Old 08-21-2011, 12:39 PM   #1
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Default THESHOPCT- 2007 STi w/ AMR T60 8cm | 432WHP - 400WTQ
Event: Dyno Tune !
Ambient Temp: 85ish degrees
Elevation: sea level
Weather: About to rain!
Car: 2007 STi
Tuner: Visconti
Dyno Info: Dyno Dynamcis - Reads like a dynojet "The Moon Dyno"
Peak HP at RPM: 432 @ 6200
Peak Torque at RPM: 400 @ 4700
Baseline hp/tq for a stock on same dyno: 240WHP
Target Boost: 24PSI
Target AFR: 11
Fuel: Straight 93
Engine/Power Modifications:
CP Pistons
Stock Size Head gaskets
Perrin FMIC
DW8504 bar map sensor
Equal Length Headers
AMR T60 8cm
Grimmspeed EBCS
Crawford AOS
Well it's been the week of the AMR turbos.
I thought I'd join in
This is Bryan's 07 STi
We originally had this car on the dyno the day before the final dynosheet
During that dyno session I noticed something wrong.
Turned out to be large amount of oil in the FMIC from not running an AOS.
We cleaned the pipes / FMIC and went back at it.
Temperature in the dyno room wasn't ideal but we got the job done.
On the dyno we were seeing about 93% injector duty on 24psi - I knew once we hit the street we were going to be maxed out - oh I was right -maxed out - 104%
So Bryan left with two maps on the fly - Low boost 20psi / High boost 24psi.
Below are the low / high boost dyno sheets including his original STG2 dynosheet overlayed with the T60 high boost
With a little more boost and some e85 things would get very interesting.
Sorry FP Red time to move over AMR T60 is way better
20PSI -
24PSI -
20PSI vs 24PSI
STRONG Stock Turbo vs AMR T60 -
Visconti is offline   Reply With Quote
Old 08-21-2011, 02:42 PM   #2
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
looks very similar to my graphs...im loving my turbo even with the 7cm hot side
BONFIRE074 is offline   Reply With Quote
Old 08-21-2011, 03:26 PM   #3
SharpByCoop
Member#: 199906
2008 Infiniti G37S
World's quickest: 11.13"
Really good work, John. I love how flat you made that curve. Big-block feel. What a pleasure to drive.
Coop
SharpByCoop is offline   Reply With Quote
Old 08-21-2011, 03:33 PM   #4
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
Nice numbers. I like that torque curve
achavez is offline   Reply With Quote
Old 08-21-2011, 07:20 PM   #5
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Thanks guys - guys does feel great.
Because of the amount of oil in the intercooler I've asked the customer to come back for a check up in a few weeks.
So I'll have a update then.
Got your PM - I'm gonna go get it now
Old 08-21-2011, 07:27 PM   #6
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Throw my plot up too. They are literally identical. This would finally put an end to Ron and myself's feud about the larger hotside on this turbo, lolll
PhatBotti Tuning TKR is offline   Reply With Quote
Old 08-21-2011, 07:56 PM   #7
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
I couldn't find your pumpgas plot...but I got your boys.. I'll pm him in a few
Old 08-22-2011, 12:00 PM   #8
CVR STi
Member#: 127428
What injectors and fuel pump ? looks good!
CVR STi is offline   Reply With Quote
Old 08-22-2011, 01:02 PM   #9
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
255 and dw850s
Old 08-28-2011, 10:38 AM   #10
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
What is your opinion on the t60r vs a rotated 30r as far as spool and power been trying to decide if I should do a rotated hta 3076 or go with the t60r
DarkKnightBaku is offline   Reply With Quote
Old 08-28-2011, 12:15 PM   #11
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
The HTA3076 will spool a little faster than the t60
and the HTA3076 is 57lb/min while the t60 is a 60lb/min turbo - so the t60 is a little bigger.
If you get the t60 for the right price I would get one - I believe AMR's website says $1,499 (before it was $1,800+ - that was too much for me)
Personally at this power level the T60 is the way to go.
-John
Old 08-28-2011, 02:28 PM   #12
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
thanks for the answer have had so many tell me rotated for the power but money is money I would assume a 10.5cm upgrade is worth it also?
Old 08-28-2011, 02:58 PM   #13
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Then your spending money lol
I would keep the 8cm and see how you like it first- I'm sure it will be plenty.
Do you have all the supporting mods for this ?
Old 08-28-2011, 03:09 PM   #14
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
Need injectors still trying to find right turbo
Old 08-28-2011, 04:24 PM   #15
nacho6706
Member#: 165611
Is the T 60 a TD06 based housing?
nacho6706 is offline   Reply With Quote
Old 08-28-2011, 10:08 PM   #16
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Very nice graph.
Wrx_Fan_0717 is offline   Reply With Quote
Old 08-29-2011, 08:53 AM   #17
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
What are your goals?
Old 08-29-2011, 01:46 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
You guys have any comparo plots you could post up?
even though the t60 has a higher rated compressor i would still expect it to make less power than the HTA76 due to the HTA's 4" inlet and bigger turbine housing. Plus the HTA is ball bearing. If you're starting from scratch (IE you dont already have the turbo inlet, up pipe, intake, etc for a stock location setup) then the price difference between stock location and rotated is not very much.
Old 08-29-2011, 02:25 PM   #19
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
Already have all stock location bolt ons looking for around 420whp pump and maybe as high as 460whp with meth
Old 08-29-2011, 04:27 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
t60, fp red, element GT65 are gonna be your cheapest options cause they're journal bearing......the ATP GT35 and the Blouch Dom4/5 are ball bearing and more expensive.
Old 08-29-2011, 05:21 PM   #21
rexblake
Member#: 178426
2010 S4
Gray
That.
rexblake is offline   Reply With Quote
Old 08-29-2011, 05:38 PM   #22
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
The cheapest route is the T60, unless you find a used HTA FP Green - but I personally like the T60 power band better
Old 08-29-2011, 08:12 PM   #23
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
Thanks for the advice I appreciate it
Old 08-29-2011, 08:39 PM   #24
nacho6706
Member#: 165611
Does the AMRT60 have a td06 compressor housing like the green, red , etc?
Old 08-29-2011, 10:01 PM   #25
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
really dont have a clue = maybe someone can chime in
FS : 2007 sti silver bbs 5x114 w/ tires - 600$!!! Unrealgtx SCIC Private Classifieds 38 08-22-2011 01:00 AM
2007 STi 500.2whp / 494wtq @ 25psi - AMR CXR750 Turbo - E85 - stock cams/heads DC5edSTI Proven Power Bragging 16 08-06-2011 09:35 AM
FS : 2007 STI 6MT Transmission (Under 25k miles) - $3,400 SHIPPED Gerald81 Drivetrain 24 01-21-2011 04:04 PM
FS : Amr T60 R Turbo Kit MODDED 06 STI Engine/Power/Exhaust 8 07-17-2010 01:11 AM
Free cold air intake for 2007 STi only in the ontario area - details inside. bue car Southern California Impreza Club Forum -- SCIC 4 09-07-2008 11:38 PM
