Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 08-29-2011, 11:59 PM   #1
Chrisgst99
Member Sales Rating: (2)
Member#: 175338
I purchased this top of the line Impreza Wrx 5 years ago from United Auto Sales with 22000 miles. I am the second owner of this car from a recent trade-in from a well taken care of, rarely driven lease of the previous owner. I have been thru numerous modifications over the years to mod my car to go faster but over time have never been satisfied, so i needed more power From a evo III 16g, to FP 18g, and currently a Blouch Dominator 4.0 XTR. I have invested more than $19,000 into the car and now its the end of the road. I have a family of 3 to take care of and I'm trying to buy a new house so this car is a variable that I no longer need. The car has 74000 original miles and 4000 miles on the new engine and about 15000 on the built tranny. The STI swapped EJ257 long-block was built and fitted with forged pistons, rods, and bearings, and Head work was done. This install was done February of 2010 from Agile Automotive, the transmission was built from Andrewtech 3 years ago and was fitted with PPG straight cut 1-4 gearset with brand new synchros which is essentially bulletproof. Motor was tuned on a conservative break in map by hill at Agile for 386 whp/400wtrq, I have not had a chance to take it back for a more aggressive tune. I lost major interest in the car from unnecessary finances with all this money and time invested. After it is all said and done, this car has turned from what was an addiction for an all show and go hobby turned lifestyle and now I regret it and I have far more important things to take care of so my car is up for sale.
The car is in outstanding shape inside and out, the engine maintenance on the car was well maintain with Motul 8100 5w30 fully synthetic engine oil and red-line shock proof transmission fluid, oil was changed when due at 3000 miles. all the motor work was done by Agile Automotive and the transmission was serviced by andrewtech, they both can vouch for the car. I have most of all the invoices from the work that was done, to show how much money was well spent..
Below is the mod-list and pictures...
ENGINE:
*Internals mods/ things done
Cosworth main bearing set, tri-metal, size 0, for Subaru EJ20/EJ25
Cosworth rod bearing set, tri-metal, size 1, for Subaru EJ20/EJ25
New cryo-treated crankshaft for STi EJ257
Eagle connecting rod set for EJ20/EJ25
Mahle piston set for STi/LGT, 100mm bore, 8.1/1 compression ratio
Subaru STi 11mm 2.5L Oil Pump
Subaru USDM 04-06 STi gasket and seal kit
Subaru oil cooler
ARP head studs
degrease block, and oil pan
re bore and hone 4-cylinder block
check rod and main bearing clearances
check cylinder alignment & main bearings
--Head work--
exhaust valves for STi
intake valves for STi
lap valves for one cylinder
degrease cylinder heads
sonic clean cylinder heads
degrease and polish cams
cylinder head surfacing
glass bead cylinder heads
clean and polish cam journals
TGV deletes
*Transmission
Synchronizer Kit for PPG Gearset
1-4 Straight Cut Synchro Engagement Gearset for Subaru
ACT HD Clutch Kit 2002-2005 WRX With 6 Puck Sprung Disc-SB3-HDG6
*external engine mods
Blouch Dom 4.0 XTR 3in inlet / 10cm2
38mm tial wastgate
Steal turbo oil line
850cc fuel injectors
255 walbro fuel pump
Turbo XS front mount intercooler
Turbo XS RFL bov
Perrin WRX/ STI 3inch Inlet Hose black ply 5
Perrin Big MAF intake
AP WRX/ STI Aluminum pitch stop mount
Hallman boost controller
06 wrx radiator
Perrin radiator heat shield
Helix bell mouth 3" down-pipe
HKS high power Cat-back exhaust
Snow performance methanol kit (not installed)
*Engine management - Custom Utec/Access-port tune HILL @ Agile Automotive
*Suspension
Tein S. Tech Springs
Tokico Racing Struts
Front Upper Sway Bar
Rear Upper Sway Bar
Front Whiteline Lower Sway Bar
Rear Whiteline Lower Sway Bar
*wheels/tires
Rota SVN 18" bronze
Nitto 235/40ZR18
oem 16" rims w/tires
*Body
New paint job about two months old
New JDM headlights with 6K HIDs
New front JDM style Lip
New JDM style rear Aprons
OEM foglights 3k HID's
also have OEM wing
*Interior
Pioneer Head Unit
HKS Turbo Timer
Turbo XS Map Selector/Launch Control
AEM Wide Band Gauge
Center Pillar Gauge cluster
After Market Shifter knob
Racing Short Shifter Kit
asking 13,500
These are a few mods that i have collected throughout the years. If you are very Interested in my car, please give me a call / text
@ 302- 897-0255 ... thanks for looking
Chrisgst99 is offline   Reply With Quote
Old 08-30-2011, 12:00 AM   #2
Chrisgst99
Member#: 175338
Old 08-30-2011, 12:01 AM   #3
Chrisgst99
Member#: 175338
Old 08-30-2011, 07:07 AM   #4
Padge
Member Sales Rating: (8)
Member#: 74412
'05 Impreza WRX STi
Obsidian Black Pearl
Free delaware bump. If you are ever looking to part any of it out please let me know.
