Old 08-25-2011, 07:38 PM   #1
scooby1326
Member#: 286827
Default Launch control problems
My launch control was working fine but now if the car is stationary I can't rev the car past the rpm I have the LC at, even if I am not touching the clutch. Any help would be appreciated it. I don't plan on launching the car often but I would rather fix the problem than just bypass it.
scooby1326 is offline   Reply With Quote
Old 08-25-2011, 08:57 PM   #2
f1speeder
Member#: 138854
2011 WRX
Did you check your Flat Foot Shifting RPM?
You could try to uninstall the AP then reinstall it and see if that helps
f1speeder is online now   Reply With Quote
Old 08-25-2011, 11:26 PM   #3
scooby1326
Member#: 286827
I don't have flat foot shifting, and I did that with no luck.
Old 08-26-2011, 08:01 AM   #4
Cobb Tuning
Member#: 4803
For the 02-05 WRX, the launch control is not based on the clutch at all. This is because the engine control unit (ECU) does not have an input for the clutch switch, so the ECU has no clue whether or not the clutch is in. As such, for these cars, we set it up so that vehicle speed determines whether LC is active or not. So, once you start rolling, LC will be disabled. If you are stationary, then LC will be active.
Bill
Old 08-26-2011, 01:02 PM   #5
scooby1326
Member#: 286827
Well that was easy, thanks a bunch.
Group N launch control Problem - Help kbaldi_29 Open Source Reflashes 2 03-09-2011 08:37 PM
launch control problems iheartwrxSTI Open Source Reflashes 12 09-09-2009 01:03 PM
xpt launch control problem I <3 Dirt Open Source Reflashes 10 04-09-2008 09:17 AM
Flat Shifting / Launch Control Problems djosrs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-15-2006 11:30 AM
Launch Control problem... 1st gear rev limit...please help vipernj Engine Management & Tuning 20 10-19-2005 10:08 AM
