Old 07-31-2002, 05:59 PM   #1
imprezive
Member#: 746
Default 30k maintence help.
I'm trying to be cheap so I'm gonna be doing most of my 30k tune up myself. but I haqve to questions.
1) How do I change the fuel filter? (pictures would help me too)
2) Should I have a proffesional check out my belts? or should I just pull on them and if they are tight and not cracked just keep them. (I'm having a pro change my brake fluid. I don't want to screw that up)
Any other advice for a beginer mechanic.
imprezive is offline   Reply With Quote
Old 07-31-2002, 06:01 PM   #2
imprezive
Member#: 746
oops wrong forum. could a moderator please move this to service and maintence.
thank you
Old 07-31-2002, 08:48 PM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
replacing the fuel filter is easy.
It's the thing sitting next to the windshield washer reservoir. When you look at your new fuel filter, you'll see..
You remove the tubes, remove the filter, and put the new one in, put the tubes back in..done
watch out tho, cuz there'll be some fuel coming out from the filter and the tubes
-vic
cRayZee is offline   Reply With Quote
Old 07-31-2002, 09:51 PM   #4
Basshead
Member#: 112
2011 Jetta TDI
everything is really easy..i did my 30k myself and spent about 130 on parts and a fwe hours of my time..not bad at all i say...fuel filter is black and next to your driver side shock tower in engine compartment..belts are as easy as loosening a few bolts, which takes the tension off, and swapping them out...
Basshead is offline   Reply With Quote
Old 07-31-2002, 11:39 PM   #5
obyone
Member#: 16523
I removed my gas cap and left it off for half an hour (while I changed my tranny and diff oil) and that released the presure from the lines. (or at least I think it did because there was no presure at all.) But it was simple except for the fact that one of the lines was practically welded onto the filter. I had to end up cutting the line, as close to the filter as I could, and then install the new one. Had that one line not been such a PITA to remove, I would've been done in 15 mins. It had to be the last one I tried didn't it?.
obyone is offline   Reply With Quote
Old 08-01-2002, 06:03 PM   #6
imprezive
Member#: 746
How do I know if I should replace the belts?
Old 08-01-2002, 06:41 PM   #7
jeffg
Member#: 2958
2001 WRX (GC8)
does anyone have a list of all the things that should be done on a 30K service?
J
jeffg is offline   Reply With Quote
Old 08-01-2002, 07:58 PM   #8
NYCshopper
Member#: 5126
J
http://205.137.197.54/owners/care/sc...sp?pageID=2001
click on link on the bottom
NYCshopper is offline   Reply With Quote
motor swap help STI longblock into a Legacy gingertooth Legacy Forum 6 06-01-2010 09:16 PM
Hey guys time for 30k maintenance- help me do it? marc10 New England Impreza Club Forum -- NESIC 20 03-25-2010 08:05 PM
did an oops B4 30K service! help!! zmaster Mid West Subaru Owners Club Forum -- MWSOC 7 09-05-2005 09:15 PM
Did a oops b4 30K Service!! Help zmaster Service & Maintenance 8 09-05-2005 08:59 PM
30k service- Do the Subaru Manuals Help?? DownSouth Service & Maintenance 2 11-28-2001 10:46 AM
