Old 08-27-2011, 09:16 PM   #1
rexxless
Member#: 292703
2003 wrx
psm
Default NEED HELP auto to manual swap 02 wrx
i have a 02 wrx and i spun a rod, long story short i picked up a whole parts car that was totaled in the front. its manual and the car is complete, i am not worried about the time it will take nor the cost, what is the easiest was to go about this. are the holes already there for the pedals, shift linkage, any cutting on chassis, or is it a simple bolt together swap ecu and wiring harness?? thanks for the help
rexxless is offline   Reply With Quote
Old 09-05-2011, 01:39 PM   #2
Tatmana
Member#: 112248
04 STI
Mechanical part is easy. Everything bolts in. Wiring can be a pain.
Tatmana is offline   Reply With Quote
Old 09-08-2011, 10:54 PM   #3
rexxless
Member#: 292703
2003 wrx
psm
what wiring do i need to do? will the auto harness work for the whole swap or do i need to cut and spice the manual trans harness to fit the auto,
anyone that has done this please add any tips
Old 09-09-2011, 04:54 AM   #4
sc00by4life
Member#: 97135
so you blew the motor in your car, then bought another car that has been totaled in the front, which very possibly includes engine damage, but you also want to swap transmissions? So you bought a whole car, just to swap transmissions? This is extremely confusing. Long story short, bugeyes are a dime a dozen. sell them both and buy a manual.
Old 09-09-2011, 06:28 AM   #5
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
1....you dont cut and splice subaru harnesses.
2....removal of the dash makes installation alot easier
3....the ecu isnt the same for 4eat/5 speed transmissions
4....good luck
MY EJ20TTTTTT is offline   Reply With Quote
Old 09-10-2011, 10:54 PM   #6
rexxless
Member#: 292703
2003 wrx
psm
Iscored the cylinder on the old motor, picked up the loaner car for practicly nothing, i pulled the loaner cars motor and everything checked out good at a machine shop. I have the pedals in,the trans and rearend in. Almost done I just need to figure the wiring to the trans,
Old 09-16-2011, 12:28 AM   #7
tyler_s18
Member#: 239496
i did a auto to manuel on my 93 and swaped everybit of wiring from the manuel car and never had to look at a diagram or cut anything. i pulled the dash and full interior then swaped EVERYTHING
tyler_s18 is offline   Reply With Quote
Old 09-16-2011, 12:16 PM   #8
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
I would swap the vehicle harness from the donor car. No guesswork. Everything will work as designed.
jake
KONKILR is offline   Reply With Quote
Old 09-16-2011, 01:56 PM   #9
kaos200
Member#: 2692
4....good luck
Sorry EJ20T, just need to clear up your post really quick, perhaps you knew it but weren't being specific.
1) Yes you do, just not necessary in his case.
2) This is necessary to replace your auto harness with the MT harness
3) Yes it is. Just a different ROM flashed into it. Since you have it just swap it over unless your ecu is flashed, then depending on what you have you'll need to do some further tuning.
4)
Rexxless, swap over the entire dash and related engine harnesses etc and you will be fine.
kaos200 is offline   Reply With Quote
Old 09-16-2011, 02:05 PM   #10
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
there's some information compiled in the thread I made when I did my swap:
http://forums.nasioc.com/forums/show....php?t=2185645
todeswalzer is offline   Reply With Quote
auto to manual swap 2.5i help 07impreza2.5i Subaru Conversions 0 11-17-2009 04:01 PM
Need Help!! Auto To Manual In 98 Impreza neversummer489 Transmission (AT/MT) & Driveline 2 09-08-2008 10:39 AM
Auto To Manual On 94 Wrx Swap 95lwrx Subaru Conversions 9 10-10-2005 11:47 AM
Cost of auto to manual swap? Sobelizard109 Transmission (AT/MT) & Driveline 9 12-11-2001 06:10 PM
