Old 08-31-2011, 12:54 AM   #1
Isoh
Member#: 292691
2012 WRX
World Rally Blue
Default Removing intake silencer
Hey everyone. I have a 2011 wrx and i was interested in removing the intake silencer so that my car has a better sound to it. Some people say by doing this you are losing horsepower and some say that is false so what is the real answer. Also if im planning on doing this what is the correct way to do it. Do i just take off the silencer and leave the hole there or do i cover it. Thanks
Isoh is offline   Reply With Quote
Old 08-31-2011, 12:57 AM   #2
lude4life13
Member#: 255027
2003 WRX
I did it and noticed no difference on my 03 WRX
lude4life13 is offline   Reply With Quote
Old 08-31-2011, 01:36 AM   #3
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
I would buy a after market intake
subaru_sti_steve is offline   Reply With Quote
Old 08-31-2011, 01:53 AM   #4
Isoh
Member#: 292691
2012 WRX
World Rally Blue
I was going to buy and aftermarket one but i read the intake thread and it said its better overall to leave the stock one so i was planning to just leave it and just delete the silencer so i get the cool "wush" sound from the bpv.
Old 08-31-2011, 01:58 AM   #5
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
You'll be surprised to learn that your car does not have an intake silencer.
Different car, different motor, different everything.
Stop giving advice.
XanRules is offline   Reply With Quote
Old 08-31-2011, 02:05 AM   #6
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
i removed my silencer. and so far, im glad i did that then buy an aftermarket intake. intake sounds dope and removing the silencer cost me nothing. id rather do that than spend 200 on an intake that will do nothing but make my car sound the same as it is now
filipin0y is offline   Reply With Quote
Old 08-31-2011, 02:06 AM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
The 2011 WRX does not have an intake silencer.
Old 08-31-2011, 02:08 AM   #8
Isoh
Member#: 292691
2012 WRX
World Rally Blue
Thanks for the info xan. So if i would like my bpv to be a bit louder, what should i do?
Old 08-31-2011, 02:10 AM   #9
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
TBE helps a little, maybe intake and inlet.
Naturally these need to be tuned for.
Old 08-31-2011, 02:24 AM   #10
Isoh
Member#: 292691
2012 WRX
World Rally Blue
So that means i need to buy an aftermarket intake? but the intake thread was saying all these bad things about buying one .
Old 08-31-2011, 02:27 AM   #11
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
If you tune for it, you're fine. But then baibai warranty.
If you JUST want additional noise with minimum warranty hassle, an aftermarket recirculating BPV may be the way to go, though I'm not sure how much of a difference they make. I'd recommend a Forge.
Old 08-31-2011, 02:46 AM   #12
Isoh
Member#: 292691
2012 WRX
World Rally Blue
and this aftermarket bpv will not require a tune or mess up the air to fuel ratio correct?
Old 08-31-2011, 04:30 AM   #13
USAF Harris
Member#: 285953
2008 Impreza WRX
Dark Grey Metallic
I'm wondering what everyone has been taking off since the silencer doesn't exist, probably their air filters.
USAF Harris is offline   Reply With Quote
Old 08-31-2011, 04:53 AM   #14
dremersvision
Member#: 141272
Not sure about the newer years but inside the fender was a black box and if my memory serve me correct, you had to remove 3 8mm bolts with a socket set. Once removed you can hear the turbo spool easier.
If you recirculate your BPV then no, it will not mess with your AF ratio but if you vented to atmosphere then it would mess with your AF ratio when you shift and no you can not tune for metered air that just dissapears after the ECU already compensated for it. Hope that make sense.
dremersvision is offline   Reply With Quote
Old 09-01-2011, 02:49 PM   #15
MacMan
Member#: 27959
2010 WRX Prem 4-door
Default Intake Mod
Hi Isoh,
I had the exact same problem as you. I wanted to hear my intake, but didn't want to tune and lose my warranty. I made a solution. What I did was buy a drop in K&N and modify my intake box. I cut the silencer and front off the intake. I now have the sound that I want. I also purchased a replacement box off badcopnodonut504 so that if I need to I can easily to back to stock.
Here is a link to pictures of the mod, the final install and videos of me driving around
https://picasaweb.google.com/jlanner...eat=directlink
I used a sawzall to do the cutting and a dremel to clean up the edges. I made sure to leave the factory mounting bolts in place.
I just did it on Monday but no CEL so far, no noticeable performance change or timing being pulled (liked I had when I bought and returned the K&N CAI).
My goal, like yours, wasn't performance but sound. Maybe I am a dork, but I don't want my car to sound like a Prius.
Josh
MacMan is offline   Reply With Quote
Old 09-01-2011, 02:58 PM   #16
kcwrxfan
Member#: 293070
2011 WRX Premium
There is no intake silencer on WRX's, the STI's however do on 2011. If you do an intake and tune you do not lose your warranty. But the dealer could deny a claim if they can prove that intake and tune cause the problem directly.
kcwrxfan is offline   Reply With Quote
Old 09-01-2011, 02:58 PM   #17
rkjunior
Member#: 112220
2011 WRX 5DR Premium
There is no silencer on the 2011s. Again.
rkjunior is offline   Reply With Quote
Old 09-01-2011, 03:28 PM   #18
curiousfish
Member#: 89283
2008 WRX Premium
SSM
**take note ppl**
08+WRX and STi, no intake silencer in fender.
you can get an aftermarket BOV or intake. To be safe, tune for intake, and be happy. For max sound, be sure to get a SRI.
curiousfish is offline   Reply With Quote
Old 10-19-2011, 02:24 PM   #19
EJ_cobrakilla13
Member#: 296308
2011 Impreza WRX
talked to my dealership the other day about my warranty and they told me as far as they are concerned the only way to void is to mess with fuel mapping and/or my turbo any other mods are ok as long as i keep up with my maintainance. They were very clear not to do any tuning because it will without a doubt void your warranty.
I have a 2011 STi and had my intake off the other day and this is what it will look like:
http://i1098.photobucket.com/albums/...6/IMG_0898.jpg
I simply removed that white section that drops into the fender well and was able to keep the ram air piece and it did no damage to my airbox so i can return to stock form anytime i need to. It made my intake sound much more noticeable especially under WOT , no CELs but not really any noticeable power.
EJ_cobrakilla13 is offline   Reply With Quote
Old 10-19-2011, 02:49 PM   #20
bildonia
Member#: 296219
2011 WRX Limited
Dark Grey Metallic
2011 WRX and STI have the same intake black box, but on the WRX the hole going to the white section is blocked off and not used.
bildonia is offline   Reply With Quote
Old 10-19-2011, 06:28 PM   #21
al82
Member#: 177913
2011 WRX STi PBP
I took some tape and wrap it around the top of the white bottle and plug it back in, easy fix!
Intake noise was more audible when cruising.
al82 is offline   Reply With Quote
Old 10-19-2011, 07:09 PM   #22
EJ_cobrakilla13
Member#: 296308
2011 Impreza WRX
wonder what purpose it serves then on the STi?
Trying to remove intake silencer, having some trouble removing the fender liner sportz135 Newbies & FAQs 22 06-15-2005 07:15 PM
remove intake silencer? knightsnke Newbies & FAQs 10 01-16-2002 03:32 PM
Remove Intake Silencer on 2002 RS? Tainted Normally Aspirated Powertrain 14 12-27-2001 04:11 AM
Removing Intake Silencer BJamerican Normally Aspirated Powertrain 1 04-08-2001 08:16 PM
