Old 08-30-2011, 10:54 AM   #1
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
Default Paint Thickness Gauge Help
I need help finding a good paint thickness gauge that isn't going to cost me a crap load. Does anyone know of one or have one. Thanks
06legacy555 is offline   Reply With Quote
Old 08-30-2011, 10:57 AM   #2
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Screwdriver and a ruler?
Psychoreo is online now   Reply With Quote
Old 08-30-2011, 11:27 AM   #3
rwdCivic
Member#: 155986
E92 M3
Jerez
rwdCivic is offline   Reply With Quote
Old 08-30-2011, 12:44 PM   #4
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
Thanks. Im new to the detailing world and i think one of these is a must have. Is that true?
Old 08-30-2011, 02:06 PM   #5
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
I wouldn't say that it's a "must have". 90% of detailing companies probably do not have one. Do you plan on doing a lot of wet sanding?
MattTHEpainter is offline   Reply With Quote
Old 08-30-2011, 09:57 PM   #6
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
No I would be using it for checking respray cars to make sure the paint is thick enough to compound.
Old 08-31-2011, 04:21 AM   #7
xCONWRATHx
Member#: 175840
2005 LGT Wagon
1999 Sentra SE-L
IME re-spray cars are always thick enough to compound. OEM paint is what you have to worry about, generally it is MUCH thinner and will usually have more potential to have been previously buffed and consequently thinned.
But then again the term 'compound' is rather vague, and probably means different things to each of us. Compound refers to a chemical but it is really the application process that would determine the amount of material removed. Compounding by hand? Compounding by DA with a foam cutting pad? Compounding by rotary with a twisted wool pad? All of these methods would yield drastically different results with a comparatively large difference relative to amount of material removed.
FWIW I use a Highline meter as was linked to above, and don't have any complaints about it. It's very affordable and works without a hitch. I suppose the only 'issue' I have with it is that it only reads on steel and aluminum (so you're flying blind on all plastic bumpers and trim, the areas most likely to have been replaced and repainted). But you won't be able to find a meter that reads on composites in the sub $1000 category. I would also appreciate being able to see the thickness of each film layer (e-coat/primer, base, clear), but that's even MORE money.
xCONWRATHx is offline   Reply With Quote
Old 08-31-2011, 01:58 PM   #8
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
I am using a DA with foam and micro-fiber pads( Meguiars Corrections System). The Highline meter sounds like the one I would buy. You are very right about the bumpers. I never thought about that and today most cars have plastic bumpers. Thanks for the reply
FS : Defelsko Positest DFT Coating Thickness Gauge <subywrx> Non-Subaru Stuff 2 03-24-2011 05:47 PM
FS: painted triple gauge pillar pod - $25. painted triple gauge clock pod - $30 cah Interior/Dressup/Audio & Security 7 09-18-2007 06:10 PM
Subaru Paint Thickness sleestacks Interior & Exterior Modification 5 03-30-2007 01:28 PM
colour and paint thickness? mr_yellow General Community 4 08-30-2003 02:47 AM
Painting a-pillar gauge pod cmos9 Interior & Exterior Modification 2 01-13-2003 03:24 PM
