Old 09-01-2011, 01:43 AM   #1
greg86jgl
Member#: 191510
2003 wrx
blue
Default running a hta86 with a vf30 map?
I am running the Cobb vf30 map right now with all supporting mods. Within a week I am switching to the hta68. Can I drive my car safley with this turbo and the vf30 map? Like to the mechanic or to get it tunned?
greg86jgl is offline   Reply With Quote
Old 09-01-2011, 08:41 AM   #2
Cobb Tuning
Member#: 4803
If the only change is the turbo and you have the correct injectors and intake for the vf30 map, then you will probably be OK for driving to the mechanic/tuner if you stay out of boost (i.e. driving like a grandma). However, if you are going to get it tuned, most tuners will send you a limp map for your mods to get you there.
Bill
Old 09-01-2011, 11:59 AM   #3
greg86jgl
Member#: 191510
2003 wrx
blue
yea effi told me they would send me a limp map but i didnt know if i could drive it before to make sure the install was ok.
Old 09-01-2011, 02:41 PM   #4
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
Wait for limp map.
Test drive on limp map.
Double check for fluid/vacuum leaks.
Go to the tuner.
Profit.
You are forcing a square peg in a round hole to run an OTS Map not designed for your setup. Especially when it simply comes down to patience waiting for your limp tune.
WhyHelloOfficer is offline   Reply With Quote
Old 09-05-2011, 12:25 PM   #5
greg86jgl
Member#: 191510
2003 wrx
blue
I just wanted to make sure i couldnt drive it.
any thoughts on running a downpipe with stage two map without a protune? 08WRBsti AccessPort 14 11-14-2010 12:48 PM
vf30 map with an sti intercooler? Who's done it? andrew3776 AccessPort 6 04-16-2010 07:10 PM
Can I run 650cc Injectors with an AP map Flamanna AccessPort 5 12-10-2008 03:05 PM
Cobb VF30 map with HKS downpipe mmorningstar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-06-2005 11:02 PM
can i run 87 octane if i switch maps with defogger? SpeedShift Engine Management & Tuning 35 08-29-2003 02:47 PM
