Old 09-04-2011, 12:18 PM   #1
Strider327
Member#: 131280
2004 Impreza WRX
Default USDM 2.0 EJ205 WRX swap into a 1997 Legacy 4eat
I got a friend that has a 1997 Subaru Legacy 4eat (Auto) He is finally thinking about doing a 2002-2005 USDM 2.0 EJ205 engine swap and rebuilding his current transmission. Is there any unforeseeable problems that will occur? I know for a fact he will be getting the complete longblock with all accessories from intake manifold, radiator, wiring harness, etc. However, the only thing is will the transmission be able to work properly with the newer engine is my only question. Mechanically it seems like it will bolt up fine perfectly. Any input MUCH appreciated. We will probably be getting a harness made to be a plug and play setup by ECS for this swap. Thanks in advance.
Strider327 is offline   Reply With Quote
Old 09-04-2011, 01:28 PM   #2
RSwapped
Member#: 243283
1999 OBS w/ WRX swap
Boostincorporated.com
depends how much power he's planning to make.
RSwapped is offline   Reply With Quote
Old 09-04-2011, 05:15 PM   #3
Strider327
Member#: 131280
2004 Impreza WRX
stage 2 or even a vf39 maximum. For sure, under 290WHP
Old 03-18-2012, 11:33 AM   #4
subieguy87
Member#: 153412
1998 Impreza wrxRS
He'll need a valve body for his 4eat then
Google IPT transmissions
subieguy87 is offline   Reply With Quote
wrx 2.0 ej205 build robwrx19720 Built Motor Discussion 12 03-06-2009 05:43 PM
03 WRX 5 speed into a 96 Legacy 4EAT cm1wrx Transmission (AT/MT) & Driveline 4 12-14-2007 12:17 PM
USDM 2.0 vs. JDM 2.0 flon3y Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-12-2006 09:03 PM
1990 ej20t legacy motor into a 1997 legacy motorswapsleeper Subaru Conversions 15 08-13-2005 08:27 PM
usdm 03 wrx swap into 00 rs, stock radiator/fans? AzNStiImpreza Subaru Conversions 1 07-29-2005 06:10 PM
