#1 |
Member#: 182830
Vehicle:2008 Porsche WSC LMP dark blue |
Hi , a couple of members have sugested i start a new thread on a little project I'm undertaking at present, so for those that are interested here goes.
As i have just joined the forum i wont bore you with to much detail at this stage, but what i'm building is a copy of the 96-97 LeMan winning Porsche LMP1 WSC car of Joist racing. it will be powered by an EG33 with a modified WRX gearbox, layout is Mid engined, weight will be approx 600-650 kg. suspension is custom, inboard front, outboard rear, front uprights and brakes are from a Mk4 RX7 Mazda, rear brakes are R34 Skyline rotors with Willwood 4 pot calipers, tyres are 10" front, 12" rear Hoosier Slicks. a couple of pics to give you an idea. ![]() ![]() ![]() ![]() a photo bucket site with plenty of pics of of the build so far http://s236.photobucket.com/albums/f...RC-95/?start=0 if anybody has any questions , feel free cheers John
#2 |
Member#: 138798
Vehicle:06 WRX Urban Gray Metallic |
Wow, very deep project. Good luck and keep updating the OP!
#3 |
Member#: 75081
BAIC
Vehicle:2003 WRX WRB |
The car doesn't even have a shell and it already has a spare tire on it?
![]() Looks like an awesome (EXPENSIVE) project. Good luck with the build up. Definitely want to see how it turns out. |
#4 |
Member#: 174768
Vehicle:2002 WRX WRB |
I would so rock that around chicago.
Very nice. |
#5 |
Member#: 182830
Mate thats not a spare but the latest tyre technology From dunlop, as my home track is prodominitly RH cnrs, i thought id save myself $600 on a slick . as for expensive, if it was i wouldnt be building it, to date it owes me $6000 and thats with everything you see in the bucket site including engine and gearbox. Goal is to have it on the track, racing for around 20g. "I would so rock that around chicago". there is one being built in Michigan as we speak, and another in California, not sure what power plant they have decided on as yet though. glad you all like it cheers John |
#6 |
Member#: 182830
finaly got the gearbox and engine bolted together and trial fitted for the first time, its tight but it fits, about 5mm clearance each side between rocker covers and top chassis rail.
![]() will have to modify side diagonals and make them removable to allow access to rear spark plugs. looking foward over the gearbox. not a lot of room but its in there ![]() now the fun starts , custom sump, custom headers etc, let the games begin cheers Kaspa |
#7 |
Member#: 126696
SWIC
Vehicle:2002 Fatbody bugeye 03 R1 09 Raptor 700R |
uh...isn't a mk4 a supra or v dub?! are you sure you didn't mean FC3S or FD3S rx7?
#8 |
Member#: 182830
for the purists, over here in NZ the Fc is comonly called a MK 3 and Fd is a MK 4 batmobile.
so front end is FD3S, if your that way inclined cheers kaspa |
#9 |
Member#: 138768
Vehicle:2004 Stage 2 .:WRX:. WRB |
mmmk.
how much for you to build me one? lol. looks freakin sweet! |
#10 | |
Member#: 182830
theres two being built state side at present. cheers Kaspa |
#11 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
wrong forum, this def isnt newbie. sick car.
#12 |
Member#: 182830
There seems to be alot of debate on other forums i've looked at as to what gear box will fit onto the EG33, so heres what ive done .
the box in the pic is a 92 legacy 4WD box thats been converted to 2WD and bolts straight up, i also have a 90 legacy 2WD box sitting on the floor and that bolts straight up as well, i also have been informed by a reliable source that all gears etc are interchangable between the 2WD box and the 4WD box, as my 2WD box has late model WRX close ratio gears installed, with early 3.9 final drive LSD. i will be useing the 2WD box in final assy as it will allow for a rh gear change mechanisim to be fitted a lot easier than the 4Wd box, as it has a shorter rear housing and the bonus ,its a few pound lighter, as soon as i sort out the new mounts to fit the 2WD box and get it fitted, ill post a pic cheers Kaspa |
#13 |
Member#: 168900
Vehicle:2002 Impreza WRX Vf-39 Grp.N luv |
WOW, kudos to you and your hand fabricated space frame.
