Old 09-03-2011, 12:04 AM   #1
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
Default Limits of the stock ej22t shortblock
Hi i was just wondering what the stock internals of the ej22t can handle
For example i am thinking of taking a ej22t shortblock and putting wrx heads on it and merging that with my current 2004rs ecu.
I would plan on running a td04 and id like to have maybe 13lbs of boost (aka) wrx equivalent with more midrange and not as horrible turbo lag and low end.
So can a stock 2.2t shortblock take this? *by this i mean pistons/ rods/ crank
But not only that, how risky is this (should i expect failures in the near future?)
KevinT. is offline   Reply With Quote
Old 09-03-2011, 03:46 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d00000000000000d
there are guys that have run 30+psi on BIG turbos on that motor...it will EASILY make 400+hp
what you plan is the purest waste of all involved of a nice 22t
dont **** up a nice motor doing dumb things to it
Old 09-03-2011, 11:44 AM   #3
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
oh lol i dont plan on staying that way forever (and i know it is the high hp /high boost engine of choice) thats why im considering it, because in the future i plan on fully building it.
I was wondering what the STOCK pistons/ rods/ crank can take power wise and boost wise.
All of the people running 30psi have forged pistons better rods and a better crank.
I want to keep it at wrx power levels for a little while until i can save up the money for forged pistons rods and a better crank plus the turbo needed to make that power as well as a front mount/ injectors/ fuel pump /transmission /clutch setup ect....
I have heard that the stock pistons can take up to 14lbs of boost but i'm not really sure and that's why i was asking here among the gurus.
Old 09-03-2011, 01:09 PM   #4
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
EJ22T has a problem with cooling, I believe.
Smoke is offline   Reply With Quote
Old 09-03-2011, 01:16 PM   #5
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
I have heard that too i have to dig around more in regards to that
Old 09-03-2011, 01:53 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes, you would be fine at that power level.
These engines are 20 years old now, keep that in mind, it could have significant wear.
Old 09-03-2011, 02:21 PM   #7
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
that is very tru it really has to hold up for a year or two maby 3 and then i can rebuild it
Old 09-03-2011, 04:10 PM   #8
RallyColtTurbo
Member#: 16819
In stock form:
EJ22T has the same crank and rods as the early EJ20G. Rods are the limiter in stock form, as on the EJ20G. The pistons are cast, and of the same basic design as the EJ20Gs - so power limits on those are also the basically the same.
Watch the compression ratio and quench, as the EJ22T pistons stick out of the deck a few thousands.
RallyColtTurbo is offline   Reply With Quote
Old 09-03-2011, 06:29 PM   #9
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
No they don't. Its a misconception. They cool fine. I ran an EJ22T block in my road race STi without any problems. And that was on a much bigger turbo than a TD04!
Some idiot on the internet looked at the deck and said, "Damn, the closed deck is going to restrict coolant flow to the cylinder head." Not realizing that it has to flow through a head gasket that looks like this, no matter what the deck looks like:
eastcoastbumps is offline   Reply With Quote
Old 09-03-2011, 09:56 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Listen to rallycoltturbo. He's right about the rods. They are good to about 350chp, and then they start to have issues.
Listen to eastcoastbumps about the cooling issues, or more to the point the fact that there are none...
Old 09-03-2011, 11:53 PM   #11
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
Ok thanks for helping out i think this is really going to go in to motion in lets say...a month? ....does any one know any other issues i may run in to while were here? clearance issues? tuning? (I'm definitely getting a Tune though)
Old 09-04-2011, 03:10 AM   #12
VIcuha
Member#: 265954
2015 WRX
grey
as far as i know 2.2 r the engine to go with if u want reliable power. im curently in process of building an engine. i will use early sti heads to it. and perryn turbo about 20psi. some of those 2.2 have oil sprayers inside which is big+
VIcuha is offline   Reply With Quote
Old 09-04-2011, 11:51 AM   #13
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
On a high revving Subaru engine it is more important to keep your rod bearings well lubricated than it is to keep your pistons just that little bit cooler. I recommend plugging the oil squirters.
