Old 08-28-2011, 06:45 PM   #1
failchawi
Member#: 291461
2005 Sti
Stage 2 Cobb
Default Fine knock learn issue
Guys whenever my calculated load (g/rev) is below 1, my fine knock learn is -8.75, is that normal? other than that it stays at 0, but there is the odd time it'll stay at 0 with very little load.. Now i'm even more confused because i thought i understood the relationship between the two. But that aside, if it is an issue, how to i remedy it?
failchawi is offline   Reply With Quote
Old 08-28-2011, 07:26 PM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
This can be caused by multiple things. You could have experienced some bad gas. If this happened, and the low load timing + cam advance were each high, this can happen.
If the car was hammered on and the re is scoring or scaring in the actual cylinders, this can be another reason.
Broken ringlands also can set the knock sensor off during low load cruise.
Reset the ECU. See if it comes back. If it does, do a compression and leak down test. If they check out, have a tuner check/recheck the car out.
-Mikey
STi Mikey is offline   Reply With Quote
Log with Fine Knock Learn? wrx904 AccessPort 5 08-24-2011 11:10 PM
i am getting the same fine knock learn at the same rpm everytime? dudenhoeffer02wrx Newbies & FAQs 2 08-08-2011 01:39 AM
feedback knock and fine knock learning??? please explain. dudenhoeffer02wrx AccessPort 3 07-28-2011 11:55 PM
constant fine knock learn? olazy AccessPort 5 05-24-2011 11:53 AM
Fine Knock Learning in ATR Tripintaz AccessPort 5 10-01-2010 09:31 AM
