Old 08-23-2011, 05:52 PM   #1
NoGraffix
Member#: 276209
I am Rub
Function>Form
Question Logging with Prosport UEGO
Just wondering if anyone else has this prosport wideband (http://prosportgauges.com/wideband-a...ber/White.aspx) and is able to log with it and how their setup looks. After searching the only UEGO adaptor I can find is this one (http://storefront.bustedfingermotors...&products_id=2) and I'm not sure if it is AEM specific or not.
Thanks for the insight.
NoGraffix is offline   Reply With Quote
Old 08-23-2011, 08:33 PM   #2
NoGraffix
Member#: 276209
I am Rub
Function>Form
anyone?
Old 08-24-2011, 01:28 PM   #3
fenix-silver
Member#: 231700
2004 WRX Wagon
Unless that wideband has a serial output (which it doesn't appear that it does), that BFM adapter cable won't work with it. I think there is a way to use an analog input with a Tactrix, but I'm not positive. I suppose that you could find some type of analog to digital converter that has a serial output that you could then log with, but that seems like a headache.
fenix-silver is online now   Reply With Quote
Old 08-24-2011, 02:26 PM   #4
NoGraffix
Member#: 276209
I am Rub
Function>Form
A contact from prosport informed me that the bustedfinger device should work.
That what the cables look like coming from the UEGO controller that should feed to some connector then to the laptop. I don't know what a serial output is.
Old 11-25-2011, 07:45 PM   #5
wrxopeh
Member#: 275785
2011 WRX
Hey NoGraffix, were you able to datalog with your Prosport Uego Controller? I'm about to install my gauges and have the same question regarding the connection from the Uego Controller to the laptop. I'm assuming the AccessTuner Race software will be able to utilize the info from the controller, but haven't found any good info about the type of cables to connect the 3 wire analog connection to yet. Thanks.
wrxopeh is offline   Reply With Quote
Old 12-14-2011, 08:48 PM   #6
Drunkinchef
Member#: 145324
1991 MR2 T-Bar Turbo
Red
Bump! I just picked one of these up. I'd like to know how to hook up the 3 wire plug to datalog!
Update: Just spoke to a Prosport rep. Black is ground, Brown is 5V signal.
This may possibly work. I wouldn't see why not...
http://www.mellonracing.com/index.ph...8c4be248f1ade7
Drunkinchef is offline   Reply With Quote
Old 12-15-2011, 12:27 AM   #7
Drunkinchef
Member#: 145324
Red
One more... This company I just ordered from. Provides a serial and the usb adapter along with software link. Winning!
Old 12-16-2011, 10:20 AM   #8
dux10
Member#: 235338
2002 Faggin Wagon
srp
I want to know if it actually works. It should work, but you never know for sure! lol
dux10 is offline   Reply With Quote
Old 12-16-2011, 10:39 AM   #9
Drunkinchef
Member#: 145324
Red
I ordered the busted finger unit. I'll post when I receive and test it. Also they say it will work with romraider, for u subie guys. I will also give that a whirl.
Old 12-25-2011, 04:01 PM   #10
NoGraffix
Member#: 276209
I am Rub
Function>Form
I got the bfm cable and wired it all up but I cannot get the drivers that bfm has available on the web page to work. Anyone have any ideas on how to get these drivers working? I'm following the instructions on the web page exactly, but when I get to the point to search for the drivers in the designated folder, but the system is unable to find the necessary software to install the drivers.
Old 01-06-2012, 10:05 PM   #11
wrxopeh
Member#: 275785
2011 WRX
Did anyone get this working? I made my own cable, bought a FTDI Chip Serial to USB Cable, but no information is showing up in hyperterminal on the laptop. I've verified voltage information is making it to the wires soldered to the female DB9 port 2 and 5. I then stuck 2 paper clips in the female db9 end into ports 2 and 5 and also see the same voltage information. My thought on this is that the prosport uego controller is sending analog information and I don't think the DB9 to USB cable is going to convert the analog information to digital, could be wrong though. If that's the case, I don't see how you can get this to work through their analog output using this type of setup. Prosport sells the same cable (http://prosportgauges.com/wideband-a...ink-cable.aspx) and this is what they state on that page "All you have to do is mount the plug in port and splice one wire to the output signal wire (green to Brown) and the other to Ground and you are ready to log." Based on the picture on that page one wire is blue and the other one looks to be brown, so does that mean they want you to splice the output green wire that goes to the gauge and not from the analog output? Maybe the gauge is being sent digital information to display and you can tap into that wire to get the data? I've sent them an email about it earlier in the week, but haven't heard back from them. Just my thoughts.
Old 01-17-2012, 02:15 PM   #12
craftyvtec
Member#: 97944
2004 M3
Does anyone have a update on this setup. thanks.
craftyvtec is offline   Reply With Quote
Old 01-17-2012, 07:20 PM   #13
wrxopeh
Member#: 275785
2011 WRX
Default Nada
No information back from Prosport yet. Still not working.
