Old 08-20-2011, 04:06 PM   #1
stangod
Member#: 148743
02 WRX & 99 RSTI
Sedona
Default Tranny ?
I have a HY-TY754VB1EA...I believe to be a type ra dccd? I have two connectors on the left side and one on the right. The right connector is the Vehicle speed sensor? The two on left on more forward then the other is what I would like someone to tell me about. One is the Neutral Position switch and other ? If anyone has pin out that would be great. Also where does dccd connect?(I don't have a controller yet). Any help or direction would be appreciated, thanks in advance.
Shawn
stangod is offline   Reply With Quote
Old 08-20-2011, 11:26 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
from the tranny code, i dont think it is an RA tranny...
if it is an RA trans with DCCD it will look like this one that is currently on Ebay...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=300588800155
it will have a set of wires going into the medal plate on the top of the rear of the tranny...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 08-21-2011, 03:53 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
The other switch is most likely the reverse gear switch
Dave, the newer post 1999 transmissions no longer have the metal plate on top, the DCCD controller wires come out from the RH side of the transfer case.
Marnix is offline   Reply With Quote
Old 08-21-2011, 10:26 AM   #4
stangod
Member#: 148743
02 WRX & 99 RSTI
Sedona
Default Thanks
I got this from someone else, it lists it as as dccd http://spda-online.ca/modules/tinyco...ite/tc_28.html
I don't know it to be true, just basing on that. So, all the wiring diagrams don't really explain the tranny with dccd. So one is reverse and the other is neutral pos switch? third is speed sensor? and look on transfer to plug in dccd?
Thanks,
Shawn
Old 08-21-2011, 11:53 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Do you have pictures o fthe actual transmission?
Old 08-21-2011, 10:20 PM   #6
stangod
Member#: 148743
02 WRX & 99 RSTI
Sedona
http://i964.photobucket.com/albums/ae122/stangod/2011-08-21_19-37-09_998.jpghttp://i964.photobucket.com/albums/ae122/stangod/2011-08-21_19-36-52_524.jpghttp://i964.photobucket.com/albums/ae122/stangod/2011-08-21_19-37-26_132.jpg
I don't know if you can get anything from these pics or not.
Thanks,
Shawn
05 tranny/07 tranny=PPG. Tranny experts shamrock 05 Transmission (AT/MT) & Driveline 8 02-28-2007 05:27 PM
Trannys Trannys and more Trannys Chaste Automotive Drivetrain 13 09-02-2004 12:37 PM
Tranny go up, tranny comes down, tranny goes up, tranny comes down.... anders8 South East Region Forum 23 04-12-2004 10:33 PM
WRX Tranny vs 2.5RS Tranny Timmay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-14-2001 11:21 PM
I got my tranny,.. I got my tranny! kaos200 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-15-2001 06:23 PM
