Old 08-22-2011, 06:15 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Ford Revives the Three-Cylinder Engine in a Quest for Fuel Efficiency
Carmakers have spent the past few years aggressively downsizing engines throughout their lineups to meet increasingly tight fuel-economy regulations. But with the sole exception of the three-cylinder Smart Fortwo, four cylinders is as low as carmakers have expected Americans to go.
Three-cylinders are common in Europe but have been scorned in the U.S., where they’re tainted by association with claptrap cars like the mousy Geo Metro. Now, with fuel-economy standards set to rise as high as 56.2 mph by 2025, Ford is planning to bring the three-cylinder to the American mainstream.
Ford’s 1.0-liter engine,the latest in the company’s cylinder slashing EcoBoost series, will be smaller than the average Harley motor, but with the help of turbocharging and direct injection, it should match the horsepower and torque of a typical 1.6-liter four-cylinder. For an easy comparison, Ford’s 2011 Fiesta hatchback wrings 119 horsepower and 40 highway mpg from its 1.6-liter four-cylinder. Drop a turbocharged 1.0-liter in a similar-size car, and you can expect 45 or 46 mpg—within spitting distance of the most frugal hybrids.
Brett Hinds, a Ford engine-design manager, says the forthcoming three-cylinder will produce more than 100 horsepower per liter, blowing past a longtime engine-efficiency benchmark.
Such efficiency is the result of many small technical victories. Unlike conventional engines, the new EcoBoost will use an offset crankshaft, which reduces friction and puts more energy into creating motion and loses less to heat. A split-cooling system warms the engine block quickly, making it easier for the engine to pump cold, thick oil, thereby using 1 to 2 percent less fuel. Higher-quality aluminum alloy in the exhaust manifold helps to trim 11 pounds from the engine. And unlike some three-cylinder engines, which require an energysapping balance shaft to counter shake and rattle, Ford says the EcoBoost is inherently balanced.
Ford has withheld most details, but it has said that the engine will eventually replace four-cylinders in millions of small models around the world. Expect other carmakers to follow suit.
http://www.popsci.com/cars/article/2...uel-efficiency
Old 08-22-2011, 06:28 PM   #2
besthaticouldo
Member#: 279660
new daily here i come.
besthaticouldo is offline   Reply With Quote
Old 08-22-2011, 06:28 PM   #3
Delphi
Member#: 239335
2011 WRX
Well it looks better than a Geo Metro.
Delphi is offline   Reply With Quote
Old 09-15-2011, 10:27 AM   #4
Finwrx
Member#: 75029
http://www.autoblog.com/2011/09/12/f...the-euro-spec/
The new EcoBoost engine will be available in the Ford Focus, C-Max and B-Max, and it will be available in 99 horsepower and 118 hp variants. A respectable 125 pound-feet of torque is available from a scant 1,300 rpm thanks to a turbocharger that can spool up to 250,000 revolutions per minute. Ford was able to extract so much power out of such a small, boosted engine thanks to improved twin variable camshaft design and an exhaust manifold cast that is cast into the cylinder head. And get this: While other EcoBoost offerings start with an aluminum block, the 1.0-liter includes an iron engine block, which isn't only cheaper, it reduces engine warmup time by 50 percent.
The key benefits sought from engine downsizing, of course, are improved fuel economy and lowered emissions. In this scenario, Ford promises 120 g/km C02, which works out to right around 45.5 miles per gallon (U.S.) on the European cycle. That 120 g/km figure, in case you're wondering, is identical to the much smaller Scion iQ, which gets a 36 city / 37 highway EPA rating. The diminutive engine will be fitted with five-speed and six-speed manual transmissions.
Subaru needs to catch up. Subaru's eco engine 1.6L 114hp and 110lb-ft/4000rpm. Ford turbocharged DI 1.0L 118hp and 125lb-ft/1300-4500rpm.
Finwrx is offline   Reply With Quote
Old 09-15-2011, 05:12 PM   #5
aschen
Member#: 30733
2007 tiny car
striped
Aluminum exaust manifold? cool........er hot well you know what I mean
aschen is offline   Reply With Quote
Old 09-16-2011, 09:52 PM   #6
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
Uhh....is that Subaru motor turbocharged?