Best of luck.
Padge is offline   Reply With Quote
Old 08-30-2011, 08:25 AM   #5
Chrisgst99
Member#: 175338
thanks man.
Old 08-30-2011, 10:04 AM   #6
wrxtuner13
Member Sales Rating: (4)
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
still have the pitching stop?
wrxtuner13 is offline   Reply With Quote
Old 08-30-2011, 10:16 AM   #7
Chrisgst99
Member#: 175338
Yeah its on the car
Old 08-31-2011, 04:50 PM   #8
Chrisgst99
Member#: 175338
Bumpp
Old 09-03-2011, 01:43 AM   #9
Franks
Member Sales Rating: (5)
Member#: 276872
no l no longer a sub
no longer a subie owner
Glws, trade me <3
Franks is offline   Reply With Quote
Old 09-03-2011, 12:36 PM   #10
Chrisgst99
Member#: 175338
Thanks man, LOL
Old 09-06-2011, 09:13 PM   #11
Chrisgst99
Member#: 175338
Tonight bump
Old 09-07-2011, 12:35 PM   #12
RLR257
Member Sales Rating: (1)
Member#: 176667
2006 AW WRX Ltd
PPG'd EWG'd & Dom3'd(XTR)
bump for my boy's bugeye
RLR257 is offline   Reply With Quote
Old 09-07-2011, 01:03 PM   #13
smokey07
Member Sales Rating: (3)
Member#: 151683
car is just like my buddy's old bugeye, agile built, 380+whp, ppgs...
I know this car has to rip, and Agile builds a good motor. glws.
smokey07 is offline   Reply With Quote
Old 09-24-2011, 08:00 PM   #14
Chrisgst99
Member#: 175338
Thank, the car does rip.
Old 09-26-2011, 10:09 AM   #15
Chrisgst99
Member#: 175338
Monday bump. Any offers car needs to go.
Old 09-26-2011, 09:58 PM   #16
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Where did you get your paint job done? is it still mbp?
FastAdams is offline   Reply With Quote
Old 10-20-2011, 02:08 PM   #17
Chrisgst99
Member#: 175338
Lowered price!
Old 11-15-2011, 04:31 AM   #18
G0DSPEED
Member#: 301022
2004 WRX
Java Black
Bump for a sexy build. Good luck with sale!
G0DSPEED is offline   Reply With Quote
Old 11-15-2011, 06:07 AM   #19
ImNOrobo
Member Sales Rating: (44)
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Free bump. I sent a buddy a link to your car. Where are you located? He is very interested. Thanks.
ImNOrobo is offline   Reply With Quote
FS : DE: 2002 Subaru Impreza WRX EJ257 & PPG's Chrisgst99 Private Vehicle 'For Sale' Classifieds 47 11-09-2011 07:28 PM
FS : DE: 2002 Subaru Impreza WRX, VF39 swap. Need to Sell FAST! 8,900 OBO BUGEYEFOREVER Private Vehicle 'For Sale' Classifieds 24 05-31-2011 10:00 AM
FS : PA: 2002 Subaru Impreza WRX blue & silver twotonedsubaru Private Vehicle 'For Sale' Classifieds 3 10-30-2010 03:10 PM
FS : PA: 2002 Subaru Impreza WRX blue & silver twotonedsubaru Private Vehicle 'For Sale' Classifieds 0 08-26-2010 07:59 PM
FS : GA: 2002 Subaru Impreza WRX Motor & Tranny HKSTuner Engine/Power/Exhaust 11 07-24-2010 11:20 AM
