Old 08-31-2011, 12:53 AM   #1
Mr.Minney
Member#: 214892
1999 Legacy
red
Default Interchangeable ecu for ej20g?
I have an ej20g from a 96 wrx wagon and from my understanding it seems to be a better idea to find a newer compatible ecu for this engine. So now I'm curious as to what ecu would be a good option for this? By the way this is going into a usdm 99 legacy gt.
Mr.Minney is offline   Reply With Quote
Old 08-31-2011, 12:54 AM   #2
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
powerfc get full tune
Imprzaboy89 is offline   Reply With Quote
Old 08-31-2011, 10:17 AM   #3
Mr.Minney
Member#: 214892
1999 Legacy
red
Where can I find those at? Also, how much does it normally cost to get a full tune?
Old 08-31-2011, 11:45 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Newer and compatible don't exist. If you want a better factory ECU for your car, you want either a Z4 from a sedan or a 6K ecu from an STI. Those are both contemporary to your car but higher powered. However, they are designed for use with the td05 turbo. You have a td04 turbo on your car unless you have upgraded it. I would upgrade the turbo before doing anything else. And then what I would personally do is get bigger injectors and a Rob-tune chip installed on your stock ECU. It's a better approach than finding a replacement ECU or messing around with a standalone.
Old 08-31-2011, 04:53 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Don't get a power fc. They don't have knock control. Get bad gas and it's all over.
You can use the Z4, Z5 or 6K ecu with a tdo4, but you need a mbc. It would be better to upgrade to a td05
The chip from rob and 550cc injectors is the best bet unless you plan on more than 300 whp.
Old 08-31-2011, 06:34 PM   #6
stangod
Member#: 148743
02 WRX & 99 RSTI
Sedona
He doesn't have an ecu or wiring harness yet, just the motor. Would you still go with the old ecu's and chip? He is looking to buy an ecu and harness to merge with his car.
stangod is offline   Reply With Quote
Old 08-31-2011, 06:38 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Depends on the person then.
If he's the kind of guy who can do his own wiring and tuning a standalone makes sense
If he's the kind of guy who sends out wiring to be done and wants a plug it in, forget about it and go solution, go with a chipped stock ecu.
Old 08-31-2011, 06:55 PM   #8
stangod
Member#: 148743
02 WRX & 99 RSTI
Sedona
I though it would be easier to get like an sti ecu and harness and merge that(I didn't know if that would work or not). For tuning, cost, wiring, ect...I would definately take what munson and 360 say to be the best route.
Old 08-31-2011, 07:13 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
USDM STI? That won't run an EJ20G
Old 08-31-2011, 10:04 PM   #10
stangod
Member#: 148743
02 WRX & 99 RSTI
Sedona
See that is why I deferred to you. So, the only tuneable options are a stand alone or ???(jdm sti after 99)??? or go with oe and get a rob chip?
I am not thread jacking but are you the same 360 on romraider with 02 wrx tunes?
Old 09-01-2011, 02:04 AM   #11
Mr.Minney
Member#: 214892
1999 Legacy
red
Huh? I definitely don't know what you're talking about on that one. So where are you guys tailing about exactly when it comes to the rob chip? I haven't heard anything about these.
Old 09-01-2011, 11:06 AM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
Standlone or chipped ecu.
Yes that is me.
Old 09-01-2011, 04:06 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
he has a 96G .. intake under manifold
but since he has no harness it really doesn't matter ...
sell the engine to some unlucky person and get a complete setup
Old 09-06-2011, 12:56 AM   #14
Mr.Minney
Member#: 214892
1999 Legacy
red
But would it really be that difficult to just find what I need? I still would like more information about the rob chip also.
Using an EJ20G ECU or EJ20G pinned standalone in place of EJ22T ECU impreza_GC8 Pre-2002 Factory Turbo Powertrain 3 10-30-2009 07:37 AM
ej20k ecu swap for ej20g ecu lJlDlMl Subaru Conversions 2 09-12-2009 11:04 AM
FS: ApeXi Power FC ECU for ej20g xtian 1993 - 2001 Impreza Specific Parts 10 02-14-2008 08:40 PM
FS: ApeXi PowerFC ecu for ej20g xtian MWSOC Private Classifieds 2 02-14-2008 07:51 PM
Mines flashed EJ20G ecu, and ej20G engine harness liberty2000rs Engine/Power/Exhaust 1 10-31-2006 12:54 AM
