Old 08-30-2011, 06:49 PM   #1
joshjames
Member#: 233604
2011 WRX P.
Default 2011 WRX Alarm Issue.. Total Joke? Read on...
So I was fiddling in the driveway today and thought to myself "I wouldn't even know what this alarm sounded like if it went off...let me see". So, I tested it.....
left the drivers window slightly down (enough to barely reach in), closed the doors, and pushed the button to lock/arm the system (it beeped). I then reached through the window (as if I found it ajar, forced it down or broke it), manually flipped the lock and opened the door...NOTHING. It even started right up.
Am I missing something about the function of these systems? Or does that indeed sound a little strange? Or does the key fob emit RFID to let the car know it's you ?(didn't think so for Subaru). I have never owned a car with any sort of alarm or security system that allowed you to do that.
Any ideas input on what it takes to set this thing off? I know I sound like a bit of a newb, but I just can't believe it.
joshjames is offline   Reply With Quote
Old 08-30-2011, 06:50 PM   #2
jrank3792
Member#: 219756
06 WRX TR
Mine goes off when I do that. Mine even goes off if you lock the car with the fob, then unlock it with the key haha
jrank3792 is offline   Reply With Quote
Old 08-30-2011, 07:22 PM   #3
wayward167
Member#: 253998
13 BRZ
Yeah mine too....I've sat inside and locked it with the fob...
Opened the door and it went off.
Nvr tried to start it at that point.
wayward167 is offline   Reply With Quote
Old 08-30-2011, 07:55 PM   #4
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
You have to wait until the system actually arms. Default is a 20 second delay but it can be adjusted (by the dealer) to up to 90 seconds. When you "arm" the system by locking the doors with the keyfob look at the security light in the gauge cluster, it should be doing a fast double flash. Wait until it starts doing a single steady flash which means the security features are set, then try your test.
Opie is offline   Reply With Quote
Old 08-30-2011, 08:01 PM   #5
joshjames
Member#: 233604
2011 WRX P.
aha..I will give that shot..thank you for the detailed info.
I wonder why the delay is used? Because people often lock/unlock or go right back to the car maybe?
Old 08-30-2011, 09:03 PM   #6
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Not sure why but the default is 30 seconds on stock navigation-equipped models.
Mine goes off if I lock it with the remote, manually unlock it with the key, and open the door. I guess that's in response to people who are able to fashion some kind of master door key?
furiouswrx is offline   Reply With Quote
Old 08-31-2011, 10:41 PM   #7
joshjames
Member#: 233604
2011 WRX P.
If by "master door key" you mean a screwdriver and a hammer, then yes.
Lock tumblers are probably the weakest part of any sort of security.
Old 09-01-2011, 12:07 PM   #8
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
I usually keep my keys in my back pocket, and it seems like whenever i sit down it pushed the alarm button (for me i just hold down the lock button) and it takes me forever to turn it back off. Its soo loud with the hellas too.
DSRX2005 is offline   Reply With Quote
Old 09-02-2011, 09:00 PM   #9
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
ive had a different issue where ive tried to unlock my car with the key fob but the car just doesnt respond. had to open the car with the key (alarm went off), then starting the car with the key shut the alarm off. not sure what the issue is/was because the alarm and key fob have worked fine ever since (this was over 6 months ago) so im not sure a key fob battery is the culprit.
guess its better than the stock alarm i had in my integra. i washed my key fob in the washing machine once, car was armed. opened the door, alarm went off, but wouldnt quit and the engine was disabled (wouldnt start). i had to unplug the battery and bypass the alarm box by moving some connectors around, great security! didnt even have to cut any wires, it was plug and play lol.
gsrcrxsi is offline   Reply With Quote
2011 wrx overheating issue, help please THE_SMURF Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-01-2014 09:32 PM
2011 WRX Hesitation Issue at Full Throttle jpinto516 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 06-08-2011 01:50 AM
2011 WRX supply issues? DAC17 General Community 5 04-18-2011 06:27 AM
2011 WRX turbo issues. . . maybe??? THE_SMURF Warranty Issues & SOA Problems 27 04-09-2011 08:03 PM
2011 WRX HVAC issue...? blindgoldfish z Electrical & Lighting 19 01-01-2011 12:36 PM
