Old 08-22-2011, 03:40 PM   #1
Drakejesus231
Member#: 249780
2015 WRX STI Limited
CWP
Default Reversed Intake Manifold
Im getting ready to do this and all I'm TRYING to do is relocate my alternator to where my AC Compressor was... I'm about ready to throw a brick through my window. The only thread I can find that explains it has no pictures on how to bolt the alternator in so It's a confusing mess. Anyone?
Reverse Thread I was reading ( http://forums.nasioc.com/forums/showthread.php?t=807772 )
If you care to see the car ( http://forums.nasioc.com/forums/show...2184093&page=2 )
Drakejesus231 is offline   Reply With Quote
Old 08-22-2011, 05:56 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need to grind away material from the A/C bracket so the alternator can flip over to the other side of the bracket where the compressor used to sit. Then you need to fabricate a way to tension the belt. You also need a longer belt.
If this is beyond your capabilities, you should just raise the intake manifold on spacers and lower the alternator with a shorter belt. Then you can run the piping over the alternator in it's standard location.
Old 08-22-2011, 11:08 PM   #3
SiFlyBy
Member#: 250910
this is what i did in order to keep a/c
SiFlyBy is offline   Reply With Quote
Old 08-22-2011, 11:49 PM   #4
Drakejesus231
Member#: 249780
CWP
Well the compressor froze up and I already took it out, I see how to mount one side by grinding it off but the other side to make tensioning still work drives me insane. Te thread I read says you can use all the stock parts?? I just don't get WTF it's talking about
Old 08-23-2011, 05:50 PM   #5
Drakejesus231
Member#: 249780
CWP
No one?
Old 08-23-2011, 06:56 PM   #6
Erik
Member#: 168774
I used the black bracket that was on the drivers side of the ac compressor. Had to bend and cut it a bit and bolted on a 90 degree piece. I used the part that holds the alternator to the bracket in its stock location to attach a bolt to to bring it up and tension the belt.
If you look close you can see what i did in this pic
Erik is offline   Reply With Quote
Old 08-24-2011, 03:38 AM   #7
Drakejesus231
Member#: 249780
CWP
I would LOVE a close up of that. If I can see it close I should be able to figure it out
Old 08-24-2011, 04:59 PM   #8
Erik
Member#: 168774
I no longer have that setup since I recently did a motor swap. Luckily I still had the parts laying around. I hope this is helpful:
Old 08-24-2011, 06:08 PM   #9
.Stichris.
Member#: 243141
2004 UNRIVALED BUILT
this is how i did my set up
.Stichris. is offline   Reply With Quote
Old 08-24-2011, 08:57 PM   #10
Drakejesus231
Member#: 249780
CWP
Wow... I never thought of that one
Old 08-24-2011, 09:11 PM   #11
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
keep the alt where it is and save yourself some trouble.
scby rex is offline   Reply With Quote
Old 08-24-2011, 09:40 PM   #12
.Stichris.
Member#: 243141
yea man its nice i like it pulling the belt down like that so i can run the pipe a lil different... and i took the driver side fan out and ran my pipe from the tb 2 the ic its just over 3 feet
Old 08-25-2011, 02:30 PM   #13
Drakejesus231
Member#: 249780
CWP
interesting! I'm gettin idea's now but I still really don;t even wanna go mess with it now..
Old 08-25-2011, 02:57 PM   #14
.Stichris.
Member#: 243141
Do eeeet
Old 08-25-2011, 09:27 PM   #15
Drakejesus231
Member#: 249780
CWP
I think I will finish this project right after my clutch is fixed. If I'm gonna go all custom piping to the IC does anyone know of a good low price / high quality front mount I might be able to buy alOne??
reverse intake manifold and fmic OneArmedScissor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-29-2004 04:14 AM
Is there a reverse intake manifold made to fit a PII ej25? wighti Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-11-2003 02:39 PM
reversed intake manifold QAboy Normally Aspirated Powertrain 3 12-13-2002 12:04 PM
Saw this on scoobynet, reverse intake manifold!!! pio!pio! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-13-2002 10:44 PM
Reversed intake manifold Really_Soaked Normally Aspirated with bolt-on Forced Induction Powertrain 6 11-14-2001 09:49 AM
