Old 08-01-2002, 04:37 AM   #1
cvalle-sd
Member#: 420
2001 Cr-V
Default Change in torque curve w/"Big Box" filter?
I've been running w/o a filter in the plenum since I can't remember - I (accidentally) bought a K&N filter for the plenum, and decided to run it with the K&N panel filter I already have in the main (small) airbox. I "think" I feel more torque down low...does that make any sense? The car doesn't feel any slower, and I'm fairly certain it pulls more strongly and immediately from low revs. Could there be some turbulence issuse or something in the plenum that a filter would balance? I know I don't need two filters, but I figured that two K&N panels would be the least restrictive stock setup, and also that the intake as is, might not be the most restrictive link in the chain, so adding 2nd filter might not reduce breathing to the point where power would be affected, that is, I may have had more flow capacity with a single panel than my engine setup could take advantage of... In which case I wouldn't mind the extra filtration.
Thoughts? Experiences? Instumented Tests? Rhetoric? Unsubstantiated Character Attacks? Gangsta Rap? Haiku?
cvalle-sd is offline   Reply With Quote
Old 08-01-2002, 02:37 PM   #2
Jademonkey
Member#: 9213
2000 RS
Red
I only have a lot of hearsay and conjecture...
But anyway, It's probably your imagination... Did you do an ECU reset after changing filter. It's not necessary, but different air flow, your ECU would take a while to learn, and if just reset, you might feel more on the butt dyno....
just a few thoughts....
Jademonkey is offline   Reply With Quote
change in torque to wheels romanlynch Transmission (AT/MT) & Driveline 2 04-11-2007 11:34 PM
Why the change in torque split on the 06 STI? Zoso General Community 35 10-12-2005 01:42 AM
Hunting for Idle? Flats Spots in Torque Curve? Costas Normally Aspirated Powertrain 0 08-23-2003 10:42 PM
Graph of horsepower/torque curve for phase I 2.5L? 2.5GT Legacy Forum 10 06-08-2001 04:14 PM
('93-'01) Graph of horsepower/torque curve for phase I 2.5L? 2.5GT Impreza Forum 3 06-08-2001 01:00 AM
