#1 |
Member#: 287657
NESIC
Vehicle:1997 Impreza Outback Blue |
I've got a 97 outback sport with the 2.2 (stock) and I've been trying to think of anything to do to get more power without doing a swap or a turbo kit or anything as my budget is limited as is my knowledge. Would swapping on 2.5 heads give a bit more power? The motors in the 2.5RS's are pretty much the same block with different heads right? If so how much would this cost me? How difficult is the labor? Thanks!
#2 |
Member#: 141373
E. Canada
Vehicle:2008 2.5i-hatch - now with a HID retrofit |
Here's a head/block chart for you:
http://www.b4et.com/docs/cr_matrix.pdf AFAIK, you have a EJ22E with a 9.7:1 CR. Doesn't seem like you have a lot of head options... |
#3 | |
Member#: 287657
NESIC
how about doing a lighter-weight flywheel and better-than-oem clutch, would that give me more accleration? I think my clutch is slipping so I probably have to do a clutch in the future anyway. |
#4 |
Member#: 3409
NWIC
Vehicle:1998 Ram 2500 Green. |
lightweight flywheel and pulleys will definitely help with acceleration, but you'll also notice that your car will slow down more on hills unless you get into the throttle more.
#5 | |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
#6 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
While the 2.5l heads will increase your ability to breath, it will steal away more than a point of compression. Only if you were going to turbo or supercharge your engine would I change to 2.5l heads. And then the only option would be DOHC Ej25D heads from 1996-1999(only on certain models in 1999).
You are better off getting a set of Delta cams and some headers. Also, look down the page a couple of threads to the High Compression Frankenstein thread. Cheap power on the Ej22e comes from changing to the 2.5l block, not the 2.5l heads... |
#7 | ||
Member#: 287657
NESIC
#8 |
Member#: 3409
NWIC
#9 |
Member#: 832
RMIC
Afredo,
Delta cams are less than $200 last time I checked. They will want your core cams back once you install theirs. |
#10 |
Member#: 287657
NESIC
How difficult is a cam installation? Do I have to replace the lifters or valves? Will I have to get a reflash for the computer to recalibrate for the new cams? Got any links for where to get these? Thanks!
#11 |
Member#: 832
RMIC
Just google Delta Camshaft. I think they are also a site sponsor.
Installation isn't much more difficult than doing the timing belt. You do have to remove and reinstall the rocker arms. Doesn't change the valves. Doesn't require any changes to the ECU. |
#12 |
Member#: 287657
NESIC
they asked me what style of rocker arm I have, flat or roller style?
| Thread Tools | |
| Display Modes | |
| WTB : 2.5 short block or long block for 97 outback | 93stiImperza | Private 'Wanted' Classifieds | 4 | 06-21-2011 11:56 PM |
| 2.5 head swap | Charles Nobis | Normally Aspirated Powertrain | 0 | 12-02-2010 10:18 PM |
| 2.5 head swap | robert4342 | Newbies & FAQs | 0 | 12-13-2009 10:38 AM |
| WRX turbo in 97 Outback sport? | Brewmaster | Factory 2.0L Turbo Powertrain | 1 | 08-05-2003 01:29 PM |
