-2011, 08:18 PM   #59
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Were there any results on the cossie yet?
waynoSTI is offline   Reply With Quote
Old 11-10-2011, 12:56 AM   #60
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Hasn't received it from what he has told me.
project_skyline is offline   Reply With Quote
Old 12-02-2011, 12:21 PM   #61
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Bump for plastic manifold #'s.
RicersWetDream is offline   Reply With Quote
Old 12-02-2011, 12:58 PM   #62
Eww Evo
Member#: 299687
TT2
06' Wrx Project
Is there much difference from the 04 05 STI and the 06 07 STI manifolds?
Eww Evo is offline   Reply With Quote
Old 12-03-2011, 01:47 AM   #63
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Bump for the magic 48hr day, where is it?
Old 12-03-2011, 02:24 AM   #64
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Well if a plastic 08+ WRX manifold is what you need just pay me for shipping and you can use my spare..... You said you had one before but I'd like to know what the IM on my 09 flows for comparison
A fully build GSC cammed port and polished head long block needs to know if the IM can flow up top!
Old 12-03-2011, 09:39 AM   #65
AREA1320
Member#: 112508
Ill quote because this is 3 times im offering this without any actual answers to my questions.
Old 12-03-2011, 04:07 PM   #66
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Exclamation
We can do it without muffing up the paint job.
We're planning on doing part 2 before new years.
ATTN: Flowtest
ASF Machine
590 N Westgate Dr. STE A
Grand Junction, CO 81505
970.242.0919
Old 12-03-2011, 04:19 PM   #67
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Planned so far:
OEM Blastic Status: Have it
Ported Short Runner 2.5i NA Status: Porting it
Forsa Rear Entry SMIM Status: Have it
Area 1320's gaudy Cossie Status: Just responded to Area 1320, pending.
Any other suggestions?
Old 12-03-2011, 04:45 PM   #68
1WRB02WRX
Member#: 182873
wrx with grimmspeed porting would be nice
1WRB02WRX is offline   Reply With Quote
Old 12-03-2011, 06:08 PM   #69
johnt2k7
Member#: 194151
2008 WRX
RED
cant wait to see the results of the plastic LGT/08+WRX manifold
johnt2k7 is offline   Reply With Quote
Old 12-05-2011, 09:05 AM   #70
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Subaru Stars
High hopes for the 2-1/2 i against the coss. Might b close to match each other.
M4c0770 is offline   Reply With Quote
Old 12-11-2011, 10:59 AM   #71
AREA1320
Member#: 112508
manifold going out this week. time frame for return?
Old 12-11-2011, 01:18 PM   #72
Maxwell Power
Member#: 190729
Are you blocking the other three Ports when testing one?
Seems to me that if you aren't, the cylinders will appear better balanced than they are since they won't necessarily be drawing from the throttle body opening which will affect the test's accuracy.
When we tested all four runners at the same time we got almost a twenty percent difference in flow between runners.
Edit:
never mind, I missed that part of your original post. The picture didn't show anything. Sorry
Maxwell Power is offline   Reply With Quote
Old 12-11-2011, 02:24 PM   #73
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Too bad Sponaugle never got to test mine for me....I had heard a rumor that it flowed well for a stock manifold:
http://forums.nasioc.com/forums/show...n2xlr8n&page=2
n2xlr8n is offline   Reply With Quote
Old 12-12-2011, 02:16 PM   #74
DSM_Outback
Member#: 56345
93 Swapped L
Green
When?
DSM_Outback is offline   Reply With Quote
Old 12-14-2011, 11:44 AM   #75
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
good thread
Subaru Cylinder Head Flow Database ASF Machine Built Motor Discussion 48 08-23-2015 05:05 PM
best flowing OEM intake manifold Gamble_WRX Built Motor Discussion 20 05-25-2010 09:52 AM
WTB high flow intake manifold and internals modusvivendi Private 'Wanted' Classifieds 2 08-06-2009 11:25 PM
'04 Plastic Intake Manifold Flow Numbers SOLUTION Normally Aspirated Powertrain 1 03-14-2006 08:03 PM
AVO high flow intake manifold aspera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-10-2002 09:58 AM
