Old 08-27-2011, 12:47 PM   #1
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Default Cobb accessport map
Hi
I run a ap stage 1 91 octane on my wrx 11
So far everything as been sweet. Lunch control as been set to 3500 rpm so I won't go too far while I'm stopped.
My problem is today, I was at a light, I press the gas a little too hard while I'm at a complete stop and the car rev pass 5000
My question is, how can I be sure what map I run if the Cobb it not connect to the car. I know the ap add power ( about 10%) but for everyday is some what subtle.
I really don't what to have any cable floating around in my car. So I won't ever leave it connect
Thanks for the input
Syrius78 is offline   Reply With Quote
Old 08-27-2011, 01:07 PM   #2
Cobb Tuning
Member#: 4803
Originally Posted by Syrius78 View Post
Hi
You can view the current reflash and realtime maps via the Tune -> Show Current Map menu on the AccessPORT.
Keep in mind that launch control will not be active if the clutch is out. So, if you were in neutral and had the clutch out, it will not come into play.
Also, your LC and FFS thresholds set via the AccessPORT can be reset to the default if you reflash a new map, reset the ECU via AccessPORT or disconnect the car's battery. The default RPM thresholds for our OTS maps is to disable both of these features. If this happens because you performed any of the above operations, simply go back into the AccessPORT and change your LC and FFS thresholds to what you desire.
Bill
Old 08-27-2011, 01:13 PM   #3
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Thanks for the quick input
I may have been in neutral, will check on my next run.
Thanks a lot
Old 08-27-2011, 10:57 PM   #4
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
I test drive it and here what i've done
I reflash the stage 1 91 map, then i change the lunch control to 3500 rpm and press ok. Then i shut down the car, unplug the AP. I start the car, remove the parking brake, put the car in 1st gear, the clutch pedal is on the floor, and i tap the gas. I went to 5000 rpm right away.
I don't understand why it's not working.
When the ap is connected to the car, no problem with lunch control, it's working fine.
Do you have any idea?
Old 08-28-2011, 08:12 AM   #5
Cobb Tuning
Member#: 4803
When you reflash a map, reset the ECU or disconnect the car's battery, you will have to start the car first before setting the LC/FFS thresholds with AP. It is only that first start after doing any of the above operations. Otherwise, you can set the LC/FFS thresholds at any time with AP with the engine on or off. The AP does not have to be connected for LC/FFS to work.
Bill
Old 09-06-2011, 07:29 PM   #6
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
I try your method step by step and it did not work
But I found a way to make it work. I install on my pc you racetuner software, load the stage 1 91 octane map, but change only one thing, the lunch control at 3500.
I install the map and everything seem perfect.
Thanks fort he help
Old 11-03-2011, 11:58 PM   #7
BlackBeautysti
Member#: 299433
2008 Subaru STI
Black Paint Black Rims
Thanks fort he help
Do u know how to change maf calibration ?
BlackBeautysti is offline   Reply With Quote
Old 11-21-2011, 07:59 PM   #8
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Nope
Way to advance for me, sorry
Anyone heard of the map STI pink 2.0l VF39 map for the cobb accessport? iloveboost93 Newbies & FAQs 10 02-26-2011 10:15 PM
cobb accessport map help mogrl840 AccessPort 6 03-06-2007 03:55 PM
cobb accessport w/vf34 map 04wrx555 Member's Car Gallery 2 01-25-2005 01:04 PM
Older revision Cobb Accessport Maps crazymikie Engine Management & Tuning 11 01-22-2005 07:08 PM
Revised Cobb STi AccessPORT Maps Available dsmperformance Engine Management & Tuning 7 10-08-2004 04:23 PM
