Old 09-02-2011, 10:36 AM   #1
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
Default Constant Fine Knock Learn at low rpm
I am having Constant less than 0.7 degree Fine Knock Learn at low rpm medium load, it goes away over 3000 rpm at high load. Is it a problem?
Thanks.
Sheltonmega is offline   Reply With Quote
Old 09-03-2011, 09:55 AM   #2
Cobb Tuning
Member#: 4803
Fine knock learning at low loads is normal, especially when it is single counts (-1.4 or -2.0 depending on car). In your case, it has actually learned back to zero a bit (does so in increments of 0.35 deg.).
Fine knock learning is a learned correction, so the engine control unit (ECU) perceives a knock event when conditions dictate that fine knock learning is active and then makes a correction to the appropriate cell (each cell is based on a specific load and RPM range). So, for example, let's say one cell is 3000-4000 RPM and 1.0-1.75 g/rev of load. You are driving and the ECU perceives a knock event at 3200 RPM and 1.2 g/rev of load and fine knock learning changes are allowed. So, it drops that cell to -1.4. Now, everytime your RPM is between 3000-4000 and load is between 1.0-1.75 g/rev, you will see that correction (-1.4). Doesn't mean you are knocking when you see that value -> it is just a learned correction based on a past knock event. That is, the ECU is basically tweaking the timing based on these perceived knock event. If it finds that the knock doesn't occur in that cell again (based on specific conditions), then it will slowly ramp it closer to zero (in 0.35 increments).
Regardless of tune or car, you will always see the occasional knock correction, especially at low loads. This is normal. Where it is a concern is when you see consistent corrections at high load (such as during wide open throttle) that is not due to shifting or mashing the throttle. Or when you see consistent large corrections (-4.2, -5.6, etc.).
Bill
Old 09-05-2011, 08:52 AM   #3
Sheltonmega
Member#: 265204
Thanks Bill.
Very faint ticking/knocking sound at low RPM under load Dr. Ninja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 115 02-07-2016 12:29 PM
2011 Impreza 2.5i Knocking Sound At Low RPMs Bruins1982 Normally Aspirated Powertrain 62 11-24-2015 07:38 PM
i am getting the same fine knock learn at the same rpm everytime? dudenhoeffer02wrx Newbies & FAQs 2 08-08-2011 01:39 AM
feedback knock and fine knock learning??? please explain. dudenhoeffer02wrx AccessPort 3 07-28-2011 11:55 PM
constant fine knock learn? olazy AccessPort 5 05-24-2011 11:53 AM
