Old 05-21-2012, 01:28 PM   #126
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
First off, thanks for the amazing thread. There is a wealth of info here. I've read the entire thread and have found some hints at what I'm looking for so I figure I'll throw my questions in the hopes that the answers will help everyone.
I'm looking for primer, paint, and clearcoat. You've given recommendations on the type of clear and primer to use, but I'd like to know if you could maybe add some more info to your first post to list some links to where this kind of stuff can be purchased?
I don't have any pics handy, but I'm looking to do some extremely small scale rust repair on my car (think 1" by 1/16" area, essentially a deep scratch that hasn't deformed the sheet metal). I'll try and post up some pics when I get home but the rest of my questions are as follows:
1. Can you buy this stuff in small enough quantities or should I bite the bullet and buy (way) more than I need?
2. Can I do the primer, paint, and clear application without the use of a sprayer? I've found some paint sprayers that will work with my air compressor in the extremely cheap price range, but you've mentioned above that you may or may not recommend it depending on the brand. I don't want to buy any junk that just won't work well. If you don't recommend doing it by hand then maybe I'll search out a place to rent the equipment from.
3. Given the extremely small area I'll be working with can I get away with using a bottle of the OE touchup paint for my car or is it not designed to be applied that way?
Thanks again for the help. This thread rocks.
bigmaninjapan is offline   Reply With Quote
Old 05-21-2012, 05:24 PM   #127
Tanktheory
Member#: 239981
01 SF5 Ver 8 swap
Blu
Dear MattTHEpainter,
I'm looking to prep my entire 1987 BMW for a paint job to help reduce costs. What procedures / products would you use.
With love,
Tanktheory.
PS. Sit on my face
Tanktheory is offline   Reply With Quote
Old 05-21-2012, 09:59 PM   #128
eastcostsuby
Member#: 320895
I have a limited Sti spoiler that I want to spray paint. The material is plastic (I think not sure) and it's been painted before and I want to color match it to java black pearl. What procedure should I take to prep it correctly?
eastcostsuby is offline   Reply With Quote
Old 05-22-2012, 07:21 AM   #129
jjasonn
Member#: 208653
2004 V-Limited
Spec C
i have a wagner optimus power painter pro series hvlp cordless sprayer. it works very very good! paint all distributed very nicely. idk but if u people wants to paint, buy this. it has an inbuilt compressor and u dont need an air compressor for it and its powerful.
jjasonn is offline   Reply With Quote
Old 05-22-2012, 07:31 AM   #130
lp87
Member#: 284237
2015 wrx
ism
What should I do to fix chipped fenders? They are chipped on the inside and I want to fix them and prevent further chipping. Should I just use touch up paint?
lp87 is offline   Reply With Quote
Old 05-22-2012, 04:44 PM   #131
03Rextacy
Member#: 239497
2003 Impreza WRX
Cleared and pretty. I'll post pics up this weekend of them on the car!!
03Rextacy is offline   Reply With Quote
Old 05-22-2012, 08:50 PM   #132
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Thanks for the kind words, just glad to help.
I have always recommended going to your local auto body supply store to purchase refinishing materials. I recommend this to beginners because it gives you the opportunity to get professional knowledge about the product you are buying. You will receive tips and tricks for application, and they will be able to help you get the right product for your project. I have never really purchased refinishing products online so I couldn't give a solid recommendation.
1. You can buy base coat in any quantity you like, from a 1/2 pint to gallons. I believe the lowest quantity for a clearcoat setup (clear, reducer, harder) is a quart. Primer usually comes in quarts to gallons too.
2. You could use spray cans, but I do not suggest it. A paint gun is like any other tool, usually price dictates quality. But, I have sprayed with cheap guns and gotten good results.
3. For such a small scratch I think getting a touchup brush from your local dealer or supply store is your best bet. Repainting an entire panel for such a small scratch doesn't seem very logical.
Let me know if this helps.
MattTHEpainter is offline   Reply With Quote
Old 05-22-2012, 08:52 PM   #133
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
With love,
Tanktheory.
PS. Sit on my face
Hello Tanktheory,
If I told you how to prep your car I would not be able to charge you $$, that I plan on charging you.
Your favorite painter,
Matt
Old 05-22-2012, 08:59 PM   #134
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
If the existing paint is in good condition on the spoiler, all you have to do is get a grey scuff pad:
http://solutions.3m.com/wps/portal/3...glTXX4WRPPK6bl
And some "scuff stuff".
http://www.prestaproducts.com/Scuff_...p-details.aspx
Then use both products to sand the spoiler and remove any "shine", so the finish is dull. This allows the new paint to "bite" and have a solid foundation.