I have made frames and body panels from scratch and it takes hours of work on a jig table, measuring and checking and re-checking for symmetry and square. What did you use for the frame, chromoly 4130? Mid-engine RWD, double wishbone w/toe rear and a Pushrod/bell crank front suspension. The only thing missing is the sequential gear box. That is some serious sickness. Are you making all of the body panels yourself from scale? |
#14 |
Member#: 182830
Hi Bloke, roll cage and associated braces are chromoly, the main chassis is just MS 1.6mm tube.
and yes i will be making all the body panels from scratch, but at least i have all the profiles on CAD to get cut out, so all i have to do is stich them all together hopefully the EG33 will push her along at a decent rate of Knots cheers John |
#15 |
Member#: 152117
SCIC
Vehicle:2012 Ford F150 ECO White |
^^^and if it doesnt...BIGGER TURBO
#16 |
Member#: 84006
Vehicle:2005 Impreza WRX STi WRB with Goldies |
Awesome job, beautiful work. Keep the updates coming, I can't wait to see that on the road...
#17 |
Member#: 144779
Vehicle:200X ZOMG a car 100% crabon fibre girlfrendorz |
Beautiful work. I would LOVE to build something like this. The tube frame/cage looks amazing. I will be folowing this build for sure.
#18 |
Member#: 182830
Thanks mate i sincerley hope every one else follows it as well, especialy after its finnished
![]() cheers John |
#19 |
Member#: 182830
things have been cold wet and miserable down here lately, so havnt managed to get a lot done, and as i cant do much engine wise for a while [lack of funds] i've been consentrating on getting all the panaling done, cockpit is almost finnished just the pasengers seat to do which i hope to get done this week end, as you will notice by the pic, i have made the seats an integral part of the cockpit which will add substantial ridgidity to the area.
![]() a better veiw of the drivers seat ![]() the two levers you see on the center consul are for the front and rear adjustable sway bars, in case your wondering. and before you ask the gear shift will be on the right, mounted on the side panel by the steering wheel. cheers and thanks for looking John |
#20 |
Member#: 180958
TXIC
Vehicle:2008 Homemade Yellow |
heya, awesome. Are you going to make it legal? how are you going to run your shift linkage? I built this and drive it to work everyday it isn't raining, I have been thinking about putting a manual in it but it is a bit of a pain in the ass.
Here are some videos of the car, as well as some pics; http://www.cardomain.com/ride/3088011 http://video.cardomain.com/armigerlives |
#21 |
Member#: 182830
Hi bloke, although it could be built to street legal specs easily enough , i'm building it as a race only car, its just a toy for an ole man to have some fun with.
glad you like it cheers John |
#22 |
Member#: 182830
The weather has finaly changed for the better, the rain has stopped for now but its still bl##dy cold, but braved the elements and got the seats finnished finaly
![]() ![]() just the gearshift left to make and fit the whole thing has turned out much more roomy and alot more comfortable than i ever would have imagined, i must admitt to being quite pleased with myself. cheers John |
#23 |
Member#: 5553
E. Canada
Vehicle:2002 impreza wagon silver |
Nice work!
#24 |
Member#: 154806
Vehicle:2011 SWP WRX |
thats fantastically awesome!
#25 |
Member#: 182830
Thanks guys appreciate the Kudo's.
Do, havnt heard back , have you made a decision. cheers John |
| Thread Tools | |
| Display Modes | |
| My 2010 Race Car Build - From the Ground Up | boost junkie | Motorsports | 1788 | 04-24-2013 10:38 PM |
| SMS/EQ Tuning GC8 Race Car Build Thread | rrsettgast | Member's Car Gallery | 147 | 05-27-2012 08:46 PM |
| Forged Performance 370Z Race car build first track test...impressions | Forged Performance | NASIOC Project Cars | 44 | 12-06-2010 10:12 PM |
| BLEE's continuing 04 STI race car build | Blee | Member's Car Gallery | 37 | 05-03-2010 11:17 PM |
| JC Meynet/Harman Motive 2009 race car build | mxpop | Member's Car Gallery | 32 | 03-21-2009 02:36 PM |
