Old 08-21-2011, 05:48 PM   #1
mdsubie11
Member#: 272830
Default 2011 wrx data log :(
So i noticed my motor seeming to get louder over these past few days an thought i take a look at a log or two and this is what i found. i dont know to much about the feedback knock or fine knock learn but i know its not sopost to look like that can anyone help me?
First log is stage 2 91oct
https://spreadsheets.google.com/spre...Jjdmc&hl=en_US
Second log stage2 93oct
https://spreadsheets.google.com/spre...J5emc&hl=en_US
Third log Stage 2 91oct
https://spreadsheets.google.com/spre...ZTS1E&hl=en_US
mdsubie11 is offline   Reply With Quote
Old 08-21-2011, 07:29 PM   #2
Tripintaz
Member#: 245218
2013 STI Limited
The only thing I see is that your car has learned it has to pull 1.4 degrees of timing on 91 octane and 1 degree on 93 octane at certain load levels. Looks like part throttle, high loads, such as being in a high gear and then mashing the gas to pass someone, and on shifts after WOT.
As for the learned timing reduction, probably needs a little adjustment in the tune to richen up the AFR where it has learned that it saw knock.
What mods do you have? There are a couple that could cause that with an OTS tune.
Tripintaz is offline   Reply With Quote
Old 08-21-2011, 08:37 PM   #3
dakrat
Member#: 272840
2011 STI
looks about the same as my 2011 STi. from my limited knowledge, I wouldn't worry about FBK and FKL if the throttle is not at 100%. I just wish that this part of the subforum gets policed by Cobb professionals regularly to explain.
dakrat is offline   Reply With Quote
Old 08-21-2011, 08:51 PM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
It does... Cobb is on here every day giving advice.
2Fast4U1DAY is offline   Reply With Quote
Old 08-21-2011, 11:11 PM   #5
mdsubie11
Member#: 272830
a Invidia DP
Invidia Q300 catback
stage 2 AP
Old 08-21-2011, 11:21 PM   #6
mdsubie11
Member#: 272830
its on high loads and on the way home today i was in 5th like 50mph and it would read a fine knock every time i pushed the gas.
Old 08-22-2011, 12:00 AM   #7
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
50 in 5th gear is at like 2000-2250 RPM's the reason its seeing a fine knock learn is because you are lugging the engine. At that speed you need to downshift to 4th, and then you will probably still see fine knock learn because the ECU has learned that you lug your engine, and its trying to prevent a knock situation from occurring.
Old 08-22-2011, 09:38 PM   #8
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Re-set the ECU, avoid all lugging situations like he said and see if it comes up in later logs again.
Phil_Dunphy is offline   Reply With Quote
2011 AP STi, what should i data log? truwrxtacy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-08-2011 07:54 PM
2011 WRX Build log Subiemax Car Audio, Video & Security 24 02-19-2011 02:45 AM
Please Check My Data Log (New logs added) Xsile STI Engine Management & Tuning 6 04-30-2010 04:17 PM
Data logging gurus, need your help reading log. vortectoy AccessPort 5 05-22-2006 01:19 AM
What data does the '02 WRX ECU log? WRX-ECE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-25-2005 04:59 PM