Derbagger is offline   Reply With Quote
Old 09-17-2011, 12:50 AM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
why do we still refuse to introduce diesel engines into the US???? 40 MPG hwy is not that impressive, we all know that the econoboxes of the 80's and early 90's did that. Averaging in the 30's in real world driving is good but damn - we could see big improvements in economy with diesels and if they are using turbos and DI to achieve the MPG goals the cost difference between a these motors and a small displacement diesel should be negligible. [/rant]
Old 09-17-2011, 08:24 PM   #8
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
Because the increased efficiency is partially offset by the greater cost of the diesel model, and partly by the greater cost of fuel. Diesel is taxed at a much higher rate to be a de-facto tax on truckers. Until that changes, they will be a fringe vehicle.
Old 09-17-2011, 08:35 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
the cost of a turbocharged DI gas motor and a turbo diesel are close enough to call it a wash. As for the fuel, you are correct that the price difference in the US is due to taxation but the efficiency improvements justify the cost difference easily.
Old 09-17-2011, 11:18 PM   #10
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Doesn't the STI have like 122hp / litre? Not much of a benchmark.
ki4syr is offline   Reply With Quote
Old 09-18-2011, 12:05 PM   #11
arghx7
Member#: 232940
it's a good benchmark for naturally aspirated cars but not so much for boosted.
arghx7 is offline   Reply With Quote
Old 09-18-2011, 02:43 PM   #12
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
good point.
Old 09-18-2011, 02:53 PM   #13
tablesandchairs
Member#: 294641
I want a high-milage small car for around town so bad. Nothing out there really yet though...may end up with an all-eletric if someone cannot make something soon.
tablesandchairs is offline   Reply With Quote
Old 09-18-2011, 03:33 PM   #14
Gixhost
Member#: 180111
* 2004.114.3 STi
Glad to see Ford stepping up to the plate and delivering more efficient engines that are also leading the way by using the most up to date technology without cutting corners.
Gixhost is offline   Reply With Quote
Old 09-18-2011, 05:01 PM   #15
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
The base auto TDI golf costs $26k and gets 42 mpg. The base auto Hyundai Elantra costs $18,500 and gets 40 mpg. Why would I ever get the Golf?
Capt Crunch is offline   Reply With Quote
Old 09-18-2011, 07:42 PM   #16
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
comparing a base elantra to a "base" TDI is silly. I mean, a base impreza is $18, why would anyone want a 3 series .
The base golf TDI come far better equipped but, you're right, that doesn't make up the gap... some people have preferences. Now, if you compare the elantra touring (only 21/31) to the Golf and it's a no brainer. Plus, the equipment on the Golf is still far better.
Old 09-18-2011, 09:05 PM   #17
quentinberg007
Member#: 7887
Scion iQ. 36mpg city, 37mpg highway. Unless you go for a hybrid, you won't see those sort of city numbers anywhere else.
quentinberg007 is offline   Reply With Quote
Old 09-18-2011, 09:21 PM   #18
Capt Crunch
Member#: 10852
The elantra touring is the old elantra. If you need a hatch, then of course, get the TDI. I needed a hatch and got a GTI instead of the elantra.
As for the TDI, I was under the impression that it was a Golf with a different engine. The base golf is $18,000, so I thought it merited comparison with the elantra. I'm not sure what toys the TDI comes standard with, but it better be a hell of a lot to warrant the $7,500 over the elantra considering the two cars are pretty much the same on fuel costs.
Old 09-19-2011, 07:15 PM   #19
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
TDI typically comes with mid-to-upper level trim.
Has anyone gotten a tune for fuel efficiency? mflo Southern California Impreza Club Forum -- SCIC 14 07-11-2011 11:54 PM
WTB : Looking for Fuel efficient commuter car xrw1 NESIC Private Classifieds 6 06-25-2011 09:02 AM
Best mph/rpm for fuel efficiency with XT DavidBowie Forester Forum 43 02-22-2006 05:37 PM
DOE Announces Research Projects for Fuel Efficiency FunkerVogt Political Playground 1 05-26-2005 09:50 PM
Mods for fuel efficiency? flyingmachine General Community 13 01-07-2004 05:00 PM
