Old 08-25-2011, 08:30 AM   #1
TheWatcher
Member#: 292189
Default Incredible Aston GT3 racer revealed
Aston Martin Racing has today (24 August 2011) officially unveiled its 2012 GT3 racer. It can be yours for 298,000.
Based on the V12 Vantage, it gets a version of that car's 6.0-litre V12 engine, producing 600bhp and mounted further back in the aluminium composite chassis for better weight distribution.
A six-speed sequential transmission sends power to the rear wheels via a carbon fibre prop shaft, which is housed under a body that's clearly been drinking a lot of Red Bull.
As well as the enormous rear wing, the clearly Photoshopped images from Aston show an ultra- wide body kit, carbon front splitter and racing spec rear diffuser.
It's eligible for all kinds of racing, including the FIA GT3 Championship, the British GT and the Open GT; Aston says it is the only manufacturer to offer a race car for every class.
Testing for the Vantage GT3 starts in October, with first deliveries of the car in early 2012.
TheWatcher is offline   Reply With Quote
Old 08-25-2011, 12:56 PM   #2
PlanB
Member#: 175608
2006 Impreza
1998 Honda VFR 800FI
That`s a lot of venting, but what exactly makes it 'incredible'?
PlanB is offline   Reply With Quote
Old 08-25-2011, 01:53 PM   #3
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
its an aston martin that may actually be fast?
IMPORTIMAGE is offline   Reply With Quote
Old 08-25-2011, 02:20 PM   #4
Skanky
Member#: 10434
2006 Impretsah STi
Aspen white
That Is Gorgeous!
Skanky is offline   Reply With Quote
Old 08-25-2011, 02:53 PM   #5
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
I've always been a fan of AM's race cars. These were the best looking Le Mans GT cars when they were running (IMHO):
e11ys is offline   Reply With Quote
Old 08-25-2011, 02:58 PM   #6
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
that **** is sick! what's that in US currency?
Strobe Media is offline   Reply With Quote
Old 08-25-2011, 03:02 PM   #7
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
Art in motion.
That's what Aston Martin is all about, without question.
SatinWhitePearl is offline   Reply With Quote
Old 08-25-2011, 03:51 PM   #8
lark6
Member#: 2715
70 911T
Maybe it's an Aston that can actually finish a race?
lark6 is offline   Reply With Quote
Old 08-25-2011, 03:58 PM   #9
WRXHillClimb
Visiting NASIOC Timeout
Member#: 206907
2014 EvoX GSR
2005 S2000 Track Car
BMW will still destroy it.
WRXHillClimb is offline   Reply With Quote
Old 08-25-2011, 07:11 PM   #10
HipToBeSquare
Member#: 119958
1992 SVX LS-L
You do realize that all of that venting is to shed heat from a V12 under that hood, right?
HipToBeSquare is offline   Reply With Quote
Old 08-26-2011, 05:32 AM   #11
TheWatcher
Member#: 292189
The new Zagoto is half million
Old 08-26-2011, 09:19 AM   #12
robmarch
Member#: 18713
06 CRV
04 STi
so V12's require swiss cheese vents, but 1000+ hp V8's are ok?
not sure what you're getting at.
robmarch is offline   Reply With Quote
Old 08-26-2011, 09:29 AM   #13
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
What 1000hp V8's? GT spec classes don't allow anyone to run a 1000hp V8. IIRC GT1 cars were around 600hp and I believe the GT2 cars have always been under 500hp. Obviously there are allowances for weight and displacement, but there aren't any GT cars running around with 1000hp coming from a V8.
Endurance racing is a lot of heat for a long time. Getting that heat away from the motor and engine bay components means they last longer. Everyone gets that heat out somehow.
Scooby921 is offline   Reply With Quote
Old 08-26-2011, 10:38 AM   #14
robmarch
Member#: 18713
06 CRV
04 STi
I'm with you, I'm just not sure it's an on/off switch that as soon as you have a V12 under the hood you need to vent it like crazy.
Aston likes hood vents on race cars with V8's too, right?
Old 08-26-2011, 12:13 PM   #15
HipToBeSquare
Member#: 119958
1992 SVX LS-L
How different companies choose to handle heat management, is up to them.
But the street-spec V12 Vantage has hood vents, too, as does the Zagato-designed version.
That is a very low hood that fits tightly to the engine. The engine also requires under-hood modifications to the radiator frame, and other things, even to FIT the V12.
But my other point was that there isn't a V8 under that vented hood, there is a racing-tuned V12. It also means that horsepower for horsepower, the V12 is probably less stressed than the V8s it competes with, and has better inherent balance. In endurance racing an engine that is not constantly breaking itself down by exceeding it's limits, or shaking itself down, can have advantages beyond a closer firing order, and more latent torque availability from 4 more pistons.
This isn't just an AM Vantage 4.7 Liter V8 in racing clothes. This is a very serious 12 cylinder machine, and has serious heat to shed because of it.
Old 08-26-2011, 02:17 PM   #16
robmarch
Member#: 18713
06 CRV
04 STi
if it's less stressed than the v8s' it's competing with, why would it be generating more heat?
Old 08-26-2011, 06:31 PM   #17
HipToBeSquare
Member#: 119958
1992 SVX LS-L
it is still 12 cylinders compressing air and fuel together.
I didn't say necessarily more heat quantitatively, I said heat in a tighter engine bay, with a lower hood line.
My SVX has a close fitting low hood over a low boxer 6 engine... and it bakes the under hood wiring, hoses, and everything else, and makes all the plastic fittings brittle, because the heat can't go anywhere. I wish my SVX had even just a couple of hood vents up by the cowl, to chimney some heat out of the engine bay.
Twice as much engine, even more tightly fitted into it's engine bay, and the heat issue becomes even more acute, which means that V12 Vantages get hood vents. Racing editions get BIG hood vents.
Just because the AM V12 isn't AS stressed as a V8 putting out nearly as much power, doesn't mean that it is putting out no heat at all. It is still two compression strokes every 60 degrees of crankshaft rotation. Compressing, then combusting all of that creates heat.
But the bearings on the V12 may not be as violently hammered (better primary and secondary balance than a V8, or any other engine, aside from a flat 6, an I6 is close, but a V12 or flat 12 is two I6s counter-balanced.)
The RPM range might not need to be as drastically high to make the given power level, and the metallurgical, physical, and thermal stresses on the block and heads may not be severe by pushing less horsepower per piston, but still producing the same or more horsepower at the end of the crankshaft, in total.
Old 08-26-2011, 11:38 PM   #18
Burnman
Member#: 218087
95 Legacy
That ugly 'spruce' green.
It's about downforce, not heat.
Burnman is offline   Reply With Quote
Aston V12 Zagato revealed AVANTI R5 Non-Subaru News & Rumors 22 05-23-2011 05:08 PM
Aston Martin Vantage GT3 Race Car Announced as DBRS9 Replacement AVANTI R5 Non-Subaru News & Rumors 0 04-13-2011 02:15 PM
Hardcore Aston Vantage revealed AVANTI R5 Non-Subaru News & Rumors 5 07-06-2010 04:27 PM
Alpina rejoins motorsport with its BMW 6-series-based GT3 racer darknightohio Non-Subaru News & Rumors 14 02-07-2009 02:57 PM
Morgan Aero 8 GT3 Racer @ 2007 Geneva Motor Show NYCshopper Non-Subaru News & Rumors 18 03-12-2007 05:02 PM
