Old 08-23-2011, 06:48 PM   #1
Tyrus3
Member#: 133875
2000 Impreza RSTi
2005 Legacy Wagon
Impreza GC8 Can someone take a look at my logs?
These are my first two logs...so be gentle.
Background: Car overboosted a couple days ago, threw the P0244 wastegate malfunction CEL, cleared it, reset the ECU, reflashed the map. It seems to be running ok now. I suspect there might be some leaks in the system though and I plan on getting it checked out.
Mods:
EJ257 SB
EJ205 heads
02/03 WRX ECU
Cobb dish pistons
Cobb TBE
Cobb XLE BOV
Cobb intake
TD05 FP20G Turbo
APS big TMIC
TGV deletes
DW 650cc
The previous owner had the car e-tuned. I plan on getting it dyno tuned in the near future.
The "Log 7" sheet I listed the rows I was WOT (248-259). Log 8 is small and easy to tell. I wasn't sure how much/little to post. I'm not sure if I was WOT long enough either.
https://spreadsheets.google.com/spre...JOZnc&hl=en_US
Tyrus3 is offline   Reply With Quote
Old 08-25-2011, 09:10 PM   #2
Tyrus3
Member#: 133875
2000 Impreza RSTi
2005 Legacy Wagon
D'oh, I was lurking this thread for a couple days prior to being able to log some data and Bill from Cobb was all over this thread, but no more. I have noticed that the car backfires a little more frequently in low gear up shifts. It doesn't do it often but it has started to do it more; maybe a couple times a week (dd the car ~250-300 mi/week).
Old 08-26-2011, 08:09 AM   #3
Cobb Tuning
Member#: 4803
You want to start your WOT run a little sooner (say around 2000-2500 RPM). You have some feedback knock near the end of your first WOT run - I'd see if that is repeatable (none in second log) or just because you were lifting off the throttle. In your second run, the DAM has most likely dropped to 14 (depends on what the initial value is tuned to post-reset/reflash). Hybrid motors have different noise characteristics compared to the stock short block, which can mean that you will see more false knock. This can make it difficult to diagnose without a separate means of identifying true knock (such as det cans). We do have beta knock sensitivity tables via the AccessTUNER Race software that you or a tuner that you plan to use could play with if it turns out to be a problem.
Bill
Old 08-26-2011, 09:27 AM   #4
Tyrus3
Member#: 133875
2000 Impreza RSTi
2005 Legacy Wagon
Thanks for the feedback. I'll try to log another run or two over the weekend and post them.
take a look at my log big22 AccessPort 2 08-14-2011 11:41 PM
WRX02 stage2, take a look at my log pls KENT56 Open Source Reflashes 15 10-31-2008 01:41 AM
Please help take a look at my logs... spitfirezip100 Engine Management & Tuning 22 04-27-2007 03:12 AM
Can someone take a look at my logs? cr125r Engine Management & Tuning 51 01-22-2007 06:36 PM
Can someone take a look at this open loop fuel map... 03WRXMA Engine Management & Tuning 7 03-13-2004 03:33 PM
