Old 09-03-2011, 12:12 AM   #1
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Default EJ20G valve cover gaskets?
I have searched high and low to find these gaskets and from my research, they are not available in the states. Is this true? If so, where can you order them from and not pay a billion dollars in shipping cost?
Part numbers from my research:
13272AA050 = Left outer gasket
13270AA050 = Right outer gasket
13293AA001 = Inner spark plug hole gasket
Pics of my valve cover and gasket:
Any help from the EJ20G Guru's out there? Matt Monson? Jaxx?
The motor is from a JDM legacy I believe, and came with a VF10 and a flex plate on the back so it was an AT car. It had coil packs on it, and that's about all I know. I'm getting ready to drop this in to my wife's Outback, and she won't appreciate the burning oil smell from it leaking on the exhaust
Thanks in advance!!!!!!!!!!!!!!!!!!!!!
morrocco88 is offline   Reply With Quote
Old 09-03-2011, 12:10 PM   #2
cmyles
Member#: 275572
2007 Built STi
Cam Seal Gaskets #806732150 (HALF MOONS)
Valve Cover Gasket RH #13270AA040
Valve Cover Gasket LH #13272AA040
Spark Plug Gaskets #11051AA070 (For one bolt Valve covers)
Those are what i used, but i was putting them on a 94 EJ20G out of a STi
I just ordered them from a buddy who owns a shop,
you can try just punching them into google and ordering it off a site that pops up,
#Edit, looks like you have the right part numbers and everything,
Go to a local tuner shop or something and bring them the part numbers man, subaru won't do shiiiiz
cmyles is offline   Reply With Quote
Old 09-03-2011, 01:40 PM   #3
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
Tizzle is offline   Reply With Quote
Old 09-03-2011, 02:39 PM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Wrong numbers above.
These are Legacy Turbo EJ20G rocker covers, the numbers the topic starter found are correct:
The small plug cover is 13293AA001 (2 needed), the LH gasket is 13272AA050 (1 needed), RH gasket is 13270AA050.
Marnix is offline   Reply With Quote
Old 09-03-2011, 03:03 PM   #5
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Originally Posted by Tizzle View Post
Thanks for the link! I totally forgot Outfront Motorsports does a ton of sand rail stuff with the older JDM motors.
Thanks for confirming the part numbers!
Old 09-03-2011, 03:26 PM   #6
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Just ordered on Ebay from Outfront
One last question: Are all the bolt hole washer/grommets the same for the 20G, 20K, EJ25D? Could I just order them for a USDM EJ25D from my dealer, or are they going to be "special" JDM only like the gaskets?
Thanks for all the help guys!
Old 09-03-2011, 03:57 PM   #7
Tizzle
Member#: 44472
Ver2 Legacy StiRA
Impressive legacy, BTW morrocco88
Old 09-06-2011, 12:52 AM   #8
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^Thanks!
Anyone on the grommets/bolt washer seals?
Old 09-06-2011, 08:41 AM   #9
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Yes they are the same.
Old 09-06-2011, 03:49 PM   #10
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Thanks!!!!!
EJ20G valve cover gaskets carter_wrx Pre-2002 Factory Turbo Powertrain 6 09-01-2010 06:22 AM
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 02:13 AM
Valve cover gaskets for ej20g? rockethound Normally Aspirated with bolt-on Forced Induction Powertrain 6 08-28-2008 10:21 AM
EJ20G valve cover gaskets Impreza Rider Subaru Conversions 5 11-09-2004 09:44 AM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 09:50 PM
