Old 08-26-2011, 12:26 PM   #1
Above and Beyond
Member#: 186176
Default EJ20G Idle Air Control Motor
Where can i find a replacement Idle Air Control Solenoid for a first generation EJ20G. Part number 22650AA072
Do any USDM subaru's rock these? SVX?
-Thanks
William
Above and Beyond is offline   Reply With Quote
Old 08-26-2011, 02:14 PM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
They are all the same except the angle of the air supply pipe. Try EJ22E and EJ25D they all came with a straight air inlet pipe maybe you can use a few small elbow hoses?
Marnix is offline   Reply With Quote
Old 08-27-2011, 04:39 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
The valve part never goes bad it just gets gummed up, clean the valve and just swap the top electrical part with any common usdm one.
Idle Air Control Valve: Anyone had this replaced? IceClimber Service & Maintenance 7 04-04-2015 05:33 PM
WTB: Idles Air control motor 03' WRX Crazykev Private 'Wanted' Classifieds 2 07-17-2006 03:58 PM
Idle Air Controller Yotsuya Normally Aspirated Powertrain 15 06-27-2004 07:56 PM
Idle Air Controller SubaruImpreza_power Normally Aspirated Powertrain 3 09-19-2003 02:04 PM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