Old 01-17-2012, 08:38 PM   #14
craftyvtec
Member#: 97944
2004 M3
I talked with prosport today. They are working on a fix for this problem. They said call back in a week.
Old 01-18-2012, 12:31 PM   #15
NoGraffix
Member#: 276209
I am Rub
Function>Form
I called them today and they told me I need to hardware the sensor to the ECU if I want to log.......
Old 01-18-2012, 02:33 PM   #16
dux10
Member#: 235338
2002 Faggin Wagon
srp
hahaha did u tell them the stock ecu doesnt work on the same scale as their sensor? for cryin out loud- the car would have to be setup to be in OL 100% of the time.....
AEM ftw
Old 01-19-2012, 01:20 AM   #17
NoGraffix
Member#: 276209
I am Rub
Function>Form
Nope I just decided to sell it and get an AWM wideband. Prosport can suck my balls, lame as company.
Old 01-25-2012, 07:02 PM   #18
wrxopeh
Member#: 275785
2011 WRX
Here's the reply I received from them today: "Our datalog output signal is made for the cars computer, meaning they have to be wired into the computer for the data logging. They're not able to be data logged through a serial/USB cable."
Looks like the same answer that NoGraffix got. I wonder what type of information is being sent to the guage (digital or analog)? If the gauge is being sent digital information, wonder if you could tap the gauge wire to get the data?
Old 01-26-2012, 04:23 AM   #19
Drunkinchef
Member#: 145324
Red
There are two wires for datalogging on the gauge. I don't have he information in front of me at the moment but I know what one is.wideband and the other is narrow band(oem style o2 output). I've been slacking on my project but ill post soon.
Old 01-26-2012, 06:59 AM   #20
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You guys shouldnt be having these problems setting up wideband datalogging.
In hyperterminal you need to make sure that your data settings are correct.
Bits Per Second: 9600
Data Bits : 8
Parity: none
Stop Bits: 1
Flow Control : Hardware
This is how it is shown in the AEM user manual.
Based off what is written in the AEM manual, the serial output is used on the 0-1v wire. The datalogging I do in my cobra is running the 0-5v wire, and I had to set my transfer function in my laptop tuning software. The Cobb AccessTUNER Race software allows for a seperate USB input for a wideband, and can be set in the software itself. I have not dealt enough witht he romraider software to give you a really good "how to" on setting up your wideband in the subaru... However I will be working on it this week.
Black94Snake is offline   Reply With Quote
Old 01-26-2012, 11:56 AM   #21
PinoyRukus
Member#: 193966
08 STi
I just bought premium gauges (amber/white pointer) boost/wideband due to the fact that these match up to the oem cluster the best. I hope the wideband can be datalogged with the cobb access tuner otherwise I just wasted some money =T . "subscribed"
PinoyRukus is offline   Reply With Quote
Old 01-26-2012, 10:03 PM   #22
wrxopeh
Member#: 275785
2011 WRX
Black94Snake, AEM outputs the information in a serial format which is digital information, the EVO UEGO controller only outputs information in Analog format which would need to be converted to digital information for a laptop to log it. I wish it was an AEM serial output, I would already have data then. Thanks for the info though.
Old 01-26-2012, 10:55 PM   #23
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Prosport lists their WB as having a 0-1v output.
AFR Premium Series Gauge
Bosch 4.9 5 wire heated O2 sensor
Weld in Bung
Instructions
Wiring harness(Gauge to O2 sensor) 10 feet long
Plug and play
Decals
Visor/hood
Mounting Cup
0-5 volt output signal for data logging
AND
0-1 volt output signal
so......
Old 01-27-2012, 04:00 PM   #24
wrxopeh
Member#: 275785
2011 WRX
Black94Snake, you are referencing the Premium Series gauge. We were trying to get the EVO Series gauge to datalog. Here is the information from their instruction manual:
BLACK ENGINE GROUND
BROWN WIDE BAND ANALOG OUTPUT 0-5V (0V  10AFR, 5V  20AFR)
GREEN NARROW BAND ANALOG OUTPUT 0-1V (0V  20AFR, 1V  10AFR)
Also, here's the link to their install instructions:
http://prosportgauges.com/instructio...vowideband.pdf
Unfortunately, the wideband wire which is sending out the 0-5 volt signal is analog information not digital, so you can't datalog it with a laptop unless you can convert the analog signal to digital information.
Old 01-27-2012, 06:03 PM   #25
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
sounds like this calls for...
http://www.dataq.com/
Logging with AEM Uego krisco Commercial ECU Reflashes 12 11-12-2010 03:18 AM
Correct Cable for Logging with AEM UEGO motocooney Open Source Reflashes 3 05-06-2010 01:32 AM
AEM UEGO for tuning and logging with Enginuity clemsonteg Commercial ECU Reflashes 0 10-01-2007 04:03 PM
Problem with prosport boos gauge andrew74 Interior & Exterior Modification 21 04-17-2007 12:08 AM
Help with PROSPORT Gauges!!!!!! readywrx Interior & Exterior Modification 1 11-23-2006 12:35 AM