Old 09-04-2011, 01:48 PM   #14
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
Really? i would think that the oil squirters would be one of the big bonuses of the engine .....also i dont plan on raising the redline or anything like that
Old 09-04-2011, 01:51 PM   #15
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need the oil pressure to keep the rod bearings oiled way more than any cooling effect the squirters might have.
They are usually clogged or fall out on high mileage EJ22Ts anyway.
Old 09-04-2011, 01:57 PM   #16
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
ok thanks .....ill make sure to do that if i go the ej22t route
Old 09-17-2011, 08:38 AM   #17
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I had mine cleaned. The stock oil pump will make enough pressure to make sure everything gets the propper lube..unless we are talking about crazy high revs
Cbgrandtheftauto is offline   Reply With Quote
Old 09-17-2011, 06:26 PM   #18
Sean2.5Black
Member#: 150647
98 Impreza 2.5RS
Ej20G hybrid
Pull the oil pan before installing the motor.. The OE oil squirters tend to pop out...
Sean2.5Black is offline   Reply With Quote
Old 09-17-2011, 07:11 PM   #19
eg33GC
Member#: 206851
56 Belair
Pro Street
Originally Posted by Uncle Scotty View Post
d00000000000000d
stock 22t can't do that, you pinhead.
eg33GC is offline   Reply With Quote
Old 09-17-2011, 08:30 PM   #20
darkcrave
Member#: 204753
2002 wrx
Im running a 91 Legacy tubro ( Came stock EJ22T )
The EJ22T Block Amazing.
the EJ22T Heads BLOW
Interals are okay ( crazy power = buying forged internals )
Buying some EJ20G/K heads will help you
They will also give you more options on your intake manifold ( so you can run under intake inlet more turbo options without modifications )
Overall EJ22T is a very nice setup only most old schoolers know about! do some more research! A stock Ej22T with suporting mods and aftermarket tuning ( Such as robs tune ) will get you about 250-275 WHP on stock internals with the crappy EJ22T heads running about 19PSI on a TD05H. ( you wont get much more out of the EJ22T heads ) Thats of course if the engine is in good shape and not beat to hell lol
darkcrave is offline   Reply With Quote
Old 09-18-2011, 10:19 AM   #21
KevinT.
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
ok i bought a 2002wrx longblock which i am going to run untill 160k. (at 90k now) and in the meantime i will be slowly building up a 2.2 block and i will replace the 2.0 block with it and keep all wrx wiring and heads
Old 09-19-2011, 01:31 AM   #22
dustyroads13
Member#: 274449
2002 wrx
the ej22t is the turbo version? whats the difference between the normal engine
better internals?
dustyroads13 is offline   Reply With Quote
Old 09-19-2011, 09:12 AM   #23
rrob311
Member#: 248743
better internals?
Ya from the old turbo legacys from the early 90's. They have oil squirters among other things. SOHC
rrob311 is offline   Reply With Quote
Old 09-19-2011, 09:27 AM   #24
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
As many have said. Rods will be the weakest part. Around 350-400 BHP is the upper limit since they are a lot narrower than the later rods. Pistons are cast but are OKish upto 400 BHP. Cranks have the thrust bearing on #3 journal which is a PITA when trying to find a new crank or you can have the block machined to accept later #5 journal cranks. The block itself is great and can handle LOTS!
Jasper.
jkopinga is offline   Reply With Quote
Old 09-20-2011, 09:36 PM   #25
__TT__
Member#: 136256
if your gonna do it I highly recomend doing a dohc head swap before installing it. Its just easier to do it in the first place. I ran 13-15ish on the motor for two years before the age of the motor spun a bearing. now running 20 psi on a rebuild for about 9 months now. very reliable and drivable with the dohc. powerband is just way to early and short with the sohc.
__TT__ is offline   Reply With Quote
limits of the stock catback... 04pauliewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2009 05:55 PM
Looking for wrx horsepower out of a stock ej22t swapped 98 impreza L awd. -> HOW TO? hotshot2109 Subaru Conversions 9 09-11-2005 12:48 AM
Question: what is the age limit of the US draft? edkwon Off-Topic 50 08-22-2005 08:45 PM
Has anyone found the limits of the stock fuel pump yet? Corn-Picker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 04-01-2004 10:37 PM
wha's the limit of the stock fuel system? turbo? & intercooler? vile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-02-2003 05:06 PM