If there is any imperfections use 400 grit wet sandpaper to feather out the damage.
Then refinish.
Old 05-22-2012, 09:01 PM   #135
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Interesting...
Old 05-22-2012, 09:03 PM   #136
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
How bad are they chipped? I have never used Dr. Color Chip, but have only heard good reviews about the product. You should check that out.
Old 05-22-2012, 09:07 PM   #137
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Those look great man, I can't wait to see them on the car. Bring the rims to a good shop to make sure they don't mess them up, it would be a shame to see your hard work go to waste.
Old 05-22-2012, 09:24 PM   #138
03Rextacy
Member#: 239497
2003 Impreza WRX
I agree!! Have to find a specialty shop around here for sure
Old 05-23-2012, 12:48 AM   #139
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Originally Posted by MattTHEpainter View Post
Interesting...
take a look here. i have the exact same one
Old 05-23-2012, 03:10 PM   #140
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
Thanks this indeed helps. This is definitely the easiest (and cheapest) route.
Old 05-26-2012, 08:33 PM   #141
Tanktheory
Member#: 239981
01 SF5 Ver 8 swap
Blu
Just purchased a Wagner Optimus, thanks for the advice PainterMatt!
Old 06-02-2012, 09:23 PM   #142
03Rextacy
Member#: 239497
2003 Impreza WRX
Here it is:
Old 06-04-2012, 11:22 AM   #143
Goeddel
Member#: 286137
2005 Sti
Jbp
hello,
I have an 05 jbp sti. when i bought it there was a large paint chip in the drivers door. It is chipped down to the bare metal and maybe a bit bigger then a quarter. I have just been keeping it rust free but would like to know what i need and the process to fix this chip. This is a tiny dent but mostly just worried about the paint chip.
Thanks,
Goeddel
Goeddel is offline   Reply With Quote
Old 06-04-2012, 05:32 PM   #144
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
People should post up about that Wagner painter! I'm curious to see how well it works!
mr.nicknasty8 is offline   Reply With Quote
Old 06-04-2012, 06:14 PM   #145
jjasonn
Member#: 208653
2004 V-Limited
Spec C
I was the one who said about the Wagner Optimus lol
Old 06-04-2012, 07:13 PM   #146
AWDspider
Member#: 43748
matt the painter: couple of questions.
1. how much paint and clear is typically required to respray a wrx/sti size car (im keeping the color pretty close to the current color).
2. this one really goes along with the first question but what all would one need to buy for a respray, including material to fill small scratches/chips. just the "chemicals".
3. i plan on keeping the color very close to the current color UGM but i intend on doing a matte/satin finish. is there a particular brand that you recommend for the paint and matte clear?
4. i have been talking to two different painters one is charging about $3200 for a respray with minimal body work (just some filling here and there of chips). the other is charging $1500 as a "side" job and i provide the "chemicals". they both have been doing this type of work for some time now but the cheaper one has never done a matte finish before. i assume that the application of the two are identical except the matte doesnt require any type of buffing, is this correct? also do those two prices sound ok considering one is done through a company with a warranty ($3200) and the other is done on his free time at his home shop ($1500)?
thanks,
shaun h
AWDspider is offline   Reply With Quote
Old 06-04-2012, 08:22 PM   #147
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Here it is:
Looks clean man, I like everything about it.
Old 06-04-2012, 08:25 PM   #148
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Originally Posted by Goeddel View Post
hello,
Thanks,
Goeddel
I would dab a little self etching primer on the bare metal to give the touch up proper adhesion. Then use some touchup on the spot. Its a little weird the paint just chipped off though. Ever been repainted?
Old 06-04-2012, 08:26 PM   #149
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
This is on the same level as applying paint with a roller. If you want something done nicely, do it correctly.
Old 06-04-2012, 08:30 PM   #150
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Lol no Matt it's a totally different level. It's an hvlp air sprayer... It has inbuilt air compressor. Nowhere the same as a roller.. Believe it or not, I have shown a buddy doing body work for about 15 years now and he is amazed by it and he got me to buy one for him because when he tried it, it was so evenly distributed that he told me he couldn't not have one..
How Bad Are Auto Sales? 10 Questions and Answers AVANTI R5 Non-Subaru News & Rumors 1 07-07-2009 05:14 PM
Anybody in the auto body/paint business? markman Off-Topic 4 05-17-2008 10:40 AM
Auto body/paint in SW Houston/Stafford? petregeus Texas Impreza Club Forum -- TXIC 4 04-01-2006 01:11 PM
auto body paint blaznasn Interior & Exterior Modification 0 09-17-2001 06:32 PM
Looking for auto body/paint shop Vestas Tri-State Area Forum 1 07-03-2001 09:02 PM
